01-14-2024, 06:34 AM | #1 |
Drives: 2022 Chevy Camaro 2SS Redline Join Date: Dec 2016
Soler Performance Ported 91mm TB Any Good? Any options?
What has been your experience with the Soler Performance ported 91mm TB? I'll be adding the upgrade to my 2022 Camaro 2SS. I'll also be adding the following additional upgrades.
• K&N Performance Intake Kit Model: GRP-KNN71-3092 • 250-609 AIRAID THROTTLE BODY SPACER Model: 250-609
For the win!
01-14-2024, 07:48 AM | #2 |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
TB Spacers are snake oil.
+1 for Soler TB's. We use Mike's TB's on our stuff. Great product along with great customer service. |
01-14-2024, 08:59 AM | #3 |
These are what mods I would look into:
-LT2 manifold -LT5 tb -Rotofab -Flex Fuel sensor
2016 NFG 1SS A8
01-14-2024, 09:17 AM | #4 | |
Having FUN in the SUN...
Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
+1... I assume the MSD + 103mm is not needed until a H/C package?
2022 M6 ZLE: Katech CNC Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild CC Coated ARH + AWE Touring + Magnaflow Center X + E85 + MSD Coils + Banks iDash + JMS Booster + Synergy Fender Tank ALL the RED Rear End BMR Goodies + JRE Terminator Cam Package + Remote Tuning and Moral Support from TED @ JRE BMR Motor Mounts + DMS Front HX + FIC 30's + APEX SM.10's + 305/345 R888R's = 770rwhp 785rwtq @E50 13.5psi |
01-14-2024, 10:26 AM | #5 | |
Snackbar Tuning
King speaks gospel. 100% agree. I know you didn't ask about that. But these are the best bang for the buck mods on the LT1 and will add a very noticeable bump in power without adding headers. Headers would make it even better. |
01-14-2024, 09:38 PM | #6 |
Drives: Camaro SS 6mt Join Date: Jul 2023
Im running a soler performance 107mm which is just a 103mm that has more flow or something. It hasnt steered me wrong yet and it was one of the cheaper options out there but is a quality product imo.
01-16-2024, 08:40 AM | #7 |
My brother put one of those on his C7 Z06 and it made the timing go negative at idle. Fwiw it had a Katech 103mm on it prior with no issues. I wasn't going to adjust the torque model to get the timing back up since it was already done with the Katech and shouldn't have changed imo. So he sent it back.
2016 NFG 1SS A8
01-16-2024, 08:59 AM | #8 | |
Drives: 23 2SS 1LE Join Date: Feb 2019
The only possible exception is the Rotofab, only because JLT is working on new intakes for our cars that should be available in the next few months. After I see testing on those I will make my decision.
Instagram: RideWithDanger
Radiant Red 23' 2SS 1LE 1100: 11/14/22 | BUILT: 3/16/23 2000: 2/17/23 | 4200: 5/8/23 3000: 2/27/23 | 5000/6000: 5/15/23 Black on black 2019 3LT RS Camaro. 1100: 3/7/19 | 4200: 4/15/19 3100: 3/15/19 | 4800: 4/23/19 3400: 3/22/19 | 5000: 4/25/19 Built: 4/8/19 | Home: 4/26/19 |
01-16-2024, 06:10 PM | #9 |
Now that I've gotten some feedback on this part, I would also like to know if adding a 250-609 AIRAID THROTTLE BODY SPACER would benefit anything? or create additional issues?
For the win!
01-16-2024, 06:36 PM | #10 |
Drives: 2016 2SS Convertible Join Date: May 2012
As Megahurtz pointed out earlier, there is no benefit. It would be a waste of money.
01-17-2024, 10:42 AM | #11 | |
Spacers do nothing unless your talking carburetors. Adapters are a requirement for installing the 95 mm LT5 Throttle body on a Gen6 Camaro or ZL-1. 3 reasons, Rotation, Bolt pattern, and taper from 95 to 87. Now one would say why put a 95 mm on a 87 intake. Answer Think, the Shaft and Blade take up some of that 87 mm so a 95 will flow everything the 87 intake can. The 87 TB can't flow what the 87 intake can. It flat works. We have 95mm TB and adapters in stock all the time as we use them in Many of our builds. https://jannettyracing.com/products/...251238f5&_ss=r We offer them in our Entry level Flex fuel upgrade also. Ted.
www.jannettyracing.com
