02-26-2021, 09:50 PM | #29 |
Somewhere in the Kalahari
Drives: 2021/18 (de-fresh) 3LT RS Join Date: Dec 2017
I took my 2021 V6 into my local dealer earlier this month at just over 500 miles for the freebie oil change. Other than what I took to be a "customer service" inquiry asking if I knew what my oil life indicator said and if I was sure I wanted my oil changed, no issues.
02-26-2021, 10:31 PM | #30 |
Drives: 2020 2SS Vert/M6/F250 SD Join Date: Jan 2021
I do my own oil changes on my trucks and bikes. I just got the Camaro and I have jacked it up using the hockey pucks on the jacks. Ive swapped the wheels and tires to a winter set. Ill be doing an oil change soon as I have almost 500 miles. I have 2 jacks in the shop at work and I can lift from 2 points. I have not established where Im going to put jack stands. It is crowded and fragile looking under there. A lot easier crawling right under the F-250 on a cardboard sheet.
As I understand it the 0w 40 is actually the recommendation for track use? The manual says to use the 0w but if not available 5w-30 dexos 1 full synth may be used for street use. The car is about to become my wifes DD. Nothing even close to track use. I use Valvoline 5 qt jugs 5w-30 from Amazon. $69.99 for a case of 3 jugs. Im going to keep using that across the board. Its Dexos approved. It says Gen-2 but in the green square before the wording it has a 1. Not sure what all that is. I usually do 5000 mile changes on the other vehicles. Ill do at least 2 oil changes in the first 5,000 miles for break in as well as the tranny and rear. Ive been using Redline in the Harley and their gear oil definitely made my trans shift smoother. Im thinking Ill use that in the trans and rear. I think I will ultimately keep with the 5,000 mile intervals. It makes it easy for the wife to know for sure when shes due. If your talking garage queen doing very low miles I would get the best lubes available and do a yearly change of everything. I do the boat motor oil at the end of the season so the engines dont sit all winter with contaminants in the oil. Sludge settling tightly never to be cleaned out again. Maybe acids... Same with the Harleys. End of season oil change before storage. I think for the most part normal maint. is part of the ownership experience. I enjoy working on my vehicles. Safety first... The guy with the quick jack has the deal there. Theres also a company making nice rubber ramps that are a low slope so the air dam doesnt hit before the tires. Im actually looking forward to getting the Camaro up on 4 jack stands and changing all the fluids. Just dont have it all figured out yet.
02-26-2021, 11:02 PM | #31 | |
2020 Shadow Gray 2SS
You bought a $40k+ car, roughly $100 for an oil change shouldn't be an issue...
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... |
02-27-2021, 12:07 AM | #32 | |
If the recommended oil was something I believed was of lower quality I would never use that. My point is any high quality full synth changed regularly is going to be a good choice. I have never used the recommended Harley oil in any of my bikes going back to the 70's because I thought it was crap. Might be OK now but it was definitely crap in the 70s and there were a dozen better choices. I think change intervals and filter quality have more impact than brand of oil within the proper spec. Ive been responsible for fleet maint on heavy trucks and equipment for nearly 50 years. Light commercial trucks, boats, motorcycles of my own and others. I shifted to synthetics in 1988 when a new Peterbilt I bought with Rockwell rears had a recommended break in fluid change. The rears came with 500,000 mile warrantees. If you changed to full synth gear lube after break in, they upped the warrantee to 750,000 miles with zero cost. Ive used full synth in everything since with the exception of the 78 Harley Shovelhead because of its age. It already seeps a bit of oil and its been widely claimed that if you put full synth in them they will start to leak profusely. The oil in that bike has been changed at 1,000 mile intervals for 42 years. Still runs great. I actually dont believe theres appreciable difference between the top tier oils. They are all outstanding. If you wanted to make a case that the 0w-40 is better because of the range over 5w-30 I agree with you. Ive also been assure the NAPA oils are really Valvoline. But I also heard that although thats true they may not be paying for the full additive package and so thats a problem for me. Castrol shows a 0w40 but its not DEXOS approved that I can see on the label. Every time Ive searched the Mobil 1 its been out of stock. If I cant buy it its not a consideration. I have cases of Valvoline. 5w-30. Its DEXOS approved. And readily available.
02-27-2021, 12:34 AM | #33 | |
$63.90 for oil and probably $8.00 for a filter...
02-27-2021, 07:23 AM | #34 | |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
02-27-2021, 08:35 AM | #35 |
Drives: 21 Camaro RS manual v6.Tyota Tacoma Join Date: Feb 2021
Y'all are making me glad I got a v6.$30 oil change 5-30 always in stock.Runs great on 87 oct. 24.6 mpg by computer.Same rear diff as V8.Can rotate tires, less ins. Cost.All I have to do to be happy is never drive or race a V8.
02-27-2021, 12:13 PM | #36 |
Not sure we helped len get the free early oil change he wanted.
If he gets particular about which "free" oil they are using, I doubt it will up their enthusiasm. Not saying they should use the wrong oil, but he seems to have an uphill battle already. |
02-27-2021, 12:58 PM | #37 | |
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
02-27-2021, 04:39 PM | #38 |
376 cubic inches of fun
OK so your dealer is an idiot for not agreeing to change your oil per your request.
But still, the "break-in" oil change is an outdated idea, so don't worry be happy. However, if you can't stop worrying, get some ramps and do it yourself. You won't have to worry about lift points or the dealer. But do me a favor: don't listen to people who tell you the car has to be level to get all the oil out. That oil plug is at the back of the of pan for a reason. And do get a torque wrench and torque the plug to 215 in.lbs. because you sound like an OCD person who would otherwise over tighten. Over tightening is bad news. |
02-27-2021, 04:50 PM | #39 |
Drives: 2016 2SS Convertible Join Date: Dec 2019
I'd be curious to know the "computer's" algorithm for % of life.
I had mine changed shortly before putting her away for the winter, and she's been in a storage unit (unheated) since mid Oct. I go start her up about every 2-3 weeks and run for 30 minutes. Just happened to be scrolling thru the DIC today and its saying I'm at 64% life. WTF????
Hyper Blue/Ash Gray A8 Magnetic Ride Control Dual Mode Exhaust 2019+ version Split Spoke Silver Wheels Navigation Silver Rally Stripes |
02-27-2021, 06:56 PM | #40 |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
Print this off and bring it in: https://www.google.com/url?sa=t&sour..._guide-min.pdf
"Please note: It is recommended that the first oil change occur at 500 miles." Also using a shop's alignment rack for an oil change may scrape your front splitter if you have one. I have to bring two lengths of a few feet of 2x12 board with me to get onto local Hunter alignment racks without scraping. Also make sure you get the recommended dexos2 Mobil1 ESP 0W-40 ESP for your free oil changes if you plan to track the car. It is unlikely that any other shops will keep it in stock besides GM dealerships. Otherwise dexos 5w-30 is also acceptable to maintain powertrain warranty if not tracking the car. |
02-27-2021, 06:56 PM | #41 | |
Hot Camaro
Some manufacturers put additives in the oil from the factory (these motors do NOT have additives in the oil) and you need to run the engine for a minimum number of miles before the first change. This was the case with an Acura I bought new about 15 years ago. The people that designed the engine also designed the break-in process to go with it. |
02-27-2021, 07:12 PM | #42 | |
My Camaro actually has a few metallic specks on the dipstick and that's why I changed the oil early.
Current:
