Old 01-07-2025, 10:22 AM   #1
Dunes
Drives: 2018 SS 1LE
Lightbulb Progress Thread: 2650 Install on 6.2L SS1LE
I used to be an active member on LS1Tech, then life happened and kids came into the picture, and any and all car hobbies went on full stop. I've been saving for my C8 Z06/Z07, but since that's a ways off, I decided to pick up a SS1LE and leave it stock. So naturally, 7 months later, I bought a Magnuson 2650 kit and LT4 fueling from Jannetty (Thanks Ted!).
This forum has been very helpful in making decisions - I'll update the thread as I go, but wanted a place to document the the install and hopefully be a resource to other mildly certified YouTube mechanics like myself. While the Magnuson supplied instructions are good, there are gaps that I personally experienced that I tried to help with below - use at your own risk
Car is a 2018 SS1LE with 9K Miles.
Working 30 to 60 minute increments as I have time - updates below!
- My first time using these new GM clips (push up on the red clip, and use a small flathead to press in the black piece where the red clip secured to)
- Who can remove those black bumper blocks without breaking that small hook/clip? I'm sure I can reuse them..
- Fuel system removed, tool PN#: EN-51092 to ensure the cam is in the correct position (and cyl #1 in TDC) for LT4 HPFP install. Removed the fuel rail gently by using only my fingers and pulling lightly on each end, came out with very little effort. Used a tiny amount of Vaseline on the injector seals and they slid right into the rail.
- Something not in the Magnuson instructions, The Magnuson supplied fuel line that connects to the output (Male connector) of the LT4 HPFP hits the OEM fuel lines and simply doesn't fit. JRE instructed me to gently use a plastic hammer (pictured below) and very slowly, gently tap tap tap away and move the connector more toward the driver's side. Another thing to do here, the fuel lines (where circled below) can potentially stick up and hit the bottom of the 2650 as referenced in Magnuson's instructions. I used the same hammer to gently tap the line downward to ensure the highest point of the line was below the top of the nearby bolt. I had no clearance issues after these steps.
- Pulley removal/install was easy as well, used the ARP Crank Bolt PN 234-2503 (with a 1 1/16 Standard 12 point deep socket) to avoid the whole stretch/torque angle meter. Used the lubricant provided/instructed by ARP and torqued to 250 ft lbs. PN W89712 for the puller from eBay was perfect. The installer I got from a LS swap site (non-sponsor so not linked)
- Use the LS3 seal, and as pictured below, install it dry, and ensure the correct orientation (LT1 seal is inverse from typical crank seals - the LS3 seal installs flat side facing out). I learned after the fact that some folks use brake clean to help with the ease of the crank seal install (because it dries to fast, it counts as a dry install still). I didn't do this, but I'll try it next opportunity.
- The Intercooler pump supplied was incompatible with the suppled wiring harness (photo below). A quick call to JRE and Ted Jr. sorted me out quick with the right pump. The new pumped I received didn't have the connector off to the side, making the rubber mount install much easier.
- On the subject of the Intercooler Pump, parts of 'Section 11: Intercooler Pump Plumbing' should be done before 'Section 10: LTR install'. I'll put some extra pictures below to help explain why, but install the pump bracket first, then with the pump out of the car, install the 3" X 20" 'L' shared hose onto the pump. Then ensure the lower LTR hose is slid through the radiator area, then install the pump on the bracket. This will make pump install much easier vs. wrestling with the hoses with the LTR brackets in the way.
- The IAT sensor (front of the blower toward lower passenger side) arrived broken in the packaging. JRE also sent me a new one no questions asked. Not something that I would replace with the blower installed.
Dunes is offline   Reply With Quote
Old 01-07-2025, 11:02 AM   #2
JANNETTYRACING
JANNETTYRACING's Avatar
Happy New Year and you are welcome.
Thank you for choosing Jannetty Racing to be part of your project.
Ted.
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 01-08-2025, 09:07 PM   #3
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Well done thus far!
Most importantly, in the first pic it's nice to see you not granny shifting and instead using a Glencairn for your scotch like you should.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp // CSP LT's & Ultra Cats // JMS // Elite Ultra CC // BMR MM // BC Forged KL13
Past Rides-
2014 ZL1 M6 Red Hot | Tons of mods
2004 CTS-V M6 Silver | Many mods
1995 Corvette M6 Torch Red | A few more mods
1992 Camaro M5 White | A few mods
Old 01-09-2025, 03:50 PM   #4
beowulf556
Drives: Camaro SS 1LE
Can you come do mine after? lol
2018 Camaro SS 1LE
beowulf556 is offline   Reply With Quote
Old 01-21-2025, 08:30 AM   #5
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
Nice build.
Old 01-22-2025, 03:08 PM   #6
Kelly@PCMofNC
Drives: 2010 RS/SS
I decided to pick up a SS1LE and leave it stock. So naturally, 7 months later, I bought a Magnuson 2650 kit...
lol, welcome to the rabbit hole.
Kelly@PCMofNC is offline   Reply With Quote
Old 01-23-2025, 08:25 AM   #7
Dunes
Drives: 2018 SS 1LE
Well done thus far!
This made my day more than you can know!
Updates made. Driving over to JRE today to pick up the replacement intercooler pump and a wideband.
Old 01-26-2025, 10:21 PM   #8
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
It's so close now! You'll be done in no time.
Past Rides-
Copyright ©2000 - 2025, vBulletin Solutions, Inc.
