Old 01-18-2025, 01:08 PM   #57
MikeEM1
MikeEM1's Avatar
Drives: Tracks: 18' ZL1 1LE
Originally Posted by dfxrte View Post
what's the downside to it not being fully sealed with the brackets?
Sucks hot air from the engine
18' ZL1 1LE Red Hot track toy
Endless RF650
Ported TB/Rotofab dry intake
AWE Track w/PLP
APR GTC300 wing / Singular Endplates
ASC Splitter / PA tunnels
MFR Engineering Custom Diffuser
Race Louvers Fender Vents
Trackspec roll bar
Various SPL suspension
Hawk DTC 70/60 pads
APEX SM10 & ARC8
For sale: 2018 OEM ZL1 1LE Wing
12' Nissan GT-R SOLD
MikeEM1 is offline   Reply With Quote
Old 01-18-2025, 02:36 PM   #58
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Hey Mike,
You bring up a good point. I just checked my car, and my photos, and I just don't see how that would be an issue based on the air flow direction in and out of the air filter area.
I also checked my first round of data collection... and although my IAT.1's were higher on average (3-5) degree's with the bracket, the air was also (2-3) degree's hotter than the baseline. Add to that, my IAT.3's were actually (3-5) degree's cooler with the bracket on vs. the baseline, in warmer weather...
I know those numbers don't mean much because the real benefit is in underhood heat extraction, there will be a residual benefit to IAT.s.. or perhaps a decline based on your logic of sucking in hot air, but I don't see any evidence of that thus far.
I finish with you might be onto something, and look forward to collecting more data, in different temperatures with different driving conditions. Stay tuned
Cheers!
2022 M6 ZLE: Katech Ported Blower & Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation Kit + MM Wild CC + XDI 30 + JMS + ATI + MSD + TSP VVT & DoD Delete Covers + LME Dog Bone + DMS Lid + 9.17" Lower + 2.4" Upper + Big Gulp + AR Headers + GESI UHO Cats + AWE + BMR Everything + JRE Terminator Cam Package + GMS Hood Bracket + GMS Stage.III Oil Cooler + GMS Stage.III HX System + GMS Stage.III Data Package = 770rwhp 815rwtq @E50 12.5psi www.GRIFFIN-MOTORSPORTS.com + INSTAGRAM
SOCAL.M6.ZLE is online now   Reply With Quote
Old 01-19-2025, 01:09 AM   #59
Bangkok_ZL1
Flying around Thailand
Bangkok_ZL1's Avatar
Drives: 2019 Camaro ZL1
So for Rain. I'm only talking rain, nothing else. This would be exactly the same as running with the rain guard off correct? And is water getting into the engine bay so bad in that area. Obviously, GM doesn't want it there, but I hear some are running without a rain guard in the rain. What is the danger of water getting into that area of the engine bay?
Mods - From JRE, the 125 RWHP Kit; From FI Interchillers, the Stage I Interchiller system, 5mm Supercharger/Head spacer plates, Heater blanket; From BMR Suspensions, Motor mounts, Cradle lockout Bushings; From Misc, Train horn in the Abandoned Heat Exchanger location using the exchanger bracket. From Banks, An I-Dash to read it all...
Bangkok_ZL1 is offline   Reply With Quote
Old 01-20-2025, 12:08 PM   #60
MikeEM1
MikeEM1's Avatar
Hey Mike,
Cheers!
There's a lot of variables to account for, especially application of driver. I have 30 minutes of hard driving on track vs another owner maybe doing 5 second pulls on a highway every so often. There's a lot more heat generated with my use.
I will note I haven't recorded any data yet, but I think it's a valid concern for my purpose.
RacingforALS already made a video of track use with a rotofab vs stock intake on track with data showing running a rotofab is a negative on track. I'm not saying it's the end all be all, but it's some good info to start with.
https://youtu.be/UujCWEQjX5I?si=sgcamdCkShcZPH2l
Your product looks super nice and I'm surprised after all these years no company jumped on it. I'd probably be on board if I didn't make my own already. Quick note, the GT4.R we got inspiration from for this runs a closed intake. Maybe it's due to regulation or it's the better route. I don't know.
Endless RF650
AWE Track w/PLP
Trackspec roll bar
Hawk DTC 70/60 pads
APEX SM10 & ARC8
Old 01-20-2025, 01:02 PM   #61
JSH
JSH's Avatar
Drives: '20 ZLE
Originally Posted by Broooster View Post
What harm is done if you just run your car without the rain guard? I thought I read, if you track your car, you should remove the rain guard. I don't track my car, but I do run it without the rain guard. I haven't noticed any negative effects to my insert at all.
I removed my rain guard two years ago, and the only thing I notice is smoke coming out of the engine compartment
'20 ZL1LE A10.
LME 390, E2650, FBO.
15" conversion, Weld F14 Beadlock/Nitto 555Rii 325/50R15.
100 octane:1116/967/1.35/9.25/151 at 3500 ft. (only one pass so far).
Alky MAF Meth, (1) 10+, Gain 3, 100 octane: 1147hp @ 5000 DA.
Old 01-20-2025, 01:04 PM   #62
PowerDemon
PowerDemon's Avatar
Drives: Camaro ZL1, Golf GTI
Do you have issues with anything getting wet while washing?
’22 ZL1 Riverside Blue 6MT
’15 GTI Carbon Steel 6MT
PowerDemon is offline   Reply With Quote
Old 01-20-2025, 01:30 PM   #63
SOCAL.M6.ZLE
Great feedback Mike, Just sent you a PM to discuss adding you to our track testing list.
Old 01-21-2025, 02:09 PM   #64
Chris357
Chris357's Avatar
Drives: 2018 ZL1 Garnet Red A10
Hey Mike,
Cheers!
Surely something could be fabbed up to replace the rubber seal on the top edge of the Rotofab "airbox" that would effectively to seal to the altered contour of the hood.
Otherwise, what would be the best closed box alternative out there?
2018 ZL1 Red Hot A10 (SOLD 1/21)
2001 Corvette Z06 Quicksilver Heads/Cam/Longtubes 443rwhp (SOLD 5/23)
2018 ZL1 Garnet Red A10 (BOUGHT 2/23)
Chris357 is offline   Reply With Quote
Old 01-21-2025, 06:01 PM   #65
Broooster
Drives: Sharkskin Metallic ZL1
PowerDemon, for me, I just toss the rain guard back on with 1 screw when I do a wash. It's really not a big deal. when I'm done, I just remove it again. Easy and free.
Broooster is offline   Reply With Quote
Old 01-21-2025, 10:14 PM   #66
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
If you’re running E85, then total airflow > IAT readings, everyday of the week and twice on Sunday. If not, then your engine is very knock limited regardless of what you do with your intake setup. TLDR, you need E in your life.
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, ATI 8L90, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors & BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.10@152.5
Old 01-23-2025, 10:21 AM   #67
PowerDemon
PowerDemon's Avatar
Cool. Thanks for the insight!
Old 01-24-2025, 03:20 PM   #68
SOCAL.M6.ZLE
Could not agree more...
Old 01-25-2025, 12:02 PM   #69
Bangkok_ZL1
Smoke..... That could be good or bad, LOL
Old 01-27-2025, 11:33 PM   #70
SOCAL.M6.ZLE
Hey guys.... for those who missed out on the first test run, the now thicker final production run is finished, and I have the next batch of (30) matte black brackets boxed and ready to ship!
https://www.griffin-motorsports.com/...insert-bracket
Copyright ©2000 - 2025, vBulletin Solutions, Inc.
