dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro DIY & HOW-TO instructions & discussions
Old 11-04-2013, 07:02 AM   #15
terry_b
terry_b's Avatar
Drives: 2014 2SS/RS 1LE
Send a message via MSN to terry_b
Well, my buddy just bought a new compressor. My plan was to enlist him and manually turn the motor over untill I can confirm the valves are closed and then erect a trash bag tent over the intake valves. I'd use a shop vac to get all the media out.
I'm kind of wary as well, but the brush seems like it may not clean quite as well. I don't know... Either way I'll post plenty of pics and such
terry_b is offline   Reply With Quote
Old 11-07-2013, 01:00 PM   #16
intensifi
Drives: '12 2LT Convertible
Originally Posted by ChadG View Post
That scares me just because I don't see how you'd ensure you get all the media back out . . . plus if your valve isn't completely closed then you're also going to get some in the cylinder.
Make sure you close the valves when doing any cleaning on a given cylinder. The instructions discuss how to manually close the valves on a given cylinder.
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
intensifi is offline   Reply With Quote
Old 11-07-2013, 09:53 PM   #17
911medic
911medic's Avatar
Drives: 2012 SIM 2LT/1970 Camaro
I think one of the benefits of using the walnut shells for blasting is that any stray fibers/materials burn up if they make it into the cylinders.
BMW uses them to clean their intake valves, albeit with a special tool that blasts and extracts the debris simultaneously, IIRC.
All bleeding stops eventually -- 2012 2LT Auto w/sunroof -- My journal thread
Roto-Fab Intake & W/W Relocate Kit -- ADM Race Scoop -- Dynomax VT Axle-Back Exhaust -- Vitesse Throttle Controller
RX Catch Can -- Drake Bowtie Delete -- JacFab Radio Face Cover -- LED Fog Lights -- LED Dome/Trunk/Plate Lights -- Gen5DIY Dash ABL -- Diode Dynamics Cupholder Lighting
Wishlist: ACS T5 Splitter -- Hood Vent Mod -- Footwell/Door Pull/Homelink Button Lighting
911medic is offline   Reply With Quote
Old 11-07-2013, 10:46 PM   #18
ChadG
ChadG's Avatar
Drives: 2010 Black Camaro LS
So the debris won't scary the pistons or cylinder walls?
Also how do you test that the valve is closed other than putting something like liquid seafoam in there to see if it puddles or not?
ChadG is offline   Reply With Quote
Old 11-08-2013, 07:30 AM   #19
911medic
911medic's Avatar
Well, I'm not a service tech or engineer, so I guess I can't say for sure, but I believe that's the idea behind the walnut shell blasting. Abrasive enough under pressure to clean, but the natural fibers/bits burn up/flow through if they get in the cylinders.
BMW's direct injection engines suffer from the same issues ours do, and their dealerships do walnut shell blasting with a special tool.
Here are a couple of links to BMW user forums where the blasting is discussed:I know Harbor Freight has some walnut shell blasting media equipment for pretty cheap, IIRC, but I don't know how good it is.
As far as checking for valve closure, I don't know of a better way than seeing if an engine-friendly liquid will pool on top of the valve. That's what I did when i cleaned my valves (see post #73).
Old 11-08-2013, 02:23 PM   #20
terry_b
terry_b's Avatar
I may be making a trip up to harbor freight tomorrow. Wow! Those are some clean valves!
So I guess it would be easiest to remove the spark plugs to rotate the motor and shut each set of valves, and then just hook up the blaster and a vacuum and go to town right?
Is there anything special about removing spark plugs?
Old 11-08-2013, 06:07 PM   #21
ChadG
ChadG's Avatar
That makes sense, but now I'm worried that if you check that the valve is closed with something like Seafoam then the walnut shells will get all wet and stick to things?
I think the spark plugs are pretty straight forward, what you said should work fine.
Old 11-08-2013, 07:32 PM   #22
terry_b
terry_b's Avatar
I'm actually thinking about doing the seafoam treatment AFTER I blast with the walnuts. That way I can just vacuum out the shells. I'm itching to dig in and see what the valves look like. Truthfully, I'll be a little disappointed if my valves are actually clean lol!
Old 11-08-2013, 08:52 PM   #23
911medic
911medic's Avatar
I was able to turn my crank bolt, slowly, without pulling plugs. But if you do pull them, just add a small dab of anti-seize to the threads before you replace them and torque them to spec and you should be fine.
Old 11-08-2013, 08:53 PM   #24
911medic
911medic's Avatar
Yeah, I suppose that may happen. Not sure what to tell you.
Old 11-09-2013, 09:19 PM   #25
terry_b
terry_b's Avatar
Well I picked up the blaster and the walnut media earlier today... ran into some complications... I think the reason the bimmer guys were having such good luck is that little tool that fits into the port. I either sprayed walnut shells everywhere or didn't get enough in one place to do any good... I may give it another shot tomorrow and see how I do... one problem is that I have some really carbonized valves. Way worse than I thought, and I was having trouble with the walnut media just sticking to everything in the port. It did seem oily still, an my intake manifold was a mess! I never cleaned it after installing the catch can, so there's a chance its just residual oil, but I don't know. More to come...
Old 11-09-2013, 09:43 PM   #26
ChadG
ChadG's Avatar
That sucks, kind of what I was afraid of - good luck getting it squared away!
Old 11-10-2013, 07:43 AM   #27
911medic
911medic's Avatar
Too bad. Might have to try the manual cleaning method, which is much more labor intensive.
Old 11-10-2013, 09:18 AM   #28
intensifi
I believe the walnut shell blast is a final treatment, not an initial one. I can see how the initial oil buildup in the air pathways/valves would be a magnet for the shells.
Sounds like an upper induction cleaning followed by a manual wipe of any remaining oil, then the shells would be a reasonable approach.
I'd like to see some "after" pics when you get a chance.
cleaning, diy, intake manifold, lfx, valves
