Old 07-26-2024, 01:22 PM   #1
Botch1
Drives: 2012 Camaro SS/RS 6 -speed
Read trans axle fluid flush
Looking for advice for my 23 2SS1LE The salesman That sold me the car in July of 2023Told me at 1500 miles Plus I should be getting the Differential lube Change He said because of all the Clutch Material in the rear end Can have debris From break in He said that flushes out Contaminated Clutch Pack Material The salesman has a 22 ZL1 1LE He tracks the car several times a year and that is good preventative maintenance I do not plan on tracking the car but do like to have fun on the back roads What do you think is best! Thanks
Botch1 is offline   Reply With Quote
Old 07-26-2024, 01:30 PM   #2
Nick S
Nick S's Avatar
Drives: 2013 Camaro 1LE
It's not that expensive to buy the fluid and change it. Just do it and be on the proactive side to making sure the diff stays in good shape. There is a specific GM ELSD fluid though so make sure you get the correct fluid.
Nick S is offline   Reply With Quote
Old 07-26-2024, 01:32 PM   #3
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
i track my ss and i do one every rear but if your not tracking it shouldnt be a big deal
Old 07-26-2024, 05:01 PM   #4
N Camarolina
N Camarolina's Avatar
Drives: 2021 2SS 1LE
The fluid is usually dirty after the break in period. Supposedly the gears are have some sort of black coating that comes off with use. If you're going to beat on the car on back roads (high rpm) for prolonged periods at a time (high amounts of heat put into the fluid), probably better safe than sorry and get the fluid changed now - it's not expensive, especially if you change it out yourself.
Note the change interval for track driving is 15 hours of use (possibly 24hrs depending on which year of the high performance manual you read). So if you like to flog it a lot on roads, keep track of your driving hours under those conditions and change fluid accordingly.
N Camarolina is offline   Reply With Quote
Old 07-26-2024, 05:13 PM   #5
22SS1LE
Drives: 2022 1SS 1LE 6M
i did mine at 1700miles 2 bottles
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2022 1SS 1LE 6M in Riverside blue
Found exact build local- ETA 7/31/22
New ETA - 7/26, 7/30, 7/31, 8/1, 8/8, 8/15, 8/21, 8/28, 9/17
8/24. IT HAS ARRIVED at the dealer
8/25- It is in the Garage
ACS ZL1 Sideskirts, 20% tint, CAI Intake
22SS1LE is offline   Reply With Quote
Old 07-29-2024, 08:24 AM   #6
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Ive done two cars differently, the 18 1LE didnt get changed to >35K miles. My ZL1 has been changed twice in 19K. No logic or reason I just chose to do it, or not. On that the first change on either car, the magnetic plug was caked with goo though.
Old 08-10-2024, 05:47 PM   #7
avarshav
avarshav's Avatar
Drives: 2020 SS 1LE 6M, 24 Nissan Frontier
I can confirm this to be 100% true. I bought mine new, waited till it had about 4k miles on it, then did it. I wish I did it sooner. It came out grey and funky. I dont track mine or even beat on her all that much. Since then, I do it with every oil change. its cheap and easy to do, easier then changing your oil.
avarshav is offline   Reply With Quote
Old 08-20-2024, 06:17 PM   #8
pzoom
pzoom's Avatar
Drives: 2021 SS 1LE SHOCK
Did mine at 1500 miles, it was nasty.
pzoom is offline   Reply With Quote
Old 08-20-2024, 09:15 PM   #9
Coded4SS
Drives: 23 Zl1
Did it at 500, 1500, 5k
Part 88862624 10-4034
Coded4SS is offline   Reply With Quote
Old 12-04-2024, 08:40 AM   #10
steig
Drives: Chevy camaro
Very easy to change diff fluid. 2 qts ACDelco Dexron LS 75W-90 Gear Oil
steig is offline   Reply With Quote
Old 12-20-2024, 10:46 PM   #11
ZLElvira
Waiting 4 A Point By!
ZLElvira's Avatar
Drives: 2020 ZLE, C8 Z06-Z07 2LT Carbon
I have a lift in my shop with Amsoil gear oil in a 5-gallon bucket with a pump... I change it as part of my pre-trackday prep just to keep an eye out for anything mysterious or irregular.
David Wilks
PatriotMotorSportsUSA@Gmail.com
Check out my Camaro ZLE videos on my YouTube Channel!!
Banks iDash Datamonster, Patriot MS SCHX-reverse-flow, A10 Trans Heat Exchanger, ARH 2", Magnaflow X-Rez, Lingenfelter 9.17 lower pulley/stock upper & SC, APEX Wheels, Hawk DTC60/70, Goodyear SC3Rs/Michelin PS4s OEMs, OG Hood Vent Kit, PatriotMS 5psi SC Expansion Tank, HPTuners, 790 rwhp & 830 lb/ft@2375rpm!
ZLElvira is offline   Reply With Quote
Old 01-22-2025, 06:00 PM   #12
p47dman
Drives: 2024 Camaro 1SS
Calls for 1.2 qts. I used recommended fluid. Got it on Amazon and it was shipped from a dealer in WI. Changed at 6200 miles. Fluid still clear and no mud on plugs.
p47dman is offline   Reply With Quote
Old 01-23-2025, 12:29 PM   #13
cdrptrks
cdrptrks's Avatar
SS 1LE has the eLSD that the regular SS doesn't have. eLSD takes close to 2 quarts.
Old 01-23-2025, 02:44 PM   #14
p47dman
Good to know.
Copyright ©2000 - 2025, vBulletin Solutions, Inc.
