Old 08-25-2021, 10:33 AM   #1
Coded4SS
Drives: 2020 1SS 1le
1le Replacement Pad Suggestions
Hi Gents,
21k miles on my 2020 SS 1le. Pads are about done. Looking for replacements with firmer pedal feel, dont want pad noise ( ive never heard any from stock brembo). Use for some track and daily/ canyon use. Any suggestions?
Rotors look good, ill clean them up any reason to turn these?
Thanks!
Coded4SS is offline   Reply With Quote
Old 08-25-2021, 10:35 AM   #2
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
sounds like oem is the way to go for you
Old 08-25-2021, 11:42 AM   #3
Coded4SS
anything out there with a little more bite? firmer pedal? I may replace the brake lines at the same time
Old 08-25-2021, 11:44 AM   #4
kropscamaro16
if you daily it i wouldnt recomend anything else to be honest i use hawk dtc60 but they are not good for the streets
Old 08-25-2021, 12:31 PM   #5
Uncle Sam
Drives: 2017 Camaro 1LE Hyper Blue
Stock sounds like the best for your mix. They are Brembo after all, not too shabby a reputation for delivering performance.
Uncle Sam is offline   Reply With Quote
Old 08-25-2021, 12:34 PM   #6
kropscamaro16
call ken at kns if you want help but i would stick with oem
https://www.knsbrakes.com/c/home
Old 08-25-2021, 12:57 PM   #7
Coded4SS
thank you broski's thats kinda what i suspected.
Old 08-25-2021, 01:22 PM   #8
Kmeleon
Drives: 2018 NFG 2SS 1LE!
I believe OEM pads with stainless brake lines might be the ticket for a more firm pedal. Atleast that's what I'm thinking about for mods this winter.
Kmeleon is online now   Reply With Quote
Old 08-25-2021, 01:37 PM   #9
kropscamaro16
and upgraded fluid if you dont already have it
Old 08-26-2021, 09:05 AM   #10
MatthewAMEL
MatthewAMEL's Avatar
Drives: 2023 CT5 Blackwing
OEM pads for sure. They are the best pick for 90% of the use cases out there.
Get stainless lines for dress up, they don't do anything for pedal feel.
(and before the stainless line guys show up and torch me, I have Speigler's from KNS on my 1LE).
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
Old 08-26-2021, 12:42 PM   #11
Kmeleon
Hmmm, I had heard they did make for a stiffer pedal. I will have to go back and re-read.
Old 08-26-2021, 06:32 PM   #12
5.M0NSTER
5.M0NSTER's Avatar
Drives: 2018 Camaro 1SS 1LE
OEM pad and don't waste your money on SS lines. I had a set of Russel SS lines burst on me at the track on a previous car. Was the pedal a bit stiffer? Sure. Did I notice after a while? No.
Or if can tolerate more dust and/or noise, and don't mind $$, choose one of these.
https://www.knsbrakes.com/c/car-item...eet+Brake+Pads
5.M0NSTER is offline   Reply With Quote
Old 08-29-2021, 05:24 PM   #13
Hops
Hops's Avatar
Drives: 2019 1ss 1le, blue wrap
My original OE pads were more than half done, and I replaced them with a new OE set, but now I’m only using that new set for the summer track season, I kept the original set for rest of the year. I figure this maximizes use by saving more of the first half for track use.
Hops is offline   Reply With Quote
Old 08-29-2021, 06:34 PM   #14
DaveC113
DaveC113's Avatar
Carbon fiber lines (sold small-scale by a member here) and brembo fluid made a pretty noticeable improvement in firmness and feel for me.
DaveC113 is online now   Reply With Quote
