Old 06-14-2013, 08:03 PM   #1
pdiddy
Drives: 2011 2SS
fuse pull/good with custom tune?? 2 questions
So my car has been dyno tuned and I was wondering after reading 15 pages on the fuse pull thread should I do this I have an LS3 is is tuned for 91 octane is what I am told. The tunner said he would rather me run 91 then take a chance with the 93 fuels around here that could be really old and no good. So since it was tuned is it necessary to do this mod/hack and will it hurt anything to do this(like lose my custom tune)? I have never ran anything other than 91 and I am wondering if I should try 93, will upping the octane hurt since I am tuned for 91?
2011 2SS,fti th400, ECS 1500, Flex Fuel, Boost built 376, squash fuel system
pdiddy is offline   Reply With Quote
Old 06-14-2013, 08:10 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
Drives: ...and they're both wrong
Yes it is still necessary, no it will not hurt your car.
Click to view my build thread
The Stig is offline   Reply With Quote
Old 06-14-2013, 08:25 PM   #3
skar
skar's Avatar
Drives: 2010 2SSRS headers/CAI/tune/corsa,
I was told with tune fuse pull not needed . Will not retard.
Stainless works headers/cats Roto fab CAI /
Corsa install and tune Livernois
TSW Nuburgring 9 &10" x 20 on Invos (315 & 275 )
JL Audio XD400/4 amp
Pfadt trailing arms & tie rods sway bars.
pedders street 1 package. ,Hurst short throw shifter
With bronze bushings .
skar is offline   Reply With Quote
Old 06-14-2013, 08:36 PM   #4
The Stig
The Stig's Avatar
Only way that's true is if your tuner copied the high octane table to the low one - in which case you better pray someone never puts low octane fuel in the car.
Old 06-14-2013, 08:38 PM   #5
pdiddy
Drives: 2011 2SS
by retard you mean running the 93 will not retard the timing. Or are you calling me a retard lol
Old 06-14-2013, 08:40 PM   #6
The Stig
The Stig's Avatar
He's saying that the car won't pull timing if you put 87 in it.
Old 06-14-2013, 08:42 PM   #7
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Absolutely not! It's tuned? Pulling fuse will do nothing!
2001 ws6, 40k miles, Ls3 416 stroker, short block built by PER the rest by me. LPE Ls3 heads milled to 12-1 comp, FAST 102, NW 102, kooks 2", dual DMH cutouts, Magnaflow C/B, BTR cam + springs. Full UMI suspension.
litle88 is offline   Reply With Quote
Old 06-14-2013, 08:42 PM   #8
pdiddy
Drives: 2011 2SS
Stig thats why I was wondering when I had my gears put in I have a feeling the guy out a couple gallons of cheap fuel in it when he had the car. CARFX of Tulsa tunned it I am not sure how he did the table I can probably find out but still trying to decide if I should do the pull and start running 93
Old 06-14-2013, 08:55 PM   #9
thahemp
Geek
thahemp's Avatar
Drives: 2012 Black LS3
Pulling fuses with a tune will still reset your long term fuel trims. It could be useful in certain circumstances, but not yours.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
x = ~x
thahemp is offline   Reply With Quote
Old 06-19-2013, 06:11 AM   #10
skar
skar's Avatar
? On my Livernois did they use two tables high and low .
must find out.......Andy?
Old 06-19-2013, 06:50 AM   #11
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
Depends if your 2 tables are the same or not. My high octane table is tuned for 93 octane. Still have the low octane table, which it will revert to for bad or lower octane gas.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Badbubba is offline   Reply With Quote
Old 06-19-2013, 06:51 AM   #12
The Stig
The Stig's Avatar
Most reputable tuners won't copy the high octane table down to the low one as it can do serious engine damage if you put low octane fuel in the car.
Old 06-19-2013, 06:57 AM   #13
Denis
Denis's Avatar
Drives: 2010 SS
I have wondered this exact thing for a while now but never asked. Now I'm curious if it would matter with my JRE tune.
Denis is offline   Reply With Quote
Old 06-19-2013, 07:18 AM   #14
Badbubba
GrINned & JUICEd
Badbubba's Avatar
I was told by JRE that they do not mess with the low octane table. So 2 tables. Yours may be different though???????
