09-06-2022, 11:36 AM | #29 |
Drives: 2017 RS CAMARO V6 Join Date: Jun 2018
The exhaust is not connected obviously. I am working on the charge pipe and intercooling which goes all the way down the passenger side of the car. I am going to use an A2W intercooler to save space and avoid cutting up my front bumper. This is the same twinscroll turbo I mentioned in the early post. I also have an old Turbowerx EXA pump, two 35MM wastegates, dual mufflers, air filter and a good tune that will need to be completed. I will keep posting pics of the progress every weekend. The nice thing about this setup is that you can keep driving the car NA until everything is finally done so there is really no downtime.
09-06-2022, 01:48 PM | #30 | |
Drives: 2020 LT1 M6 Join Date: Jan 2016
09-06-2022, 02:41 PM | #31 | |
BTW, What vehicle did you work on that had a custom rearmount? |
09-06-2022, 05:29 PM | #32 | |
09-06-2022, 07:58 PM | #33 | |
09-06-2022, 09:23 PM | #34 | |
09-07-2022, 08:46 AM | #35 | |
09-07-2022, 09:29 AM | #36 | |
In hindsight, a blower would have been much more enjoyable and trouble free, but you live and you learn. |
09-07-2022, 12:31 PM | #37 | |
09-07-2022, 03:32 PM | #38 |
Yes sir, it is definitely a niche novelty. Only ever heard of a handful of people that had long term trouble free success. They were all full custom set ups (fabricated from scratch). Post up a dyno if you can get it tuned, would be nice to see a gen6 v6 that puts down good torque, hehe.
09-07-2022, 06:57 PM | #39 | |
12-28-2022, 02:20 PM | #40 |
Its been a while but I have not forgotten about this post. I finally found a 2.5" air to water intercooler that I could easily fit in the engine bay with little modifications. Its held by two brackets that I welded together. I relocated the radiator upper hoses as well as the bypass hose and the PCV hoses to give the intercooler room to fit.
The intake on temporarily for mock up purposes. It is comprised of two 3 inch aluminum intake pieces (one BOV mount and one MAF mount) and large silicone connectors. The BOV is connected by an old radiator hose which is attached to the bung. I plan on using 3 aluminum parts with hose clamps and shortened silicone hose instead of all the large silicone parts. In my past experience those cheap 90 degree silicone connectors have a bad habit of collapsing and expanding ALOT when you go from boost to vacuum. |
12-28-2022, 02:33 PM | #41 |
Since this is a remote style system I wanted the shortest path to the intake for the charge pipe and intercooling so I went with A2W. HOWEVER... the bone stock OEM front mount intercooler for the 2.0 turbo Camaro would have also been a perfect solution to this project since it mounts between the radiator and condenser. It receives secondary air after the condenser but its also supported by the puller fan behind the radiator. They go for around $125 new. There are two aftermarket brands on the market offered by Mishimoto ($450)and REV9 ($350) which both claim to support between 450 - 600HP. There would be no major modifications to the vehicle since they are direct fit. Plenty of PROS and CONS of both types.
01-02-2023, 09:34 PM | #42 |
Drives: 2020 3LT Camaro 3.6L 1LE Join Date: Feb 2020
Back in the 1990's, didn't someone make a rear turbo kit for the Gen 3 and 4 Camaros/Tran Ams? Would it be easier to modify that kit, if it still exists? Just wondering.
