11-10-2022, 04:43 PM | #71 |
Drives: 2018 2SS Camaro Join Date: Mar 2020
I've had a 2.9 Gen 5 Whipple 175RF for about 3 years now. Apart from the drive coupler that disintegrated and bypass valve that I am currently needing to replace (torn diaphragm) I havent had any real issues.
Question; why didn't Whipple simply further develop the 2.9 rather than re-engineer for new rotor packs etc? Was it because of so many reported failures & issues?
2018 2SS, Hyper Blue, Australian HSV delivered
2.9L Whipple 98RON tuned 650hp/850Nm Elite Engineering E2 Catch Can Eibach Prokit springs Mamo LT1 Ported TB |
11-10-2022, 06:04 PM | #72 | |
11-10-2022, 09:14 PM | #73 | |
11-10-2022, 09:30 PM | #74 | |
Drives: 2017 Chevrolet Camaro ZL1 Join Date: Jul 2018
Obviously this is not apples to apples, but I’ve been watching some of the Mustang ET’s and traps with the Whipple’s to start getting ideas relative to the 2650’s. The quickest and fastest I’ve seen has been in the 7.90’s at ~178 MPH. That is at a 3880 lb race weight, so you can safely assume he’s making around ~1430 RWHP through a TH400. That is the new Whipple 3.8 as well, not the 3.0. I think we’ll hit 178 with my 2650 all in, but my car is a little over 100 lbs lighter also. Doesn’t mean a lot, but more data points in absence of the new Whipple’s on our cars. Lol
2017 ZL1 - PB 8.05 @ 172 MPH @ 3730 lbs @ 70 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned |
11-11-2022, 07:41 AM | #75 |
Whipple 3.0 has been 171 in the 1/4. I think midnight performance went even faster but I can't find the post to back it up.
2016 NFG 1SS A8
11-11-2022, 04:29 PM | #76 |
I've said it before that if it performs on the Lt1 like it does on the 5.0 its going to be a formidable blower to whatever is out there in a PD SC.
11-12-2022, 09:53 AM | #77 |
I don't know why it wouldn't. The Whipple 2.9 performs similar on a Coyote as it does the LT1. It's a 148-150mph 1/4 mi supercharger max on a full weight car. It's out of airflow with the rotor pack to go any further. A Kong X port 1.7 will make the same power but the 2.9 still has better cooling. The 3.0 has different rotors(4x3 vs 4x5) to allow it to flow much more air. Coyotes have seen 100+ whp gains switching over from a 2.9 to 3.0 with boost levels in the 15-17psi range. Obviously on a 10psi the gains are likely going to be much less. I think I seen a report of +30whp on a low boost setup.
2016 NFG 1SS A8
11-12-2022, 09:59 AM | #78 | |
It definitely seems like the 3.0 is going to be like the 2650 performance and efficiency wise. When I went from the 2.9 to a non-ported 2650 it picked up over 90 RWHP at the same MAP level. I bet Jokerz and others will be able to port it to match a ported 2650 as well. I’m curious to see if the gains stay linear at really high RPM’s (25k+).
11-12-2022, 10:06 AM | #79 | |
2016 NFG 1SS A8
11-12-2022, 10:11 AM | #80 |
Drives: 24 Sliverado 1500 ZR2, 2017 ZL1 Join Date: Feb 2021
Can anyone that has seen one verify if it is already set up for port injection?
Finally on the way to 1K.....
11-12-2022, 11:35 AM | #81 | |
We are working on a price for those who want to upgrade from the 2.9 to the 3.0. I should have that in the next 30 days As for port injection as of now it does not accept it but we are also working on it We have just released the LT1 Camaro kit and as of now there has not been any back to back testing with the 2650
11-12-2022, 11:38 AM | #82 | |
https://kongperformance.com/collecti...e-supercharger
11-12-2022, 12:04 PM | #83 | |
2016 NFG 1SS A8
11-12-2022, 12:12 PM | #84 |
Yeah it’s been painful waiting for Whipple to get back in the LTx game. This 3.0 blower was supposed to be out last summer, then fall, then December for January 2022 shipping, etc etc.
