05-23-2019, 10:41 AM | #1 |
Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
Car over heating.
Car is a 2018 ZL1 A10. Over heated today going 75 just cruising. Car is at the dealership right now. The fans come on but the temps rise pretty high with reduced engine power coming on. Any ideas?
History: car has kooks ceramic coated no cats, 9.1 pulley, RF intake, 160 thermostat. I’m wondering if the thermostat is stuck and not flowing. There is plenty of fluid. Oil looks good too with recent oil change about 2k miles ago. |
05-23-2019, 11:13 AM | #2 |
2019 ZL1 1LE MY GOON
Drives: 1980 Z28 Big Red. Join Date: Dec 2018
Was it boiling over?
Maybe the temp sensor is messed up. |
05-23-2019, 11:18 AM | #3 | |
2018 ZL1-NFG-A10
New Iron L8T 9.32 147MPH |
05-23-2019, 11:39 AM | #4 |
Mods were done about 3k miles ago. No problems at all. After pulling over and letting it cool down I drove it to the dealer about 3 miles away and watched the temps climb from 170 to 210 in about 2 minutes. I pulled over about 1 mile from dealer, turned it off and the fans were running. After a couple of minutes the fans turned off and I started up again. Once pulling into the dealer the temp was at 215 and I shut it down. I don’t think the coolant is circulating so maybe thermostat or water pump. Could also be air in the system but I have no experience with that.
05-23-2019, 12:01 PM | #5 |
Drives: 2019 Silverado Z71 6.2L A10 Join Date: Mar 2017
It really does sound like a faulty thermostat that got changed. In my lifetime, this has happened to me. It opens, but not all the way. The best way to test it yourself, if you want to, is to boil it and watch what it does. That's what I did and it just opened halfway.
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's. Past Rides 2017 M6 Camaro ZL1 Hyper Blue 2016 M6 GT350 White with blue strips 2014 M6 Mustang GT Premium Track Pack Ruby Red 2012 M6 M3 Melbourne Red Metallic |
05-23-2019, 12:03 PM | #6 |
Drives: 2019 ZL1 1LE Join Date: Feb 2017
These engines are really sensitive to air pockets in the system, and it has a lot of places for air to get trapped. They basically put the system under vacuum before introducing coolant, and it is a lengthy process to get all of the air out. Wouldn't surprise me that that's all it is.
Old: 2017 SS 1LE
Old: 2017 ZL1 Current: 2019 ZL1 1LE |
05-23-2019, 12:33 PM | #7 |
Drives: 2017 ZL1 Join Date: May 2019
My 16 z06 had the exact same thing happen.
Failed mishimoto 160* thermostat. The rubber ring fell out of the grove. Once I replaced it, it overheated again and after pulling the water pump (it was fine) I replaced the tensioner. That fixed it up. I'm not sure if the thermostat failed first, or if the tensior failed first and caused the thermostat to fail. |
05-23-2019, 01:04 PM | #8 |
I wish you luck on getting your modded Camaro worked on at a dealership. I’m surprised they will even look at it but hopefully there is a tech there that finds out the cause of the overheating. Good luck!
05-23-2019, 02:11 PM | #9 |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
My wild guess is an air pocket. Just did a 2000 mile road trip with similar mods to yours. Temp only exceeded 185 once, stuck in a traffic jam on a warm day it briefly climbed to 195 and the settled back to 185. Air pocket issue is my guess.
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
05-23-2019, 03:03 PM | #10 |
Drives: A10 LT4 Join Date: Aug 2016
Well that stinks Mark...wanna race??
05-23-2019, 03:42 PM | #11 |
05-23-2019, 04:45 PM | #12 |
Let me know...got the lockout kit & all the bolts needed, pending the BMR upper / lower / trailing arms & those will be here early next week.
Hoping to have everything installed in the next couple of weeks. |
05-25-2019, 10:15 AM | #13 |
So my car is still at the dealership. They tell me that the computer doesn’t say why it’s over heating. Will the computer know if the thermostat is opening or if it’s stuck? I can’t imagine there’s a sensor for that. Not sure what to do next?
05-25-2019, 05:07 PM | #14 |
2018 ZL1 1LE
Drives: 2018 ZL1 1LE Join Date: Aug 2017
You're gonna have to pull the thermostat and see if it's working properly.
