04-01-2022, 05:35 PM | #1 |
Drives: 2008 Pontiac G8 GT, Shelby GT500 Join Date: Mar 2011
ZL1 vs Blackwing
Is it just me, or is the CT5-V Blackwing a bit faster than the ZL1 even though it has the same engine and weighs more? I’ve heard of a few at the strip trapping around 128 mph and seeing videos like this make me think there’s more than an additional 18 hp in these things.
https://youtu.be/YiS89K33MMU |
04-01-2022, 05:40 PM | #2 | |
Drives: 2022 Wild Cherry ZL1 1LE Join Date: Mar 2021
Geoff |
04-01-2022, 05:46 PM | #3 |
Yes non 1LE. The Caddy offers the same 10 speed that the ZL1 has. I’m not sure about aerodynamics but I’ve seen a few videos of guys running 0-60 in under 3.5 seconds and it absolutely rips past that. Definitely seems a bit more robust than the ZL1s I’ve seen. I know Cadillac made some revisions to the LT-4 and got a little more power out of it, but it seems like more than a little after seeing videos of them run.
04-01-2022, 06:42 PM | #4 | |
Drives: '12 Corvette GS / '13 Equinox Join Date: Oct 2015
~ Current Rides ~
'22 Camaro ZL1 | A10 | Carbon Everything '22 Kia Stinger GT2 RWD - Bone stock '19 Kia Sorento - Wifemobile ~ Previous Cars ~ '12 Corvette Grand Sport '12 Infiniti G37xS Sedan - Takeda CAI, FI RHFC + FI resonated cat-back, Hotchkis F+R Sways, SSR GTV03 (18x9.5 +45 squared), Toyo Proxes T1 Sports, Tanabe Lowering Springs, Full Akebono BBK upgrade F+R, StopTech Rotors/Pads/SS Brake Lines, Takeda FTSB, (300AWHP / 251TQ) |
04-01-2022, 06:48 PM | #5 |
Drives: CHEVROLET CORVETTE Join Date: Feb 2021
Cadillac does something right then kills it. GM typically does. Just got this months Motor Trend. BW4 vs BMW M3. Guess who won? MT and Car and Driver, if its a Porsche or BMW against anything, they always win.
04-01-2022, 07:00 PM | #6 |
Drives: 2022 ZL1 M6/Nissan Leaf Join Date: May 2016
Might have to do with how the two put power down. The CT5 is fitted with 305/30ZR19 and is a little heavier. Isn't higher trap speed related to how quick you can put the power down and build speed? I'd love to see how the ZL1 would do with similar tire/wheel size.
04-01-2022, 07:11 PM | #7 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
Trap speed is normally indicative of power and weight. ET is indicative of how well you put the power down.
04-01-2022, 07:12 PM | #8 |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
Anyone seen any 60 - 130 times for it?
04-01-2022, 07:13 PM | #9 |
I would have to see a ZL1 and Blackwing on the same track, same day to determine which is quicker. The ZL1 has the power to weight advantage and should be slightly quicker. Comparing different cars and different tracks on different days is pointless.
04-01-2022, 07:22 PM | #10 |
Pretty equal cars. A lot is on the driver.
04-01-2022, 10:17 PM | #11 |
Drives: ZL1/1LE parts added Join Date: May 2018
Location: Somewhere around Texas pines tress and smooth asphalt
I asked this question a month ago, was told the blower has a improved rotor pack, tune, and maybe throttle body, so it's more like 30hp or more over the ZL1.
04-01-2022, 11:11 PM | #12 |
04-01-2022, 11:22 PM | #13 |
Drives: 2021 Camaro ZL1 A10 Join Date: Nov 2018
This is tough, but I think it is about +20-25 hp over the ZL1, so I don't think Cadillac is really underrating the CT5V Blackwing.
Here's my theory: GM advertises the ZL1 as 11.4 @ 127 mph and the auto ZL1 weighs 3,925 lbs. If I remember correctly GM advertises the Blackwing as 11.3 @ 128 mph in the 1/4 mile and it weighs just over 4,100 lbs, however, that version has the carbon ceramic brakes, which saves a lot of rotating mass, bringing the theoretical weight differential a bit closer than the approx. 190 lbs on paper. Call it closer to a 125 lbs difference, as far as acceleration goes due to the lighter brakes and less unsprung rotating mass. So, to go 1 mph more in the 1/4 mile takes about +15 hp at these power levels. Then, to make up for the 125 theoretical difference in weight you'd need another 15 hp. So, call it +30 hp, however, I think the Cadillac is slightly more aerodynamic than the ZL1, which helps its acceleration at higher speeds, thus, reducing that theoretical 30 hp difference down to about 20-25 hp to get to the claimed performance numbers. So, I think it is only about 20-25 hp more than the ZL1, so similar to, or only slightly over, the advertised 668 hp.
2021 Camaro ZL1 A10
2022 GR Supra 3.0 Past: 2018 Mustang GT Premium w/ PP1, MR, and A10 2007 MazdaSpeed3 1995 Pontiac Trans Am 1987 Camaro Z28 |
04-02-2022, 06:08 AM | #14 | |
Drives: 19' ZL1 A10, w/pdr Join Date: Sep 2014
BTR Stg II cam w/ 38% fuel lobe, ARH 2" headers into 3" w/cats, AWE Touring, Kong X port, Weapon X triple ht exchangers, NW 103, Rotofab big gulp, DSX lowside, TCM tune, BMR Lockout, Mustang dyno 720 rwhp, 634 rwtq on 93 pump.
