08-30-2021, 11:55 AM | #1 |
Drives: 2019 ZL1 Join Date: Mar 2019
If anyones interested, FI Interchiller installed soon.
Getting a FI interchiller installed on my ZL1 soon as this summer was brutal in NJ with heat/humidity etc. So if anyone's considering one or wants to lower their IAT's for more power ill be sure to post my review once its done. From what i've seen they completely resolve heat soak, and even the 2650's still suffer, albeit just not as bad.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
08-30-2021, 12:10 PM | #2 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
Yes, they work very well except for road racing. I had the FI Interchiller Stage 1 kit on my 892whp Hellcat. This was on a 93F day.
08-30-2021, 04:28 PM | #3 |
Drives: CMaro Join Date: Sep 2018
Bro I been debating on getting one for the 2650r I ordered . What’s are you’re iat right now driving around town . And after a wot pull .
08-30-2021, 04:43 PM | #4 |
Petro-sexual
Please share
08-30-2021, 06:47 PM | #5 | |
All depends on what ambient temps are. Usually my MAT temps are 35-40F above ambient temps. On a 95F day MAT temps can be 130-140F just driving around. A pull it would actually go down a bit before going back up as your getting more air over the exchanger. Stopping in traffic on a hot day like above, mat temps i've seen 165F +. Goes does soon as you start moving though. Make sure your logging correct pids also. IAT 1 = Air entering the SC (should be ambient or within a few degrees of) IAT 2 = Some calculated value (not used on gen V) IAT 3 = Manifold Air Temp (Air after SC entering cylinders, whats used when timing is pulled, this is what you want to log/record). The IC should keep MAT temps below ambient, unless your in a pull 1/4 mile etc. But temps would return quick. I would need to be driving on a 50F day highway speeds to see MAT temps of 90F. When my MAT temps are 90F i can feel a SOTP difference and my 60-130 times reflect that. So if the IC will keep temps well below ambient you should be making full power and then some at all times.
08-30-2021, 07:44 PM | #6 | |
08-30-2021, 08:12 PM | #7 | |
I just need to decide if I want a trunk tank or just a bigger reservoir like the cordes or something. This car is more street then drag so not sure if it’s justified. I’m sure though addding 5-6 gallons to the system you could probably go through a full 1/4 mile pull and barely move temps with a trunk tank.
08-30-2021, 08:49 PM | #8 |
I’m looking at this guy.
https://cordesperformanceracing.com/...mper-ice-tank/ I don’t want to mess with trunk tanks, lines run via body etc. Something like this should work nicely to add a couple gallons of capacity.
08-30-2021, 11:23 PM | #9 | |
08-31-2021, 05:27 AM | #10 | |
Drives: 2017 Camaro SS, 2011 Corvette GS Join Date: Feb 2019
I added a CPR tank to my E-force C6 Grand Sport. Tank is excellent quality, fit perfect and added about 2-gallons of capacity. Really helps with temps and you can pack it with ice to get IC temp down rapidly. |
08-31-2021, 06:03 AM | #11 | |
08-31-2021, 09:24 AM | #12 | |
This will be just an expansion to go along with interchiller. I won’t need ice. Apparently it takes up space where the IC goes though so I’m looking at the fender mount one now.
08-31-2021, 10:02 AM | #13 |
I certainly like the idea for drags
'20 ZL1 1LE A10,
09-05-2021, 11:44 PM | #14 |
Any updates ?
