11-30-2019, 08:27 PM | #1 |
Drives: 2018 Camaro 2SS 1LE - Hyper Blue Join Date: Aug 2018
Trans Fluid
Anyone use a different trans fluid for street/track driving in their 1LE? Want to get rid of some notchy feelings, but don't want to increase temp on the track. Links and experience would be great!
11-30-2019, 09:44 PM | #2 |
Drives: 2017 Camaro 1LE Hyper Blue Join Date: Apr 2017
Are you sure the notchy feeling isn't just our short throw shifter?
Or a matter of adjustment? |
11-30-2019, 10:03 PM | #3 |
Drives: 2017 1SS 1LE...makes me go YeeeHaw! Join Date: Mar 2012
A lot of people found changing to Royal Purple, Amsoil or Redline has help.
I changed to Amsoil and noticed a small difference, but when the car is cold second gear gets a double clutch. However, once warm all is smooth...YMMV! Do a search on Trans Oil to read what others have done and are experiencing.
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late! |
12-01-2019, 07:20 AM | #4 |
Drives: 2018 2SS 1LE Black Join Date: Aug 2018
Not a Royal Purple fan-boy but I ended up going with they're Synchromax and it did make a substantial difference in the cold weather, stock it was almost impossible at times to shift into second and sometimes it would kick back out. It's still a bit clunky when cold as are most manuals but is much improved over the factory fill. Redline D and Amsoil seem to get mentioned a lot also.
I ordered the six quart box because it was almost the same price to buy four quarts, that and a buffer incase I did something stupid like spilling some. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Pump - https://www.amazon.com/Plews-55001-L...48X7DP2K8PHMTC Last edited by Warrior102; 12-08-2019 at 07:35 PM. |
12-01-2019, 09:57 AM | #5 |
Yah those are the 3 I have heard of. Any experience with track and daily use with them?
12-03-2019, 08:16 AM | #6 |
Any experience on daily/track use with this Redline D4 ATF ? I feel like it will be better than stock, but I dont want to have issues when tracking the car.
https://www.amazon.com/Red-Line-Auto...s%2C154&sr=8-3 |
12-03-2019, 08:32 AM | #7 |
Drives: 2018 ZL1 1LE Join Date: May 2019
Probably doesnt help, but I still run OEM AC Delco, I havent had issue with it yet, Ill probably start experimenting with new fluids next interval.
Subscribe to my Youtube channel!
https://www.youtube.com/c/Junkyardspecial Will buy your GoodYear Supercar 3R Take offs! |
12-03-2019, 11:38 AM | #8 | |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
12-03-2019, 11:14 PM | #9 | |
12-07-2019, 07:42 PM | #10 |
It's definitely an improvement on the street. On track, I didn't seem to really notice anything. It just seems the friction package and lower temperature viscosity properties allowed the transmission to shift a bit smoother than the factory fluid.
12-08-2019, 12:35 PM | #11 | |
Drives: 17' 1SS 1LE GBA-Black Join Date: Mar 2017
The BG stuff is also on my shortlist, next to RL D4 and RP, when I reach the time to change trans fluid:
https://www.bgprod.com/catalog/drive...ncro-shift-ii/ Here is a Review Video: |
12-08-2019, 12:56 PM | #12 |
Drives: 2019 ZL-1 Join Date: Feb 2009
I hate Royal Purple and Amsoil but may have to make a change. My M6 ground a gear into second the other morning and I really cringed. It was 52 here in Naples, FL....
2012 Yukon XL Denali w/ 6.2 AWD |
12-08-2019, 02:52 PM | #13 | |
2017 Camaro SS 1LE
Pray ported TB/IM TSP 1 7/8 Long tube headers w catted con pipes Taylor plug wires Mishimoto oil cooler Elite X2 catch can |
12-08-2019, 05:14 PM | #14 |
There is also the crush washer mod for the ball detent, lots of info out there as the same transmission is used in Corvettes, Dodge and Mustangs. Look up "Anti-Venom 6 Speed Shifter Modification". Cost is two Dorman crush washers and fifteen minutes of your time, some like one some two. It basically takes some of the pressure off the shift rod by the spring loaded ball detent, the 1LE's short shifter doesn't have as much leverage so you feel more resistance.
https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1 Last edited by Warrior102; 12-08-2019 at 06:05 PM. |
