#15 |
![]() Drives: 2017 Camaro SS FIFTY Join Date: Dec 2016
#16 |
I can shut the trunk on my cord, without the cord being pinched. The weatherstripping prevents metal-on-metal pinch points.
Soler DLX Bluetooth Throttle Controller / OFFKAT Smoked LED Side Marker Lights / Blue SS emblems on front & rear / Wildhammer Rear Dark Reflectors / Trim Illusion Gloss Black Door Handle Covers / eBay Black Fuel Door / Screaming Chicken Fender Hash Marks / Color-Matched G2 Caliper Paint CT Sounds Tropo 10" Sub / Down4Sound MM1000 Mini Maxx amp / JL Audio LoC-22 line output converter / Sub Thump Plug N Play T-Harness With ANC Defeat Harness Kit My Camaro Journal |
#17 |
![]() ![]() ![]() ![]() Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
I really wouldn't do that if you disfigure the seal water can leak in. If you ever see how water flows around the trunk lid you are asking for trouble with all the boxes that sit in the trunk pan.
#18 |
#19 |
Here's a much better idea, that of installing a charging socket under the trunk, if someone is averse to using the underhood terminals (which has always worked fine for me, even back up Northeast at very low winter temps, but I digress...):
https://www.camaro6.com/forums/showp...1&postcount=53 The hosting thread and its "baby sister" have other interesting comments, too: https://www.camaro6.com/forums/showthread.php?t=620733 https://www.camaro6.com/forums/showthread.php?t=540177
#20 | |
2020 ZL1LE A10.
LME Max Effort LT4 390, E2650, FBO. 15" conversion, Weld S81/555Rii or MT ET Street R. 100 octane: 1116/967/1.35/9.25/151 at 3500 ft. (only one pass on this tune). 100 octane, Alky MAF Meth (1) 10+, Gain 3: 1147hp @ 5000 DA. (Pullies 3.00/9.84) |
#21 |
![]() Drives: 2022 Camaro LT1 A10 Join Date: Nov 2015
My battery comes out every winter. Gets put on my bench and juice it up once in a while. Man, I can’t wait for spring
2022 Camaro LT1 A10 - Drag Pack/Corsa double X pipe/AWE track axleback -11.849@118.67MPH/1.798 60' 2001 Camaro SS A4 - HCI/Stall/Bolt-on/Gear/Tune/DR/Diet - 429HP/392TQ - 10.99@123.58MPH/1.584 60' 1998 Camaro Z28 A4 - Bolt-on 1999 Camaro Z28 A4 - Stock |
#22 |
![]() Drives: 2023 Camaro 1SS M6 Join Date: Mar 2023
Been doing under the hood since day 1 of charging. I cant think of any problem, unless it's little stuff like not wanting to leave the hood open, or routing the wires through the front grill (can be annoying). This year she's been sitting almost 2 months already. Hoping by March we're good to go!
Black 2023 Camaro 1SS Coupe M6
Ordered: April 2022-----Built: July 2022-----Delivered: September 2022 -Dual-Mode Exhaust (NPP) -Red Painted Calipers (J6F) -5 Split Spoke Bright Silver Painted Aluminum Wheels (56W) -Chrome Camaro Logo Fender Badge -Second Generation Front Splitter in Satin Black |
#23 |
Probably doesn't like you
Drives: 2022 WCT ZL1 M6 Join Date: Jun 2015
Dealer's choice, doesn't matter.
كافر ΜΟΛΩΝ ΛΑΒΕ железобетонное очко Quod gratis asseritur, gratis negatur. There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly. |
#24 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS/RS LS3 Join Date: Nov 2011
Just consider that if needed you can jump start your car using the underhood connections...So, I would think using them for charging, trickle or otherwise, works just fine.
Messing around in the trunk is too much hassle...Under hood has always worked fine for me. Good luck. |
#25 |
#26 |
![]() Drives: 2024 Camaro 1SS Join Date: Mar 2024
Most remote posts used to jump vehicles are wired directly to starter solenoid and to the positive on the battery. I assume the Camaro may be the same. Using the trickle charger from under the hood works, but you lose amps to the battery due to the long run to the trunk. The best bet for long term storage has always been removing the battery. With that being said, this is my first winter with her, and since we have no snow, I have been lucky enough to drive her a couple of times. So, battery has remained in place.
#27 |
It gets old raising the hood and clipping there. Definitely hard wire and just plug up.
$40 bucks for one of these.. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
#28 | |
![]() I know it's not exactly needed to pull it out while storing but is the main reason nobody else take it out is because it's too heavy? This year my car is in storage for winter, so if I was to maintain the battery it had to come out to take home. Although my car was at home last winter, I still took the battery out though. Gotta get my pulls in ![]() I'm pretty active with the battery anyway. Even in summer I only drive it once a wk or so and I disconnect the battery after every drive. I never know how long the car will sit sometimes. Anyone know of any ill-effects of disconnecting after every drive? Fuel trims, re-learning or anything? If so, I certainly cant tell. Car runs great!
| Thread Tools | |
