09-14-2021, 06:03 PM | #1 |
Track times vs. Traction control setting
I have an interesting thought regarding lap times vs driver inputs...
Context I HPDE my SS 1LE in "Track - Sport 1" and my times are mid pack for an SS on OEM tires. Q: What Track mode do you most commonly use? I know the car can be faster in more advanced modes, but I tried "Sport 2" for a lap or two... and once active handling is off my talent seems to run out. Counter-steering every other corner. "Race" is even more slippery than the previous, so no thanks there. I figure Chevy has tc, so why work without a net? No prizes in HPDE.
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8 Results: 470 hp / 447 tq |
09-14-2021, 07:57 PM | #2 |
Hi Ozzy, Good question. What do you mean by slippery? If you mean the rear end gets slippery (oversteer) through the corner then there are several things to consider. Also when in the turn does the car get slippery? Corner entry, mid or exit?
1. Tire pressure when hot. I like it to be max pressure between 35 and 37 on a hot, dry track, so starting pressure is about 30 cold. Outside air temp about 85. To get more rear grip try 1 pound more air pressure in front and 1 pound less in rear. (2 pound differential; but I don't know your typical pressures) 2. If you have PDR look at when you begin adding throttle in the corner. If it is too early and too much that will cause oversteer. When I enter a corner (from a straight) I try to balance the car's weight by 1. Let off throttle and weight shifts forward. 2. Brake which shifts more weight forward. 3. Add steering into corner while trail braking. This keeps weight on the front wheels while shifting weight to the outside wheels (front more than back). 4. Continue trail braking while you continue to turn toward the apex. 5. When at the apex begin to add throttle and then lift off brake. This will shift the weight more to the rear (mostly outside) 6. As you continue to add throttle you should be decreasing your steering angle (see PDR) To answer your question, I drive with car in Track setting and Race in the PTM. I will also use Track and no PTM. Go to track setting and then hold the esc/stabilitrak button down for about 10 seconds until both lights are lit on instrument panel. I find the rear gets light when my right foot is too heavy, too fast. At an HPDE event, ask a driver coach to ride with you and give some advice. You could also put a PDR video here and the forum can comment. Best of luck. JJ |
09-14-2021, 10:25 PM | #3 |
Drives: '94 Z28+ '15 Z/28 Join Date: Jun 2009
Fill the tank. It will help keep the rear planted.
1973 Mach 1, 351C cruiser
'15 Z/28 Red Hot, A/C 1980 Z28- resto-mod project 1979 Y84 Trans Am 1986 IROC-Z |
09-14-2021, 10:50 PM | #4 |
Drives: 2018 Camaro 1SS 1LE Join Date: Jun 2021
Race gives you better turn in, and more rotation. It also allows control with throttle. I personally like the sideslip. PTM Track is definitely more fun. I can see how Sport2 would be quicker at times though.
09-15-2021, 05:36 AM | #5 |
Drives: 2021 1SS 1LE Join Date: Nov 2020
I've run back to back with TC off and then with the PTM in Race mode and went quicker in Race mode. I did the test with the F1 SC3 220tr tires and not an R compound and it will be interesting to see if the R compound with TC off is better. That said, I was impressed with the settings the engineers created and it works....
See post #44 https://www.camaro6.com/forums/showt...=594295&page=4 |
09-15-2021, 07:51 AM | #6 | ||
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Norm
'19 WRX 6M (the family sedan . . . seriously) |
09-15-2021, 07:58 AM | #7 |
Well phrased sir!
09-15-2021, 03:32 PM | #8 | |
Norm
09-15-2021, 09:52 PM | #9 |
Drives: audi R8; ss 1le; F250 Join Date: Mar 2021
A GM Camaro engineer told me that they calibrated Track/Race for the Hero lap ( fastest lap with tires NON-overheated tires).
that said, he said once the rear tires get "hot" (as measured by amount of slip and the temp given by the TPMS sensor) he said the car is actually faster with Track/Sport 2 because that is calibrated for ideal slip to produce maximum forward thrust with "hot" tires. he went on to say that once the tires get hot and start slipping, the slip allowed with Track/Race actually provides less forward force, than the with the slip allowed with Track/Sport 2. at the tail end of the conversation, he said for this reason it's imperative to use GM TPMS or at least TPMS that will communicate both PSI AND temp, because temp figures into the slip allowed. crazy the amount of computer control built into the car. |
09-16-2021, 01:08 AM | #10 |
Makis
Drives: 2020 Red Hot ZL1 A10 Join Date: Apr 2019
This is a great thread with great info on the different driving/PTM modes:
https://www.camaro6.com/forums/showthread.php?t=496996
Mosaic black 2018 Camaro 2SS A8 (sold) |
09-16-2021, 08:34 AM | #11 | ||
Norm
09-16-2021, 12:57 PM | #12 | |
Drives: 2017 1SS 1LE Join Date: Jun 2016
Yes, exactly this. If you want to get the most out of PTM, you need all the stock tires/wheels/brakes/suspension etc. on the car to get the most optimized control. All of the PTM/eLSD/suspension calibrations are built assuming the specific slip characteristics, brake response times, and overall vehicle dynamics of the OE package so any change to that would likely make it less than optimal. Not to say hardware changes would guarantee the car being bad or undriveable or anything like that because it is closed loop control, just the targets that are being controlled to and some of the pre-emptive stuff won't be as optimized anymore.
2017 SS 1LE.
09-16-2021, 02:41 PM | #13 | |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
09-16-2021, 06:07 PM | #14 | |
Interesting read about progressing tire temperatures... cool! I agree, once the SC3 gets hot, the tail does get "happier".
