05-15-2019, 10:39 AM | #1 |
Shadow Gray '19 ZLE M6
Looking For 19x12 // 19x11 Wheels (ZL1 1LE size & offset)
Searched around, but haven't seen a thread like this. If it's a duplicate, my apologies in advance.
I'm looking for a track set of wheels for my ZL1 1LE. I'd like to keep the stock sizes / offsets. The plan is to move my stock Good Years to the track wheels and put Michelin PS4S on the stock wheels for the street. Since they're a track wheel and won't be on the car nearly as often as the street setup, I'm not looking to break the bank. Something affordable, yet in stock weights or lighter, works great. I know I just missed the Apex group buy, but I wasn't totally sold on the ARC-8s. I want to consider other options before making a purchase. I see a lot of brands mentioned (Apex, MRR, HRE FlowForm, etc.), but not a lot of prices listed in the Sponsor Classifieds or this forum. More importantly, I notice a lot of the offerings for our cars come only in 20 inches, or if they're offered in 19 inch, they typically don't go as wide as 12 inches. Thus, I'm looking for recommendations of aftermarket brands / wheels that make 19x12 & 19x11 wheels in the correct ZL1 1LE offsets. And given I'm not trying to spend an arm and a leg, it's most likely that I'm looking for a rotary formed / flow formed wheel. Any suggestions? Thanks!
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
05-15-2019, 11:05 AM | #2 |
Drives: Fastish Join Date: Jan 2019
Your general options for 19"wheels that actually "fit" the ZLe, are OEM, OEM Z28, BCForged, Finspeed, and Apex...
Thats about it. Apex is the only one I put in "Affordable".... the rest are 2k+, but are also track worthy |
05-15-2019, 11:12 AM | #3 |
Drives: 2018 ZL1 coupe Join Date: Nov 2018
Spent quite a while researching this, for the same reason, and UrbanKnight pretty much covered it...
OEM ZLE, Apex and $$$ aftermarket. MRR has a ZLE rep (M716) in 19x10.5 and 19x11. That's probably the least expensive option. |
05-15-2019, 11:22 AM | #4 |
MRR’s Reps do not fit in 19”, only 20” per them
05-15-2019, 11:33 AM | #5 | ||
05-15-2019, 11:51 AM | #6 |
Drives: camaro Join Date: Nov 2011
Guys I Also have noticed this issue and I just may have a solution.
Making wheels for this car is difficult but can be done, we just need to pass the hurdles 1. we need to build a 19" with a barrel large enough to clear the calipers and also the spokes 2. make a wheel 11 wide and 12 wide in which the only car it can be sold to is this car. 3 the affordable part/ making a wheel designed for a limited vehicle means that sales wont be crazy so the cost of production molds etc all get factored into a limited amount of part numbers But here is my solution let me know if this works for you guys Solution 1 ( and the most affordable ) we can produce for example our M755 design in factory specs 19x11 5x120 11et 66.9b 19x12 5x120 41et 66.9b Gloss Black Flow Forged Construction priced at 1650.00 a set The catch: will need to be a group buy and the minimum number to reach in order for us to process is 25 sets total 2nd option: I can do the same factory specs in a 2pc forged wheel similar to what I posted on another thread, we do a group buy with a minimum of 20 sets just to get the price down but it will still be above 2 grand simply cause is forged and a 2 pc |
05-15-2019, 12:55 PM | #7 | |
05-15-2019, 01:18 PM | #8 |
05-15-2019, 01:20 PM | #9 |
05-15-2019, 01:28 PM | #10 | |
in order for us to create a new design and keep the cost low then a group buy is still a option but the minimum required jumps up/ unfortunately when a group buy minimum is to high it will be a super long wait time or it will not reach its goal. another option is the M228 in a one piece forged model if we can do a group buy of 20 sets minimum then the price will be at a really good affordable rate. |
05-15-2019, 01:30 PM | #11 | |
05-15-2019, 03:37 PM | #12 | |
SABIO
That would be kool. An instantly recognizable Camaro Wheel.
05-15-2019, 05:16 PM | #13 |
05-15-2019, 05:18 PM | #14 |
if we can get some momentum i can make it happen / just got to get 20-25 Zl1/1LE cars on board.
