12-06-2017, 01:28 PM | #15 | |
Drives: 2017 SS 50th Jan 17 2018 Join Date: Nov 2017
that is my understanding as well, had some Michelin new all season that were really squirrley the first couple of hundred miles in the corvette, now they are fine. stig eh
12-06-2017, 01:38 PM | #16 |
Drives: 2016 Camaro 1LT Join Date: Apr 2016
Good review and pretty much lines up with Tire Rack's review. I also just purchased these for my 1LT and I really like them so far. But mine is a daily driver and I don't track the car so I don't need to worry about pulling g's. The ride is smooth, turn in is good and I love the look of them. I would def recommend for a daily driver tire, especially at $145/each (245/40/20).
12-27-2017, 11:39 AM | #17 |
Drives: 2017 Camaro 1 SS Join Date: Jun 2016
UPDATE:
They've gotten a little better (phew). Adjusting the pressures helped (to be expected) and they change direction a little better now with some miles on them. They still bounce a bit on the highway, which took getting used to - but overall, I don't regret putting them on my car since they were just so damn cheap. I do still stand by my initial review, but let's just say that everything I was unhappy about has just reduced in severity a bit. I was able to hit 1.01 with them recently so they're sticky, no doubt about it, but they still need more steering input and they just wander more. Maybe it's just me still getting used to them, but I'm usually pretty quick at adapting to changes on my car. Anyway - no need to write another book here, bottom line? If you don't need a Y rated tire (they're W rated) or you just use them as a DD tire, why not. If they were more expensive, I'd say steer clear, but they're so cheap that it's hard to go wrong. Final Grade? I'd give them a C+ / B-. Could be a lot worse...
1SS - M6 - Silver Ice Metallic - Dual Mode Exhaust. Light, Simple, Fast. "If everything's under control, you're going too slow" - Mario Andretti Last edited by Canyon Carver; 12-27-2017 at 11:59 AM. |
12-27-2017, 11:49 AM | #18 | |
I just posted a short update and it sounds like we had similar experiences with these tires. They have improved with pressure adjustments and age, to be sure...but my initial feelings still stand, just less extreme. I look forward to getting the Firestone's out on a track day, so your opinion for the track days were welcome, and good to hear. You really prefer the Goodyears from a Dig? For me, the Firestone's have been hooking up better...are you in cold temps? Just curious. Are you MT or AT? I've got the 6spd.
1SS - M6 - Silver Ice Metallic - Dual Mode Exhaust. Light, Simple, Fast. "If everything's under control, you're going too slow" - Mario Andretti |
12-27-2017, 04:22 PM | #19 |
Drives: '16 Garnet Red 1SS Join Date: Mar 2014
Seems like all tires need to get worn down a bit, to remove the tire mold release chemicals.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
01-04-2018, 06:42 PM | #20 |
Drives: 2016 1SS (12/10/2016) Join Date: Jul 2015
I've got the A8, so trying to put down all that power in first gear is a challenge for any tire. I ran a whole summer on the Firestones... Granted, this last summer was cooler in average than the summer before, but I think I was typically able to hook up from a light just a little better with the stock tires. My only experiences were like I said, red lights on "cold" tires. Even on a warm summer day, they still needed some warm up before they would hook. Sitting in traffic for my 8 mile commute isn't ideal for getting anything up to optimal temps.
I'd like to be able to do a side by side comparison, it's possible I was romanticizing the Goodyears after the Firestones were so slippery their first couple hundred miles. |
01-07-2018, 10:04 AM | #21 |
OP, is your car stock power level? I’m considering getting these just for the rears on my car for some late night hard highway pulls.. I can’t find much that hooks up well, and ultimately end up wearing my rears out in 5-8k miles. If I can get a tire that hooks up alright, and is cheaper then I don’t mind wearing them out fast lol. How do you feel these hook up on a highway roll, full throttle? Currently I’m blowing conti extreme sports and PSS off at a punch. I expect that, but wearing the expensive tire out so fast stinks lol
2016 2SS/Hyper Blue/M6/NPP/Navi
Forged pistons Custom cut Brian Tooley Cam SW long tube headers 3" stainless mid pipe - Secondary Cat delete - High flow cats Port and polished heads-Double valve springs-platinum lifters & push rods Cam phaser limiter - DOD delete P1SC-1 Pro Charger 3.7 pulley Stage II intercooler 667rwhp 577ft lbs |
03-03-2018, 11:07 AM | #22 | |
1SS - M6 - Silver Ice Metallic - Dual Mode Exhaust. Light, Simple, Fast. "If everything's under control, you're going too slow" - Mario Andretti Last edited by Canyon Carver; 03-03-2018 at 11:11 AM. Reason: Grammar |
03-03-2018, 12:41 PM | #23 |
BL1ZZRD
Drives: '16 Camaro 2SS, '20 Equinox Redline Join Date: Jul 2009
Im thinking about pulling the trigger on these but Tire Rack has the fronts on backorder till 3/31. Anyone know where to buy these now? OP great review! Thanks!
03-06-2018, 03:13 PM | #24 | |
I think simple tire has them - and cheaper...that's where I got them. https://simpletire.com/
03-08-2018, 01:40 PM | #25 |
Drives: Kubota 2640, 83 BMW R-65, 2017 1 SS Join Date: Nov 2016
Good review...Thanks CC.
My oem Goodyears have maybe half the summer left in them...I was thinking Firestones as they are a bunch cheaper. THIS really helped. |
03-09-2018, 07:53 AM | #26 |
BL1ZZRD
Mine are on order from the local Firestone dealer. Rears are in stock but he told me about a month for the fronts. Firestone is building them right now. Big demand for these thus the shortage in stock.
03-11-2018, 11:54 AM | #27 | |
03-11-2018, 12:09 PM | #28 | |
On the street, they're still working well. They have lightened up the steering a bit, which I've gotten used to. I've learned that at high pressures, they don't hook up as well from a dig (to be expected). But they're just fine in town, not as loud as the Goodyears and aside from getting a little "bouncy" with a pogo effect on some road surfaces, they're generally comfortable.
