Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro DIY & HOW-TO instructions & discussions
Old 03-25-2014, 09:03 PM   #57
Low RS
Low RS's Avatar
Drives: 2010 ''RS1'' my own package
Originally Posted by Jerry7297 View Post
Been working on that....
Here is attempt one, Fiberglass. It would still work I just dont want to put in all the time to bondo it and all that. so today...
2nd attempt. Lexan from Home Depot. This fits fine and I think I am just going to Plastidip it and be done with it...
CAN YOU GET US A PIC OF THIS ON THE SCOOP BEFORE YOU PAINT IT??
2010 1LT A6, Hurst shifter and handle, 3pc rear spoiler, streetscene splitter, ss front end with ZL1 grill, ABL , footwell and cup holder lighting, ss cat back exhaust, Eibach lowering springs, custom engine cover, 4pk gauges, speedhut A pilliar pod and gauges, metra kit and kenwood stereo, 2014 ss hood scoop with stock rain tray, 3D Carbon fender vents, rear lighted bowtie, and ultra gauge.
Low RS is offline   Reply With Quote
Old 03-25-2014, 10:16 PM   #58
Jerry7297
Jerry7297's Avatar
Drives: 2018 2SS/ 1LE
Nope done. Sorry about that. I will upload a pic tomorrow with the Hood liner on.
Jerry7297 is offline   Reply With Quote
Old 03-25-2014, 11:18 PM   #59
Dexter9522
Drives: SS
How did you make that, just heat gun and a break or did you use the fiberglass as a mold. Did you make a template as well. Very nice work
Dexter9522 is offline   Reply With Quote
Old 03-26-2014, 06:58 AM   #60
zkdreads
zkdreads's Avatar
Drives: 2010 Camaro LS V6
prepped and ready for surgery
C-LO or Sonic
"Without Struggle there is no progress"
I am your best nightmare!
zkdreads is offline   Reply With Quote
Old 03-26-2014, 07:19 AM   #61
Jerry7297
Jerry7297's Avatar
Lexan, dremel and and a torch or heat gun.
I did have a template I had made for the fiberglass piece I made. I used that cut it out and strategically bent the lexan over some angle on one of the trailers at work. the back corners are not sealed so I put silicone on them and plastidipped over. I am very pleased with it and it was a lot easier than the fiberglass.
I can upload a template with the measurments for it if anyone would like. The only bad thing is the front 2 mounting nuts were a PITA to get on.
Old 03-26-2014, 07:21 AM   #62
Jerry7297
Jerry7297's Avatar
You dont have to leave the template on the car. If you are pleased with the placement just use a sharpie and mark it out and remove the template. Good luck man just triple check before you start cutting
Old 03-26-2014, 11:05 AM   #63
zkdreads
zkdreads's Avatar
Done!
C-LO or Sonic
Old 03-26-2014, 11:21 AM   #64
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
man i wanna do this, but i'd be shitting bricks cutting into my hood
Sold: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower, Custom Camshaft, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, 680rw 93/750rw E85, Tuned by CSP
Sold: 2010 2SS, some bolt ons, 415rwhp/400rwtq
spadz93 is offline   Reply With Quote
Old 03-26-2014, 11:25 AM   #65
zkdreads
zkdreads's Avatar
At worst u cut the hole to small. Then adjust it from there
C-LO or Sonic
Old 03-26-2014, 12:14 PM   #66
Jerry7297
Jerry7297's Avatar
Done!
Looks really good with your color combo.
Would like to see the underneath side...
Old 03-26-2014, 05:49 PM   #67
Dexter9522
Drives: SS
That would be awesome.
Old 03-26-2014, 06:07 PM   #68
Deftones
Deftones's Avatar
Drives: 2012 RS/SS LS3
Does anyone have pics of how it mounts on the 2014?
Deftones is offline   Reply With Quote
Old 03-26-2014, 06:08 PM   #69
Jerry7297
Jerry7297's Avatar
Finished product. I will work on the template layout for this. Give me a little bit will get it done soon.
Old 03-27-2014, 08:01 AM   #70
zkdreads
zkdreads's Avatar
this wont work on the 2010-2013 model. the hood is a difference size with the indentions and the hood is made for the actual scoop. i tried yesterday. one of my camaro club members have a 2014. and you would have to play with your 2010 hood and scoop to possibly come up with something to how it would fit let alone stay there. on the 2014 the insulator is different because it has fastener holes as well for the hood scoop pan too
C-LO or Sonic
