02-27-2022, 02:37 PM | #1 |
Red Bull
Drives: 2017 Chevy ZL1 Join Date: Dec 2020
Timing Chain Tensioner
Is it true that the ZL 1 has a problem with the spring coming off the timing chain tensioner? I am about to do my cam install and was thinking about using the LME replacement tensioner? Anyone else using one? Is it really an issue? I am changing the oil pump to the Katech unit. Any suggestions please share
02-27-2022, 02:58 PM | #2 |
Drives: 2013 ctsv Join Date: Nov 2021
Yes, there is a tsb from gm in regards to it on oil pump failed cars. If you’re in there it would be wise to replace.
02-27-2022, 03:08 PM | #3 |
Drives: ZL1/1LE parts added Join Date: May 2018
Location: Somewhere around Texas pines tress and smooth asphalt
I say while you in there do it ! Are you using LS3 timing sprocket?, which requires LS3 cam center bolt? I have been researching everything, the only reason I'm holding off is my warranty. But Im doing LS3 sprocket, katech oil pump, LME timing cover or Katech, and the tensioner from LME. It's good to sit back and watch what works and what doesn't. The factory timing that people use to lockout is not a viable solution. = Erratic tuning and timing up top with a cam from what I have read, maybe people out here have no problem with the lockout, but why risk it.
02-27-2022, 09:07 PM | #4 |
Red Bull
Thanks for the info guys. I did hear people saying that the LME makes a little more chain noise??
02-28-2022, 05:45 AM | #5 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
If you don't want to use the LME part, at least get the upgraded GM part from the 2019+ models.
02-28-2022, 10:51 PM | #6 |
Red Bull
Do you have that part number? Or how can I get that?
02-28-2022, 11:17 PM | #7 | |
Drives: 18 ZL1-1LE, 10 JKU Join Date: Jul 2018
Can you elaborate more on the erratic tuning or have any links i could read? My car throws a P0011 timing over advanced code from time to time and while it runs great, it kinda makes me curious |
