03-16-2019, 06:28 PM | #1 |
2018 ZL1 1LE
Drives: 2018 ZL1 1LE Join Date: Aug 2017
Caliper Pin Punch...
I'm changing my pads out to ceramic. What are you guys using to push out the caliper pin? I know that Brembo makes their own and sells it for $30.00, but I'm sure you guys have some ideas. Also, just curious how many of you are sanding the rotors when changing out the pads and if you are doing this, are you sanding both the inbound and outbound rotor surface. Thx guys!
03-16-2019, 06:48 PM | #2 |
Drives: ISO ss 1le Join Date: May 2018
Buy a set of harbor freight punches and use a drill start to dimple the end of them. Works like a charm.
03-16-2019, 08:36 PM | #3 |
2018 ZL1 1LE
03-16-2019, 09:47 PM | #4 |
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
03-16-2019, 11:09 PM | #5 | |
2018 ZL1 1LE
05-03-2019, 11:16 PM | #6 |
Drives: 2019 Satin Steel 1SS 1LE w/ PDR Join Date: Sep 2017
05-04-2019, 12:52 AM | #7 |
Drives: 2023 Silverado LTZ, 2022 Camaro 2SS Join Date: Jul 2010
I think he was referring to an automatic center punch that puts a dimple in a piece of metal to help the drill bit not move around. I’m not sure it is needed if you are careful.
Currenent rides: 2020 SW ZL1 A10 2019 SW 2SS A10 2017 SW Silverado LTZ |
05-04-2019, 11:13 AM | #8 | |
Drives: gas powered Join Date: Jan 2019
Im not 100% sure what he meant but punches usually come to a point where to knock the pins out .....and not slip..the end needs to be concave. I would also recommend a rubber tipped hammer JIC you do miss you dont chip your powder coat on your calipers. |
05-04-2019, 11:47 AM | #9 |
Thank you Al Oppenheiser!
Flat punches work just fine if you pay attention to what you're doing. Or you can drop more coin for one of these...
https://www.racingbrake.com/product-p/ccp01.htm I guess for someone changing pads weekly at the track a dimpled pin and convex punch may be worth the extra one-time work. But like the RB punch it seems like overkill to me. |
05-04-2019, 01:31 PM | #10 |
Right with just a little care a plain punch works perfectly, there's absolutely no reason to drop $28 on a "Brembo" punch.
