08-11-2021, 02:22 PM | #29 |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
I had a Chevy dealership check for over revs as part of my pre purchase inspection since the car was pre-owned and they didn't mention a limit to how far back the check goes. I assume it goes all of the way back to when the car was new...it wouldn't take up much storage space.
08-12-2021, 10:01 AM | #30 |
Drives: 2019 Camaro SS 1LE Join Date: Sep 2020
yeah they didn't specifically tell me how far back they looked for overrevs but I assume it's a binary that once it gets overreved it stores that forever. So might make sense to have a dealer check it if you're buying used and will be tracking the car.
-Jon
2019 SS 1LE doing work as a SCCA S2 Time Trials car and FS autocross car |
08-12-2021, 10:15 AM | #31 |
The dealership was able to confirm that the car's warranty was valid from the overrev check and visual inspection (and probably also from checking notes/service history in their system). I would highly recommend having this checked with passing being a condition of purchase for anyone buying a used manual car.
08-12-2021, 03:14 PM | #32 | |
Drives: 2018 2SS 1LE Join Date: Feb 2018
Wonder if the motor blew 10-15K miles later if they would deny coverage just for that.
2018 1LE
2nd 6th gen SPL Toe Arms/Brembo HTC64t/Corsa NPP/Tremec MTF Fluid |
09-06-2021, 10:00 PM | #33 | |
Drives: audi R8; ss 1le; F250 Join Date: Mar 2021
Sadly, my motor let go this past weekend at VIR, so I'll start this process with the dealer this week. ('21 SS 1LE with 8K on it). |
09-23-2021, 09:24 PM | #34 | |
went to another dealer, talked with the service director who said, "if you've not changed the ECU, it's covered." dropped the car there, 2 hours later they had cleared the ECU with GM and a new motor was on order. Amazing the variability within the same state. BTW - When I left I asked if there was any published "required" break in for the motor and got blank stares. I know the manual says 1200 miles for a completely new car. anyone see any print specifying break in for a new motor? |
09-24-2021, 04:41 AM | #35 |
I now have 2 friends with SS 1LEs that had motors let go at COTA. One was a 17 and the other a 19. Replaced with no issues.
09-24-2021, 06:01 AM | #36 | |
Drives: 2018 NFG 2SS 1LE! Join Date: Jul 2018
09-24-2021, 06:17 AM | #37 | |
Drives: 2021 ZL1 1LE Join Date: Aug 2010
09-24-2021, 10:31 AM | #38 | |
Also I'm fairly certain it's 1500 miles. And the first 500 miles are super restrictive, no cruise control or over 4000 rpm.
-Jon
09-24-2021, 11:38 AM | #39 | |
Crazy that towing your blown motor car to one dealer can result in "voided warranty" when this is explicitly covered
2018 1LE
10-04-2021, 09:37 AM | #40 |
Drives: 2019 SS 1LE Join Date: Jun 2018
well, I blew my motor at Road America last year right at the top of the hill on the front straight shifting to 5th. And just did it again this weekend! Exact same spot. Wasn't a missed shift or over rev, just let go at the top of the RPM range in 4th. Last year the dealership in WI said it was a piston failure... Behaved exactly the same this year. Towed it to the same dealership.
10-04-2021, 02:42 PM | #41 | |
Drives: 2023 Chevrolet Camaro 2SS 1LE Join Date: Jan 2020
10-04-2021, 08:17 PM | #42 |
I wonder the same. Obviously had plenty of fresh oil, checked the level before running that session as well. Oil pressure was good until it wasn’t in PiToolbox.
