Old 01-23-2025, 07:02 PM   #1
massimo
Drives: 2017 Camaro SS 1LE
Camaro 6 LED Reversing Lights
I am on my second set of LED reversing lights and I am still getting the CANBUS glow. The 2nd set even said that it would work with CANBUS. I am not getting an error, just the glow. Anyone know of LED reversing lights that work properly in a Camaro 6?
Thanks
massimo is offline   Reply With Quote
Old 01-23-2025, 09:56 PM   #2
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
Don’t think I’ve seen a set of LED lights that didn’t cause the glow, you need a resistor to run LED reverse lights. I grew tired of replacing my resistor on my old Camaro so this time around I got white halogens instead. Lose some brightness but the brake lights still flood everything in red imo while getting the same white look
2016 1LT v6
- Totaled
Happiness: Infinite
Old 01-23-2025, 10:47 PM   #3
Thanks
Use this resistor harness and you'll be fine. I've had it with high brightness LED reverse lights since March 2018, never an issue, still working as good as on day 1.
There is no way to solve this problem without resistors. Your options are as follows: 1) buy a professionally assembled harness as above, 2) solder resistors to the bulbs yourself, or 3) buy bulbs that explicitly state the presence of built-in resistors, not just "CANBUS compatibility", because this isn't primarily a CANBUS issue but a leakage current problem due to the very low resistance of LED bulbs.
Old 01-24-2025, 12:47 AM   #4
NYTMARE23
NYTMARE23
NYTMARE23's Avatar
Drives: Black 2023 ZL1 A10
I used NOKYA 7440 Hyper White backup bulbs in my Z. They're not LED'S but they DO give a much "whiter" glow than the OEM bulbs. Close as I'm getting. Don't feel like getting resistors, etc just to get the LED look. Never really got "good" before and after pics so these are the best pics I have. Of course nighttime is when you notice it the most. Top pic is OEM "yellow" halogen, bottom is NOKYA 7440 Hyper White bulb.
2023 A10 ZL1 "NYTMARE"
NYTMARE23 is offline   Reply With Quote
Old 01-24-2025, 08:13 AM   #5
These are indeed better than stock. My experience with brighter halogen bulbs in several cars is they don't last long, although that probably doesn't matter so much with reverse bulbs that are only used for short periods.
I chose LEDs because their brightness is way superior, which helps a lot with backup camera image quality in the dark. Don't mind the resistor harness at all.
But, we're not all the same, different people have different preferences, and that's is perfectly fine.
Old 01-24-2025, 08:52 AM   #6
NYTMARE23
NYTMARE23
NYTMARE23's Avatar
Totally get what you're saying. I realized I probably should have mentioned I also don't daily mine either. I have 950 miles on it since I got it September of 2022 and I think I've driven it twice at night. So, the bulbs I used I'm sure are plenty good for MY use anyways, but I CAN see the benefit of going the LED/resistor harness route if someone drives much more at night than I do.(which probably wouldn't take much!)
Old 01-24-2025, 08:53 AM   #7
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
The resistors, really, aren't bad at all.
'20 ZL1 Black "Fury"
Old 01-24-2025, 10:12 AM   #8
david_acm
david_acm's Avatar
Drives: LT1
They make drop-in replacements as well. I have had these now for over a year with no issues.
https://store.ijdmtoy.com/products/c...stay-lit-issue
david_acm is offline   Reply With Quote
Old 01-24-2025, 11:43 AM   #9
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Another thing you have to watch with putting led's in the reverse lights on newer cars is that the BCM module will not hibernate and drain the battery faster. I have resistors soldered into my LED bulbs and there is no glow, but the battery drains faster when not in use. So, I have to keep it on a float charger when the car sits. Maybe the harness Arpad linked helps. I ran into the same thing with my Acadia. I ended up putting regular bulbs back in and the faster battery drain issue went away.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Perf. mods- Whipple 2.9/Fuel System/Flex Fuel
Old 01-24-2025, 12:02 PM   #10
bbraswell918
bbraswell918's Avatar
Interesting, curious about this as well. I am wanting to do this little change to my car but won't do it if there's no way to prevent battery drain.
2016 Camaro 2SS A8 || SE 2 inch Longtube Headers | SE Offroad X-Pipe | Corsa Extremes | DSX Flex Fuel Kit | MSD Atomic AirForce Intake Manifold | NW 103mm Throttle Body | Roto-Fab Cold Air Intake | Oil Catch Can | e85 Dyno Tune
bbraswell918 is offline   Reply With Quote
Old 01-24-2025, 01:05 PM   #11
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
THIS. I used the Gen5DIY resistor harnesses and I noticed a massive jump in battery drain with the car off. I just pulled them out last week and threw them away.
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, ATI 8L90, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors & BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.10@152.5
Old 01-25-2025, 04:48 PM   #12
massimo
Thanks for the great info. Anyone know the resister ohm value I should use if I go that route?
Old 01-25-2025, 04:51 PM   #13
DeuceCam
Drives: LT1
Sorry if I'm derailing this thread, but do led side markers also put extra drain on the battery when the car is off?
DeuceCam is offline   Reply With Quote
Old 01-25-2025, 05:50 PM   #14
No, those aren't tracked by the BCM.
(Also, in other words, if they burn out, whether stock or LED, the car won't notice.)
Copyright ©2000 - 2025, vBulletin Solutions, Inc.
