#29 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '22 Silverado 2500HD Duramax LTZ Join Date: Dec 2015
No issues with mine..... been up there pretty high...... only time I get anything close to that is early mornings, cold tires and roads........ but its just under really hard acceleration.... early into my drive....
#30 |
![]() ![]() ![]() Drives: 17 ZL1 Join Date: Mar 2017
Have you checked your rear rims for hairline cracks? Just a thought
2017 ZL1 Coupe M6, Red Hot
Mods; AFE Pro 5R CAI, Kong Ported Blower and Snout, NW 103 TB, Griptech 2.31 Upper, Kooks 2",JMS Voltage Booster, Flex Fuel, Mighty Mouse CC,Jannetty Racing Tune, 680 rwhp |
#31 | |
![]() Drives: 2017 Camaro ZL1 M6 pdr roof CF blk Join Date: Mar 2017
Also some members in warmer states with perfect road surfaces may not experience above as much. |
#32 |
![]() Drives: Pre-production ZL1 M6 Join Date: Feb 2016
Been up to 140 and solid as a rock. Planted in the ground like concrete. Only time I’ve ever felt uneasy is in rain, especially where water has puddled. The car gets squirly in the rain due to the tires.
#33 | |
H-Town Camaro Club Member
Drives: 17 Hyper Blue Metallic KLR-ZL1 Join Date: May 2009
#34 |
![]() Drives: 2017 ZL1 A10 Join Date: Nov 2009
I have experienced this several times at the track. But it's not very consistent and would be hard to repeat. I am thinking it has something to with the surface of the road maybe? I have been on other roads (Westpark Toll) in Mexico making a lot higher speed runs and never felt the rear end getting loose.
#35 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
check the rear cradle bolts and anything that attaches the rear to the car itself. Check sway bars (especially the end links that have been loose on many cars). Get the car on a rack and see if anything else could be loose and not properly torqued. Mine feels stable, solid, and I have no squirrely feelings up to 100mph. I'm still in break-in mileage at 705 miles on the clock. The car sounds like it has that feeling like a rear tire is flat or under inflated which we know isn't the case.
#36 |
![]() Drives: 2015 Z/28 Black Join Date: Nov 2016
Note: Any low speed wobble is always a tire issue, maybe a separated belt or something.
2015 Black Z/28
70 Chevelle SS396 01 M3, 88 Land Cruiser |
#37 |
Cal
Drives: 2017 6th Gen Camaro ZL1 Coupe M6 Join Date: Sep 2013
I've never had stability issues with my M6 on stock tires at any speed up to nearly 150 MPH. It's always been rock solid.
I did feel a bit squirely with the new DRs on the big end at the drag strip but I attributed that to the wider sidewalls, low tire pressure, and cross-winds that day. I put the car up on a lift and do a safety inspection before each track visit. So far no loose components. Still, as others have suggested, there is a bulletin out about loosening struts (ZL1 Front Struts FYI). This may not be detectable by hand on a lift. I don't see how old differential fluid would cause the behavior you describe but I do change mine after every 1 or 2 drag strip trips, depending on how hard it's driven. Faulty eLSD could potentially cause instability if it clamped down with too much pressure or at the wrong time. travislambert has opened this thread to investigate eLSD issues with the M6: eLSD Wheel Slip % on M6 I hope this gets resolved soon. I'd be interested to know what's causing it too. I can imagine how frustrating it is. --Cal |
#38 | |||||||
![]() Quote:
#39 | |
#40 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS/RS LS3 Join Date: Nov 2011
If you are trailering it, take it to the fest and slam the crap out of it!...lol....(just don't crash).....Like HAL in Space Odyssey suggested...let if fail, then you'll know what it is that's wrong.....
I wouldn't let it turn the fest into a bummer for you....Get some engineers in it with you, and let it rip.... |
#41 |
![]() ![]() Drives: ZL1/335i Join Date: Apr 2014
+1 on getting that car on an alignment machine. Wouldn't be surprised if you had a rear toe issue. New cars can definitely be far from ideal. It's pretty common from what I've experienced working on brand new cars over the years. Cheap and easy to check.
#42 |
![]() Drives: 2013 2LT RS, 2017 ZL1 Join Date: Jan 2013
I have felt the fish tailing in three scenarios, heavy accel from low speed, heavy braking on a turn, and very heavy rain at any speed over 30 mph which is more tires
Thread Tools | |
