07-30-2022, 01:53 PM | #1 |
Drives: 2017 Camaro 2LT RS Join Date: Apr 2019
Caliper bolt bracket
Hi I just purchased a new rotor for my car and now I am having a hard time taking of the bolt bracket for the caliper, I only used breaker bar and it wont bulge. Haven't tried using an impact wrench yet but I will do once I get it. Are those bolt torque to yield and if yes what are the specifications. Do I replace the bolt too after I take it off or I can reuse it? If yes to replacing it, does anybody know the part number for the rear and front bolt?
08-05-2022, 11:33 AM | #2 |
I've never heard any warning about not reusing bolts for these locations.
Last time I removed a caliper carrier to replace rotors (not on a Camaro) I used my 18" breaker bar with an impact socket. I use the top half of the handle for my floor jack as an extension to give me about a 36" lever. The floor jack handle is basically a steel tube about 1.25" diameter. ID is just big enough to slide over my breaker bar. With this much torque I would strongly recommend an impact socket over a conventional one. |
08-05-2022, 02:16 PM | #3 |
They are reusable; see the relevant fastener torque specs below.
08-05-2022, 03:16 PM | #4 | |
The front bolts broke loose with an 18” long, 1/2” drive Titan Tool ratcheting breaker bar.
08-31-2022, 04:28 PM | #5 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
Not sure what kind of thread locker they use at the factory but they are tight, I had to use a large breaker bar to get mine busted loose also. I used blue locker putting back together.
08-31-2022, 04:39 PM | #6 |
goodluck i had to use a breaker bar and jack up the car higher so i could get some leverage last time i had my rotors replaced i just took them to my buddy shop haha
08-31-2022, 04:58 PM | #7 | |
https://www.amazon.com/Titan-Tools-1.../dp/B000QJEF56
