05-21-2019, 06:02 PM | #29 | |
X2... that's a great post.
There was a lot learned from the Z06 overheat issues. Kind of sounds like yours may have been trans but then I'm sure you had the gauges up to figure that out. Good way to finish the day testing the limits. ...or 0W40 |
05-21-2019, 06:57 PM | #30 |
Drives: ZL1 Join Date: Jul 2017
05-21-2019, 07:01 PM | #31 | |
It's 0W40 for all the Vettes and ZL1's on the street and track now so no oil change needed just for the track. I wouldn't change anything for AutoX but your run at COTA might be a good case for 15W50. https://www.amazon.com/Mobil1-123875...s%2C170&sr=8-8 |
05-21-2019, 08:26 PM | #32 | |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
RSFR, no wonder you're overheating and id say you're pretty lucky she didnt go boom, as W30 is insufficient viscosity for track duty for any V8 Camaro. Here's a link for ya which should hopefully assist: https://www.camaro6.com/forums/showthread.php?t=552667 Cheers! |
05-22-2019, 11:24 AM | #33 |
Drives: '18 ZL1 1LE Join Date: Mar 2019
For what its worth - I was running 15w-50 and my PDR showed a peak oil temperature of 270 for most of the sessions. Again, this is driver dependent, but I was very happy with the oil temps on what ended being a very hot day.
05-22-2019, 12:26 PM | #34 |
Drives: 1LEs Join Date: May 2009
What enhanced trans cooling hardware?
05-22-2019, 01:23 PM | #35 |
Drives: 2019 ZL1-1LE A10 Join Date: Jan 2017
They added an additional trans cooler on the ZLE A10. They also changed the tuning and shift points on the ZLE A10 and differential is tuned different too.
19 ZL1-1LE A10
05-22-2019, 01:37 PM | #36 |
Drives: 2019 ZL1 1LE A10 Join Date: Jan 2015
RSFR,
You know my secondary cats have been eliminated & I've put blankets on the primary cats & DEI shielding on the A10 & eLSD cooling lines where they get near the primary cats. Also, DEI tape on the rest of the eLSD cooling lines, running all the way back to the eLSD. I was running Mobil 1, 15w-50w, data shows oil peaked @265F and trans peaked @230F.
Ryker #29
2019 ZL1 1LE A10 2015 Z/28 #809 |
05-22-2019, 01:49 PM | #37 | |
As per my question, I was asking about hardware changes not software. |
05-22-2019, 01:55 PM | #38 | |
The oil "cooler" is as much as a warmer as a cooler, a real oil cooler would not flow into the radiator IMO, it would be a stand alone. I've read that most people see a peak oil temp drop of about 30-40F degrees going external oil cooler.
Ryker #29
05-22-2019, 01:59 PM | #39 | |
"They added an additional trans cooler on the ZLE A10." |
05-22-2019, 02:18 PM | #40 |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
In this article, it mentions Chevy added a new transmission oil pan and an additional cooling duct for the steering gear while tuning the A10 for the 1LE. Everything else is the exact same as the ZL1 non 1LE A10.
https://www.caranddriver.com/news/am...-transmission/ |
05-22-2019, 02:42 PM | #41 | |
https://media.chevrolet.com/media/us...amaro-zl1.html "This new transmission comes with many changes that live up to the requirements of the 1LE performance package. Unique calibrations were made to the transmission, electronic limited slip differential and performance traction management system. The front and rear Multimatic DSSV® (Dynamic Suspension Spool Valve) dampers have been tuned to accommodate the quicker shifts in weight transfer. New hardware includes a new transmission oil pan and an additional cooling duct for the steering gear." |
05-22-2019, 09:01 PM | #42 |
Exactly. I was backing up your statement.
