Old 06-17-2024, 12:29 PM   #1
Saberscar223
Saberscar223's Avatar
Drives: 2023 Riverside Blue 2SS
7psi whipple 3.0 on stock lt1?
Can the stock LT1 and OEM fuel system handle that? I really don't want to upgrade the fuel system and id be satisfied with the gains id get from 7 psi but would i have to upgrade the fuel system regardless of what psi I run?
Right now I have 2 inch headers, E85 and a CAI.
Saberscar223 is offline   Reply With Quote
Old 06-17-2024, 01:51 PM   #2
KC64
Gray Ghost
KC64's Avatar
Drives: 24 Camaro 2SS Loaded
The 3.0 Whipple and 7 pounds of boost you would be well advised to do a cam package and fuel and have a very reliable car, otherwise you could run low boost and be fine but these cars run on HIGH compression and if you do not do a cam package you would be looking at some problems that are likely to show up.
You could do the Whipple and low boost or Pro Charger says you can run their stage two and not touch a thing other than a tune.
I am saving money as right now my intentions are to do a cam package, pistons, heads along with everything else, do a CAI and tune and run NA and have a nice HP reliable Camaro.
KC64 is offline   Reply With Quote
Old 06-17-2024, 04:37 PM   #3
Kerry
Drives: 2019 2SS Camaro
Aftermarket cams in most cases with high lift ect are not as reliable as stock cam set ups. A cam is not necessary to make power with boost.
Kerry is offline   Reply With Quote
Old 06-17-2024, 05:34 PM   #4
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
E85 is your best bet to make the stock LT1 shortblock live. To run E you will want LT4 in-tank, HPFP, and injectors at a bare minimum.
Cam is absolutely not needed at 7 psi.
Agreed.
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, ATI 8L90, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors & BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.10@152.5
Old 06-17-2024, 08:43 PM   #5
KC64
Gray Ghost
KC64's Avatar
If you are going to get into the motor a cam is easy to do. You can do a stage one and not do anything but 7 pounds of boost on a Whipple 3.0! Is pushing it on a stock motor.
I have not heard of a shop not doing a cam while they are in there, the four or five shops that I know of all say do a cam package.
Old 06-17-2024, 08:55 PM   #6
m6-lt1
m6-lt1's Avatar
Drives: 2023 Chevrolet Camaro 2SS 1LE
You don't have to go inside the motor to install any super charger.
Current: 2023 2SS 1LE
Prior:
2016 Camaro 1SS
2007 Mustang GT
2008 Civic Si
m6-lt1 is offline   Reply With Quote
Old 06-17-2024, 08:57 PM   #7
Joshinator99
7 pounds is *not* pushing it on a stock LT1 running E85. No way.
Old 06-17-2024, 09:00 PM   #8
KC64
Gray Ghost
KC64's Avatar
Correct on a stage one you do not have to go in the motor.
And another fact is the stock catalytic converters are going to heat up nice and toasty, best to run high flow cats to avoid any troubles.
Old 06-17-2024, 09:26 PM   #9
Kerry
wonder why they all recommend a cam?
Old 06-18-2024, 08:15 AM   #10
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
If you are going to get into the motor to install a cam then you should do rods and pistons being the engine has to be torn down to the short block anyway for a cam. Many just pull the engine.
It's not nearly that extensive to install a supercharger. You are literally just pulling the intake manifold and balance off.
That being said, the stock fuel system will be maxed on 7psi with pump gas. You really need to upgrade fuel system and run ethanol on a SBE LT1. A cam is certainly not needed...fuel system is.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Perf. mods- Whipple 2.9/Fuel System/Flex Fuel
Old 06-18-2024, 08:54 AM   #11
GreyGhost702
Drives: 2019 Camaro 1SS1LE
As others have pointed out, fuel system is a must have especially when upping the Ethanol content. LT1 Direct Injection is going to get spanked on E with boost. The LT4 HPFP should remedy that for a 7 PSI build. If your ride isn't a 1LE, you'll also need to upgrade to the LT4 in-tank pump as well, or something a little meaner than the LT4, since you're dropping the tank anyway.
Also, since you'll be pulling your balancer off anyway, an ATI Super Damper makes for a nice upgrade. A little help to keep the OE oil pump and internals happy, and take the opportunity to replace that front seal while the balancer is off. Which leads to my last suggestion, upgrade the PCV system and get a catch can system on the car. Another quality of life upgrade for the engine. I really like the Mighty Mouse stuff, they have some serious hardware and it looks sharp under the hood.
A cam is going to push your build into another realm of complexity and funding, I wouldn't recommend it until you're good and bored with 7PSI. With a PD setup, 7PSI on E85, you're going to make tire frying power. The next step up is the realm of the absurd in terms of putting power to public asphalt, and it becomes more of a dyno queen and bragging rights than an ability to keep the car planted.
2019 1SS1LE M6 Shadow Gray Metallic
ProCharger D1X Race Kit - 4.25" Pulley || GPI Pistons/Rods - ACL Bearings - ARP Hardware || LME Timing Chain Guide || Katech C5R Timing Chain || Katech OE Spec Billet Oil Pump || OE Ported Heads || CHE Trunnion Upgrade || BTR 220 Cam - BTR .660" Dual Springs - GM Racing "Caddy" Lifters - BTR 3/8" Pushrods (7.825") || ATI Balancer || LT4 Injectors || LT4 HPFP || JMS BAP || DSX Flex Fuel || LT2 Intake Manifold || LTH (Catless) || Stainless Works Redline Series NPP || 91 + 8oz Boostane
7/26/2024 Tuning in progress
GreyGhost702 is offline   Reply With Quote
Old 01-20-2025, 11:47 PM   #12
3rd_Will
Drives: 2018 Chevrolet Camaro 2SS 1LE
First of all, I just wanted to thank you all for your input here. I'm trying to plan out what I want to do with my 18 ss.
It seems like the 3.0 Whipple is packaged from Whipple for a stock 6.2l. I'm considering just going with that because I want to keep it my daily driver on all seasons 7 months of the year.
If I go with the Whipple 3.0 and their tune, and later on in a couple years want to put a mild cam like a 220(?) and get that tuned, would that overtax my fuel system (1LE)? Would it push my HP to a level where I have to throw in more mods to have it all work together?
2018 Camaro SS 1LE w/ a manual.
Thanks
3rd_Will is offline   Reply With Quote
Old 01-20-2025, 11:56 PM   #13
Hostile_1LE
Hostile_1LE's Avatar
Drives: 2020 Camaro SS 1LE | Satin Steel
Thanks
yeah it will need a fuel system
HCI | GPI SS3 | E85 | xxx whp \ xxx tq
Hostile_1LE is offline   Reply With Quote
Old 01-21-2025, 05:50 AM   #14
Ray3768
Ray3768's Avatar
Drives: 1977 Trans Am, 2024 Camaro 2SS
They recommend a cam that closes the exhaust valve later in the cycle (more overlap) which decreases the dynamic compression ratio. This will reduce the cylinder pressure and tolerate more boost and more advanced spark timing.
-Ray
Ray3768 is offline   Reply With Quote
Copyright ©2000 - 2025, vBulletin Solutions, Inc.
