Old 04-07-2018, 06:51 AM   #29
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
At our shop we've seen lower ball joints cause similar issues, if its stuck and not articulating like the other side it could cause problems under acceleration or braking as could a strut mount.
Old 04-07-2018, 09:31 AM   #30
Wierd Harold
Drives: 2017 2lt rs
Maybe electric steering issue ?
Wierd Harold is offline   Reply With Quote
Old 04-07-2018, 10:10 AM   #31
17CamaroZL1
Life's Short, Live Fast!
17CamaroZL1's Avatar
Welcome to my thread... and there's another one out there with quite a few others experiencing this.
I just got rid of the car...
Here's whole group of folks with the same type issue.
http://www.camaro6.com/forums/showpo...9&postcount=46
You don't have your Z any more?!! I hate to hear that. Have you replaced it with anything?
Life's Short, Live Fast! https://youtu.be/rTUv2p4T7OA 10.94 at 128 mph, 11.13 at 127mph 870 DA, https://youtu.be/e_X_LcpFp50 11.19 at 127mph 1100 DA, https://youtu.be/OXQiCQdQuH4 11.40 at 125mph 1800 DA
https://youtu.be/uWba1qs8M6Q 11.52 at 123mph 3500 DA
12/26/2016 Ordered!
2/8/2017 Built!!
3/2/2017 Brought Home!!!
Old 04-07-2018, 11:28 AM   #32
tomster
RedLine
tomster's Avatar
Drives: 2022 ZL1 1LE
its a tire pull swap tires side to side and see if it changes. working for bridgestone i would see this from time to time
2018 GMC 2500 "Blue" (Sold)
2018 ZL1 1LE Hyper Blue" (Sold)
2018 CTS-V "Black" (Sold)
2022 GMC 2500 "Blue"
2022 ZL1 1LE 6spd "Rapid Blue"
2023 ZL1 1LE Auto Rapid Blue (ordered)
tomster is offline   Reply With Quote
Old 04-07-2018, 11:43 AM   #33
The plan was always to get the ZLE so I'm anxiously waiting on a 19 right now. This issue helped with my decision but hoping something gets fixed.
Old 04-07-2018, 02:17 PM   #34
pcguy2u
pcguy2u's Avatar
Drives: 2009 Corvette ZR1
In for the fix...
pcguy2u is offline   Reply With Quote
Old 04-07-2018, 02:20 PM   #35
17CamaroZL1
Cool! Are the 19s available to order yet? Are you going with white again?
12/26/2016 Ordered!
2/8/2017 Built!!
Old 04-07-2018, 07:50 PM   #36
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
Ive never had any issues in my car; but Im easy on the throttle unless the temps are into the 70's or have been driving for a while.
when I leave my house in the mornings temps are high 40's lor 50's this time of year, and after 20 minutes at 70 mph on the freeway the tire temps still read cold. this car will light up the tires even at lower rpms in first and 2nd gear if the tires are not warmed up.
also with the stiff suspension there is no where near as much weight transfer to the back of the car like on the other ZL1's which makes having warmed up tires even more important.
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is offline   Reply With Quote
Old 04-07-2018, 07:53 PM   #37
Colormegone
Originally Posted by JANNETTYRACING View Post
It really sucks I have a track event paid for next Sat, I need this resolved before then.
Well I just saw the sun pop out down here and really wanted to take my new ride out, only 70 miles on it and I have owned it 3 weeks, yay New England weather sucks... So I saw you dilemma , so I made my treck up on 395 here in CT. Some nice long stretchers of fairly smooth road, well I did several different sims. And my 2018 ZL1 1LE tracked perfectly, rolled it at 60 , into the throttle and no lane change or pull, tires were in the green/ 39 psi in all 4. So I cannot help out your situation with any info my ride did not compare to yours. Sorry to here but I am sure you will soon figure out what is wrong.
Side note, I too have signed up for track day at Thompson on the 24th also in May on a sat. That's why I kind of went out today to get some good break in miles on it.
