04-19-2021, 08:46 AM | #29 | |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
04-19-2021, 09:13 AM | #30 | |
Drives: 2023 SS 1LE Join Date: Mar 2020
04-19-2021, 09:20 AM | #31 |
I wish you could honestly. I would encourage you to find anyone nearby that has it installed to give it a listen. I certainly didn't spend $5K on catback exhaust for the C8 Corvette and my ZL1 for no reason, it really is that good.
04-19-2021, 09:47 AM | #32 |
OK, now I will assume there's no power to be gained by changing my catback except by removing it entirely and losing the ~70# weight
'20 ZL1 1LE A10,
04-19-2021, 09:51 AM | #33 |
04-19-2021, 01:33 PM | #34 |
Thank you Al Oppenheiser!
On an otherwise stock car, rump-end weight reduction is the only improvement from cutting off the suitcase, including the crimped pipes forward of the suitcase. And if you're a straight line kinda guy, deleting weight aft of the rear axle is probably not the 1st thing you want to go after. Power gains come when you start deleting cats. Aft of the cats, you only affect weight, sound and/or tailpipe bling.
04-19-2021, 01:47 PM | #35 | |
'20 ZL1 1LE A10,
04-19-2021, 02:06 PM | #36 |
Drives: ZL1 Join Date: Jan 2019
Would love to install one of those loud exhaust systems before switching to EV,, only problem is, in UAE car must have the stock exhaust while performing the annual reg. inspection or when selling.
04-19-2021, 02:20 PM | #37 |
Drives: 2018 ZL1 Coupe NFG M6 Join Date: May 2017
I'm pleased with my Kooks axleback/Borla midpipe combo:
https://www.youtube.com/playlist?lis...-OiCpJ0Rh12GUp
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School 2017 Colorado Z71 <- Daily 2018 ZL1 M6 <- Not Daily |
04-21-2021, 08:25 AM | #38 |
I suppose if we could dyno a car with and without an aftermarket catback we could quantify hp gain precisely, but here's what Corsa just said to me:
"It would be able to free up a few HP, as it will relieve all back pressure in the system (aside for the hi-flow cats)." So the bottom line appears to be --- do an aftermarket catback for sound not hp.
'20 ZL1 1LE A10,
04-21-2021, 08:41 AM | #39 | |
04-21-2021, 08:53 AM | #40 | |
I ordered the Corsa Npp because it's that only exhaust that truly goes from mild to wild. +12db change in sound from closed to open. I don't really care if it gains power or not. The problem with the stock muffler is it gets tinny and raspy sounding with any exhaust mods up stream that do add power. So plan on a axleback if you do headers or cat deletes.
2016 NFG 1SS A8
04-21-2021, 09:08 AM | #41 | ||
04-21-2021, 09:53 AM | #42 |
I've got Kook LT and green cats. I like how my exhaust sounds with stock catback and have no plans to change it. I'll test with the Camaro club this year, so I suppose it's possible that I will hear an exhaust that sounds better, but it's going to have to sound a lot better for that kind of money.
'20 ZL1 1LE A10,
