07-28-2017, 08:24 PM | #1 |
Drives: 2010 2SS/RS L99 IBM silver stipes Join Date: Dec 2015
How do you measure Hz?
I need to tension my SC'er belt. And I am suppose to measure it in Hz. How do I go about doing this?
2010 Imperial Blue w/ Silver stripes 2SS/RS L99
Mods = Not enough.... |
07-28-2017, 08:31 PM | #2 |
Drives: Camaro Join Date: Mar 2013
07-28-2017, 08:32 PM | #3 |
07-28-2017, 10:03 PM | #4 |
I don't see how that helps. No where does it say anything about tensioning your belt to a certain Hz. Maybe if I needed a new belt it might help me pick one....
07-28-2017, 11:08 PM | #5 | |
Drives: 2010 Camaro (M6) 1000+ HP SBE Join Date: Jun 2011
Surely there is some sort of conversion from Hz to ft lbs or some other measurement that makes more sense? I am rooting for you C701LE . . . Lets get that thing on the road!!
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam Brodix BP BR 3 Heads Kooks LT Headers and full 3" exhaust Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears McLeod RXT Twin HD Clutch & Upgraded Slave RPM Level VII TR6060 BMR Drag Suspension Package w/Strange shocks Carlyle 15" and M/T ET Street R radials 10.1 @ 143 mph 1/4 mile |
07-29-2017, 07:41 AM | #6 |
Started#gottalovethatblue
Am I missing something, but Hz is referring to frequency right? Is there a resonate frequency of the belt that is being referred to here?
07-29-2017, 08:01 AM | #7 |
There is always more than one way to skin a cat. Why not just use the right belt?
07-29-2017, 08:47 AM | #8 | |
There is a minimum and maximum tension range. We like to select a belt that is very close to the Max tension range IDLING, so as the belt stretch it will take up for it.
www.jannettyracing.com
07-29-2017, 09:22 AM | #9 | |
Drives: Miss Con Ception Join Date: Aug 2016
Cords in the belts run radially and when they fail the belt breaks. Tires can change in diameter because the belts are installed diagonally to improve flexibility and provide a smoother ride and better contact with roads. Belts can wear on the inside if, and only if, they slip, but the OD never changes.
2011 1SS/RS LS3 CGM
07-29-2017, 09:32 AM | #10 | ||
The do act just like rubber bands. The reason we need a spring loaded tensioner, the more load you put on the belt the longer it gets and the tensioner has to take up that extra length. Also the reason why Manual tensioner don't work and always experience belt slip. See this video,
07-29-2017, 11:44 AM | #11 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
Damn, like telling Einstein relativity is a myth......
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
07-29-2017, 01:54 PM | #12 |
Well guys, thanks for the replies. It is the correct belt that came with the kit. There is no "spring" tensioner. It is an allen bolt set up, and the directions tell you it is measured in Hz (frequency). I downloaded the Gates app, but that is all it says to do. I don't know if I have to use my phone in the right spot when it is running. Or, just pull up on that spot and let it "boing". I asked on the Kraftwerks 5th Gen facebook page. And all I got was shit for not knowing what to do......
07-29-2017, 02:24 PM | #13 |
Belt tensioner
Here it is
07-30-2017, 08:51 AM | #14 | |
Drives: 2014 2SS blue Join Date: Jun 2016
To the OP, if they want you to tension the belt by adjusting the frequency, I would guess you'll need a strobe light with adjustable frequency to identify the belt slap frequency.