Came home with 125 miles on it, man do I like this car!!!!!
Maybe I will see you at a track day some time. Palmer is on my list as well.
Good luck with yours....
Nathan
Colormegone is offline   Reply With Quote
Old 04-08-2018, 10:24 AM   #38
JANNETTYRACING
JANNETTYRACING's Avatar
Update
Spent the day yesterday testing different combinations and on the chassis scales.
Things we tried with Zero change, tested after each change.
Swap rear tires
Swap front tires
Went to a parking lot and did several circles left and right.
Tried different PTM modes.
Tried different driving modes
We (Top Cat and I) put the car on the scales an noted the corner weights, with and without me in the car, right rear had over 100 lbs more than left so we proceeded to adjust the front coils to even out the corner weights.
We also found the front sway part has some preload on it with suspension haning so I will be installing adjustable sway bar links.
Nothing we did had any affect on the torque steer.
I don't completely understand how the ELSD works but this car feels exactly like a car with a spool and a broken axle.
I am under the impression that all the torque goes to the right rear wheel when torque is applied.
The ELSD percent increases with Throttle which leads me to believe the Rear diff clutches are not responding to computer commands.
Will be visiting the dealer in the morning and try to get them to replace the diff as an assembly as I believe it is defective after 2 days of systematically eliminating other possible causes.
Stay tuned.
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 04-08-2018, 10:31 AM   #39
closs2sx
closs2sx's Avatar
Drives: 1970 chevelle
Good Luck Ted.
On Order 2018 ZL1 1LE Garnet Red Tint Coat Metallic
MY Car
2015 Z06 Z07
Daytona Sunrise Orange Metallic
Dads Car
2013 ZL1 vin 963
Crystal Red Tint Coat/Black Wheels
Exposed Carbon Fiber Insert
6 Spd Manual
closs2sx is offline   Reply With Quote
Old 04-08-2018, 10:34 AM   #40
travislambert
travislambert's Avatar
Drives: '17 ZL1
If you turn traction control off and spin the tires going straight, both tires should spin. If only one spins that would confirm a problem with the eLSD. When the clutches don't work, it will behave exactly like an open differential.
Also, some vehicles can apply each rear brake independently to vector torque. I don't know if the Camaros do this or not, but it might be worth checking into.
2023 Camaro SS 1LE A10
2023 Camaro ZL1 1LE M6
2017 Camaro ZL1 M6
2016 Camaro SS M6 w/LT4 (Sold)
travislambert is offline   Reply With Quote
Old 04-08-2018, 10:39 AM   #41
travislambert
Drives: '17 ZL1
Oh. It's probably worth checking your steering angle sensor. That a major input for the eLSD. If it thinks you're trying to turn while you're actually trying to go straight, it would throw everything off.
The easiest way to check is use your PDR to record a video while trying to drive straight. Make sure you use an overlay with the steering angle. It should read near 0 degrees while going straight.
2017 Camaro ZL1 M6
Old 04-08-2018, 04:30 PM   #42
Bx Tpr
Drives: 22 ZLE 6MT
This car will change lanes with the steering wheel perfectly straight with Moderate throttle.
So I pulled up the ELSD gauge on the dash and I see the Percentage rise on throttle and it was showing small amounts of tire slip even with none.
So I dropped the car off at my shop and called it a night.
This morning I went through the entire suspension, front and back looking for something that can shift or is lose and torqued every bolt and everything was perfect.
We even went so far as to measure the rear tires for circumference to see if I had a larger tire on one side, NOPE perfectly the same.
This leads me to think there is something going on with the ELSD.
Anyone else experience anything like this?
Ted.
Same thing here. Had my bro in the car out on the interstate a few months ago. I went WOT in the right lane and ended up in the middle lane a second later lol. I thought it was just the combo of a bad roadway and wide tires.
Bx Tpr is offline   Reply With Quote
Copyright ©2000 - 2025, vBulletin Solutions, Inc.
