07-03-2021, 12:10 PM | #1 |
Drives: 2017 Camaro SS Join Date: Jun 2021
Differential click/pop sound
Okay so I’ve noticed over the last few months that my SS does this weird thing where it clicks/pops every time I let off the throttle, and then again when I reapply the throttle in any gear. It gets louder when the car is warm, so loud that I can hear it inside the car even with the windows up. I can also physically feel the car jerk when this happens too. It almost feels like the pinion is skipping a tooth on the ring gear causing a jerk. I can recreate this sound by holding the brake and putting the car in first gear then releasing the clutch to its friction point (pop 1), then immediately putting it in reverse and doing the same thing (pop 2). I did it in this video I posted on YouTube, here’s the link. Is this normal or am I tripping. I have a apt at the dealer set up for next Friday the 9th. Reason why I’m worried about it now is because I’m literally about to go full bolt on (ported msd, headers, full exhaust, soler 95mm throttle body, E) and I want to get this taken care of before I start adding these parts I already bought and void my warranty.
EDIT: forgot to say, I thought it was my clutch making normal clutch noises at first but it’s not, if I physically grab the driveshaft and turn it with my hand while the car is on the ground, it has like a 1/10 revolution of play and it clicks back and forth inside the diff, so it’s 100% something with the diff. I know 373 gears are known to be loud. But this loud?? Thanks https://youtube.com/shorts/7WgQ3iY8JSg?feature=share Last edited by SnowWhiteSS; 07-03-2021 at 12:14 PM. Reason: Forgot to add something |
07-04-2021, 05:45 PM | #2 |
376 cubic inches of fun
Dude why are you torturing your drivetrain?
All differentials have backlash. |
07-04-2021, 09:46 PM | #3 |
IYAOYAS
Drives: 22 1LE 2SS M6 Riverside Blue Join Date: Mar 2018
Could it be rear end links? I had a very similar issue witha 2018 camaro ss M6, even backing up it made a popping noise. It went away for good after getting retightened.
2022 Riverside Blue Camaro 2SS 1LE/ PDR
2020 Red Hot Camaro 2SS 1LE/PDR /Sold 2018 black Camaro 2SS M6 Redline Edition/Traded 2016 summit white Camaro RS V6 M6/Traded |
07-06-2021, 07:18 AM | #4 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
If that lash isn't there the driveline would destroy itself. Some cars more than others for sure but some is normal and your description is normal.
07-06-2021, 10:01 AM | #5 |
02-01-2023, 11:35 PM | #6 |
Drives: Chevrolet Camaro X2 Ford Excursion Join Date: Dec 2022
Did you ever get your rear diff checked by Chevrolet? Did you find out what it was, was it normal? I purchased a new 2022 SS 1LE with the 6 speed and my diff does the same thing. I couldn't hear the noise in your video. I have video of the movement of pinioon in the diff and makes that noise andit wasn't like this a couple months ago. I bought it 9-30-22, I have 1475 miles on the car, followed break-in procedure 95% and to me the amount of movement in the pinion and the noise is not normal. I took the car to the dealership last Saturday, 1-28-23 and they didn't have a technical technician to loo at the diff but the service writer said of course, That's normal." It may be normal to have that much backlash but to have that noise that sounds like ring and pinion are about to explode can't be. I own a 1976 Chevy 3/4 ton 4-speed with 30?,??? miles and it doesn't make that noise. I alsoam a bit worried about warranty as I have installed BMR, toe rods, cradle shims and cradle lock out kit and upper control arms. BMR parts are to make it better but Chevrolet may use it to void warranty. May be covered by tat Magnassun law possibly or whatever that law is. Long thread and I apologize. First time post. Thank you all. I have learned alot. Where can I post those videos of my diff? Thanks again.
Here is a link to a video showing pinion making that noise. Another video on the noise turning the wheel. Pinion Link https://gopro.com/v/57mXKbBDNXv15 Wheel Link https://gopro.com/v/8veb7KrzwP054 Is this normal? Last edited by switzer; 02-02-2023 at 03:40 PM. Reason: Link to video |
