Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > Exterior Parts & Accessories
Old 11-15-2022, 02:53 AM   #1
RPIDon
RPIDon's Avatar
Drives: Camaro
Send a message via AIM to RPIDon
Morimoto Custom Led Tail Lights MOR-1008 for 2016-2018 Camaro
With GM discontinuing their custom clear/dark tail lights your custom tail light choices are limited. These great looking custom tail lights use bold European styling cues to give your Camaro a bold look that is sure to be noticed on the street or track.
No doubt the sixth-gen Camaro is a capable car, and if you've already upped the ante by making more power, new wheels, and fatter tires, then it's time to ditch the stock lighting setup too. Morimoto's unbeatable XB LED fog lights have been top sellers in our catalog forever, and we couldn't be more excited to see the lineup expand with offerings such as the new high-performance XB Camaro LED tail lights too!
COMPATIBLE: With all 2016-2018 Camaro's, these complete tail light assemblies will swap directly in place of the original Camaro tail lights, use all of the stock mounting points, and should only take around 30 minutes to install.
PLUG N PLAY: Wiring is easy too! The XB LED tails are designed to work without any special wiring. They will plug into the factory connectors for the stock lights and each assembly includes all necessary connectors, rubber seals, and pigtails for a plug n play install. No additional resistors, modules, etc needed!
STYLE: Inspired by the Lamborghini Aventador, while they look radical, they don't look out of place like other aftermarket options. The piano black finish matches the OEM trunk trim perfectly. The geometry flows with the body lines like a boss. The XB LED tails for your Camaro are available with either a smoked or red lens. Both will illuminate red.
WELL-BUILT: Their durable polycarbonate lens will resist the test of time, keeping the housings looking new for many years to come. The injection-molded ABS housing is light-weight and much stronger than comparable cheap alternatives. The XB Tail lights may not be the cheapest new tail lights for your Camaro, but they're OE quality, and as the saying goes, you pay for what you get.
Fitment: 2016, 2017, 2018 Chevrolet Camaro
RPIDon is offline   Reply With Quote
Old 03-23-2023, 12:34 AM   #2
RPIDon
RPIDon's Avatar
Drives: Camaro
Thank You for shopping at https://www.rpidesigns.com/shop/item...d-tail-lights/
