Old 01-23-2025, 08:15 PM   #15
N Camarolina
N Camarolina's Avatar
Drives: 2021 2SS 1LE
Originally Posted by QuirkyTurtle View Post
I'm not sure if my images are displaying properly so here are direct links:
https://imgur.com/bYX0z1D
https://imgur.com/Q9C1tds
Wow. Not only did they not give you footwell lighting, but the pedals are positioned all wrong!
That's why you buy the 2SS and not the 1SS!
N Camarolina is offline   Reply With Quote
Old 01-23-2025, 09:00 PM   #16
speedyink1
speedyink1's Avatar
Drives: 2023 Camaro 1SS 1LE 6MT
See the comment before yours:
Originally Posted by Bumbleboy92 View Post
Not sure if it means anything, my 2SS 1LE did not come with the footwell lights. I bought and installed them myself, no flashing is required just a single wire splice and back-breaking/contortioning work
Now I'm confused, lol
speedyink1 is offline   Reply With Quote
Old 01-23-2025, 09:10 PM   #17
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
So according to the order guides - To confirm, the below is for RPO S0O (RGB footwell lighting)
2016 had no illuminated footwell option or package
2017-2018 it was included in the Convenience and Lighting Package only for 2LT/2SS
2019 was the same but 3LT/2SS only
2020-2024 did not require the Convenience and Lighting Package. You could order it as a standalone option on 3LT/2SS
It does not show as available for any other trims but maybe dealerships did it anyways, it's always been a LPO so
2016 1LT v6
- Totaled
Happiness: Infinite
Old 01-23-2025, 10:52 PM   #18
There are 2 separate sets of footwell lights for the 6th gen Camaro.
The first one is two white LED bulbs, one on the driver side and one on the passenger side. I'm sure Bumbleboy92's 2SS has this set from the factory.
The second pair is part of an optional RGB footwell lighting kit that enhances footwell lighting and follows the color of the LED strips around the radio, the door cards and between the cupholders. No Camaro will have this kit unless explicitly ordered as an RPO (or part of a convenience/lighting package that included it), or purchased as an accessory after the fact. On trims without the aforementioned accent lighting package (1LS, 1LT, 2LT, 1SS), another upgrade may be necessary before it can be used.
Old 01-24-2025, 10:10 AM   #19
speedyink1
speedyink1's Avatar
Ahhh, thought we were all talking the white bulb, not the RGB upgrade.
What an odd thing to omit.. not that I ever noticed its absence until this thread pointed it out.. but now I want it!
Old 02-04-2025, 09:28 PM   #20
QuirkyTurtle
Drives: 2018 1SS 1LE
Originally Posted by p47dman View Post
Just to say, when you add the illuminated door sills, you do not need to flash for just them. They are wired through your door switch and work with no computer upgrades.
Good to know!
QuirkyTurtle is offline   Reply With Quote
Old 02-04-2025, 10:04 PM   #21
2018 Blue 1LE
2018 Blue 1LE's Avatar
Drives: 2018 Hyper Blue Metallic 2SS 1LE 6M
2018 2SS 1LE and I do NOT have the foot well color matching lights, just white.
2018 Blue 1LE is offline   Reply With Quote
Old 02-04-2025, 11:25 PM   #22
Yes. The RGB kit is an optional accessory.
Copyright ©2000 - 2025, vBulletin Solutions, Inc.
