05-10-2021, 10:46 AM | #463 |
Drives: 2017 Chevy Camaro 1SS Join Date: Oct 2019
I still run into the issue where I slowly accelerate and the A8 decides to hang and almost jolt into second gear.
05-10-2021, 01:42 PM | #464 | |
Drives: 2023 2SS Convertible Join Date: May 2009
-Geoff
05-10-2021, 02:25 PM | #465 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
that has nothing to do with the fluid issue.
That's just fun tcm/ecu tuning. similar to the car not down-shifting in certain low speed scenarios until you provide much more accelerator pedal travel than you would think necessary ...which while triggering a shift, will result in a pronounced change of speed instead of a nice gradual one. the a8 (both varieties) have had such low speed quirks since the 6th gen was brand new. |
05-10-2021, 02:56 PM | #466 | |
05-10-2021, 03:22 PM | #467 | |
(What I mean by "near perfect" is all except for the paddle shift lag that doesn't seem to be fixable... although I do have a dirty trick in mind that I'll try once I have a little extra time).
05-10-2021, 03:59 PM | #468 |
Drives: 2017 Camaro SS, 2011 Corvette GS Join Date: Feb 2019
05-10-2021, 04:38 PM | #469 | |
that sounds like perhaps something entirely different. At a stop (for more than a few moments) the car should shift down to 1st and flooring it should result in immediate acceleration. Any deviation from that makes me think that something else is going on unrelated to the things described above. Sometimes if you stop for only a moment though, (or dont fully stop) you'll still be in 2nd and it will take a moment for the car to downshift for the few seconds it'll stay in 1st and then move back up thru the gears. That kind sometimes yield funky acceleration sensation |
05-11-2021, 07:31 AM | #470 | |
I used the think the paddle shifter was a complete waste until I drove out to Colorado a few years back. I can't imagine driving in the mountains without it. I never could really understand the paddle for performance driving though. -Geoff
05-11-2021, 11:48 AM | #471 | |
Doesn’t always happen, but during the times it does it almost feels like I’m about to blow the tranny off the line lmao. It’s so violent that it takes me off the gas for a brief second. It’s the same sensation you get when you drive stick and you let go of the clutch too quick and the car jolts. Last edited by AutoPenalti; 05-11-2021 at 01:29 PM. |
05-11-2021, 12:59 PM | #472 | |
Long hauler
05-11-2021, 02:24 PM | #473 |
05-11-2021, 07:06 PM | #474 |
Long hauler
My RPM’s rise before shifts in lower gears but that’s not dependent on the trans fluid temp. It was fixed with a tune but the temp jumped like 20-30° these past weeks and it’s returned so I was hoping a retune would fix that
05-11-2021, 09:08 PM | #475 |
Drives: 2018 Camaro SS vert Join Date: Oct 2020
My 2018 with 7500 miles is at the dealer right now for this, the TSB describes it perfectly
"Some customers may comment that their vehicle is experiencing a shake and/or shudder during light throttle acceleration between 25 and 80 mph (40 and 128 km/h) steady state driving when transmission is not actively shifting gears. ⇒ The condition may be described as if they are driving over rumble strips or a concrete road surface with rough expansion joints." This is not the slight change you feel when it goes from V4 back to V8 mode, it really feels like you are driving over a rumble strip on the highway. As soon as I felt it starting I made an appointment to get it taken care of under warranty.
05-12-2021, 08:51 AM | #476 |
Then sounds like mine really just needs a TCM tune, my car is bone stock other than the Borla ATAK I added a year ago and my BtB warranty expired but not my powertrain so I don't know if I should just wait until that expires as well... the whole jolt/jerk when shifting to 2nd just gets really annoying after a while.
