10-01-2017, 05:37 AM | #1 |
Drives: 2016 1SS D1SC Methfed Lowered Wrapd Join Date: Apr 2016
DSX Aux Fuel System
Would this installed in a 6gen with lt1 SS high side/low side/intank allow for full time E85?
https://www.dedicatedmotorsports.com...-p/lsfscam.htm Pretty tempted to give it a shot before pulling the motor out for internals. I know sledge just got one of these but he was already boost cammed i believe.
//2016 1SS M6 D1SC Upgraded IC 4.25 Pulley//
// Alky Control Meth Kit running 100% methanol // (purchased from JDP, installed by True Bliss Customs, tuned by NewEraPerformance in Augora Hills) // 3M/Gotch Design Sponsored Gloss Deep Space Colorshift Wrap // |
10-01-2017, 07:26 AM | #2 |
Drives: Camaro 17 SS Join Date: Jan 2017
I have this kit. It is well put together and of high quality. Here are a couple key notes I wish I would have done before or during my install:
- Make sure that you have little gas left in the tank or you will have more to drain. - Also don't forget to order the tap also it is not included in the kit. - Plus the sealer needs to setup over night so don't plan on driving it too soon. If you are like me - The kit no longer uses the Warlbro pump. It has a Bosch 044. Will this setup get you to "full E85"? I will say YES* I have a cam with 32% lobe and all lt4 fuel system and I have run as high as 77% ethanol (highest I've ever gotten out of a pump) and the lowest fuel pressure I saw ( after changing info in the tune) was 65psi. Which is great. |
10-01-2017, 01:10 PM | #3 | |
10-01-2017, 02:19 PM | #4 |
Drives: ex-wife's car Join Date: Jan 2011
10-01-2017, 02:35 PM | #5 |
Well I guess it all depends on your car and tune. What is you injector duty cycle? What is your AFR durring PE? Both questions at what ethanol content? What is your "no less that" fuel pressure both high and low side? What is your desired ethanol content? You have to properly diagnose the fuel system before you can decide if this kit will solve any problems. I know that mey answer does not answer your question directly but I dont want you to waste oney that you do not have to.
10-01-2017, 02:37 PM | #6 | |
10-01-2017, 02:46 PM | #7 | |
10-01-2017, 02:59 PM | #8 | |
10-01-2017, 03:09 PM | #9 |
Looks like I have to sit down with my tuner and look at logs... Thanks for the replies gents
10-01-2017, 03:18 PM | #10 |
Your welcome and it can be confusing because there are so many points of adjustment and modifications on our cars that it can be dificult to diagnose. Now if the budget was unlimited that would be a different story. Also i just saw your PM. I sent a reply
10-01-2017, 07:06 PM | #11 |
Drives: 2016 1ss m6 Camaro Join Date: Jul 2016
from what ive seen the cost of this,lt4 hpfp,injectors,is similar to what a port injection setup is looking to cost,kinda causes you to rethink where to spend the money at,especially if you have to add in the cam with 32% fuel lobe,the port injection setup starts to sound pretty interesting.
2016 camaro 1ss,m6-npp,tsp longtubes,no cats,e85,tuned by rpm motorsports(451hp/467tq),
17"race stars drag pack,bmr upper and lower trailing arms,bmr upper control arms,bmr front cradle brace,gforce outlaw axles/driveshaft,lnf 2step. Best 1/4 mile of 11.2@122mph |
10-01-2017, 09:00 PM | #12 | |
10-02-2017, 12:56 AM | #13 | |
10-02-2017, 07:24 AM | #14 | |
