Old 04-17-2022, 05:28 PM   #1
Ninjor
Ninjor's Avatar
Drives: 2022 2SS 1LE
New 2022 SS 1LE cylinder 1 misfire
4500 miles on the car stock engine only mods are rear toe/control arms for camber and a big wing. Was at a lapping day and I was using the auto rev match downshift, mid lap it turned off auto rev and wouldnt turn back on then my dash said "Service rear axle", "Service ESC" and check engine light came on and engine was running super rough.
Plugged in an osd reader and it says cylinder 1 misfire.
Is this the dreaded lifter failure?
Waiting on a tow truck 😞
Ninjor is offline   Reply With Quote
Old 04-18-2022, 03:12 AM   #2
Puddin
Lifter or valve spring would be my guess.
Old 05-17-2022, 12:12 PM   #3
joeyazzata29
j1ss
Drives: '21 2SS 1LE
I had this issue with a 2ss 1le with 4900mi, would only do it on track. Battery reset would temporarily fix the issue. Ended up being a coil pack wire pin that had backed out of the plug. Hoping your issue is as simple as mine, even tho mine took 2 ruined track days, 3 trips to the dealer, for me to eventually find myself and fix. Wishing the best
joeyazzata29 is offline   Reply With Quote
Old 05-17-2022, 12:20 PM   #4
Coded4SS
Drives: 2020 1SS 1le
If you go to the dealer wash your car first. If your tires look like hell then put on another set. Don't tell them anything about the track
Coded4SS is offline   Reply With Quote
Old 01-08-2024, 01:06 PM   #5
Eric_Bloom
Drives: 2022 Camaro SS 1LE
Hey Ninjor, having the same issue on my 22 camaro ss 1le: did you ever figure out what the issue was?
Eric_Bloom is offline   Reply With Quote
Old 01-08-2024, 04:19 PM   #6
SomeGeoffGuy
SomeGeoffGuy's Avatar
Drives: 2023 2SS Convertible
I thought they were honoring race day warranty for 1LE? But yea, I still wouldn't tell them!
-Geoff
'16 2SS Convertible - White on white, mag-ride, NPP, nav. Sold!
'23 2SS Convertible -Same as above except orange.
SomeGeoffGuy is offline   Reply With Quote
