Old 06-19-2017, 01:06 PM   #1
AxiomVerge
AxiomVerge's Avatar
Drives: 2017 Mosaic Black M6 1SS Vert
Procharger vs Magnusson and Heat saturation
I was thinking of getting Magnusson supercharger for my SS convertible, but the local shop said he recommended a Procharger as there would be heat saturation with any supercharger that sits atop the engine in Nevada or Arizona, and they lose about 50 hp once heated up.
It's currently around 115 degrees here but no idea how that affects what kind of supercharger is best. Does anyone know about this?
The reason I was thinking of a PD was since the convertible is a good 250 lbs heavier that the immediate boost would be an asset.
He's asking $2000 to install and tune.
2017 Mosaic Black 1SS Convertible M6 / MRC / NPP
Magnuson Heartbeat, Rotofab
Previous:
2008 Corvette Convertible
2007 Pontiac Solstice GXP
AxiomVerge is offline   Reply With Quote
Old 06-19-2017, 02:23 PM   #2
Cdflyer
Cdflyer's Avatar
Drives: 2016 1SS 6speed
The ProCharger will heat soak as well. But it also isn't "quite" as bad not being attached. But it is still contained under the hood.
2016 1SS M6 P1SC Stg II 592rwhp/548rwtq (for now)
GForce Outlaw axles & driveshaft, TSP 2” LT’s, turndowns, RTS S71 drag pack with radials.
Cdflyer is offline   Reply With Quote
Old 06-19-2017, 06:55 PM   #3
JANNETTYRACING
JANNETTYRACING's Avatar
The Magnuson supercharger has a constant supply of cool water running through it, Heat saturation would only be a problem if the water pump quit.
Feel free to call with any questions.
Ted.
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 06-19-2017, 07:48 PM   #4
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
Mine has no problem with heat soak even with back to back runs at the track in 90 plus temps. I ran 10.78@129 when it was 92 degrees and DA was over 3600.
Old 06-19-2017, 11:20 PM   #5
AxiomVerge
AxiomVerge's Avatar
What is DA? I take it 3600 is good?
Sent from my SM-G935T using Tapatalk
Previous:
Old 06-20-2017, 05:20 AM   #6
laynlo15
laynlo15's Avatar
3600 sucks a lot. Good DA is 0 or negative, that's when the motor can make maximum hp and torque. Track becomes slick and greasy.
Old 06-20-2017, 08:57 AM   #7
DenverTaco07
DenverTaco07's Avatar
DA = Density Altitude
https://wahiduddin.net/calc/calc_da.htm
Old 06-20-2017, 09:25 AM   #8
jwdominick
Drives: 2017 50th 2SS
I own both, I have a tvs2300 on my denali pickup and a procharger on my camaro. the maggie is great and keeps the iat cool enough for what i do with the truck, but not sure it'll stay cool in a camaro under constant abuse. my procharger gets warm if i am constantly beating it, but cools rather quickly after i ease up.
jwdominick is offline   Reply With Quote
Old 06-20-2017, 11:31 AM   #9
AxiomVerge
AxiomVerge's Avatar
Originally Posted by DenverTaco07 View Post
Thanks, looks like I can expect between 4200 and 5900, estimating with this (http://airdensityonline.com/track-fo...otor_Speedway/)
Previous:
Old 06-20-2017, 12:00 PM   #10
1968ss350
1968ss350's Avatar
Drives: 1968 Camaro SS 350
I feel if the heat was such an issue then large auto manufactures wouldn't equip vehicles with PD blowers from the factory. Remember the Magnuson is built to OE specs and it's underdriven. I live in Los Angeles and haven't noticed any power drop with this heat wave. Not 120* only around 90* but I'd be more concerned with what type of sunscreen I was going to apply with a Vert in 120* weather
1968 Camaro SS 350 Lemans Blue
-350 10.4:1 comp, Edelbrock Etec 200 heads, Comp XR288HR cam,AED750dp worked, Tremec TKO 600, console gauges w/tic toc tach, Moser 12 bolt, 4 wheel Willwoods
Hyper Blue 2SS/6 speed, NPP, MRC, Nav, 5LQ 6 piston brakes, Black split spoke, Magnuson 2300 Heartbeat Supercharger, Flowtie upper grill
1968ss350 is offline   Reply With Quote
Old 06-20-2017, 01:28 PM   #11
AxiomVerge
AxiomVerge's Avatar
So I called another Las Vegas performance shop and he said that the first shop I called was completely wrong for the same reasons already mentioned above (the liquid cooling, the fact that Chevy uses a PD from the factory anyway). He also said that if anything the ProCharger would be hotter. I won't mention either shop's name until I know what's what but shop #2 seems to have a bit more reputation, especially in the Corvette forums.
Previous:
Old 06-20-2017, 01:44 PM   #12
DenverTaco07
IDK about a centri with an air-to-air intercooler being hotter, I think the majority consensus is that air-to-air is way more efficient and your IAT lower with centri - i mean it's one of the known pro's of a centri over a PD.
At least in my limited knowledge of the topic.
Let's not forget early C7 Z06 heat soak issues - just because OEM use them, doesn't mean they aren't hot.
Old 06-20-2017, 02:54 PM   #13
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
There are many variables that affect which choice to make. My first question is how much power do you really want to make? The second question is where are you going to drive the car, specifically will you ever put the car on a road-racing track? You are really going to have to be driving gonzo on public roads to get these cars really hot. There is just too much airflow through the intercoolers in the grill on the highway for it to really be a problem. As soon as you coast for a little bit everything comes right back into normal ranges.
Honestly I favor the PD blower and as long as you plan to run the stock pulleys it should be fine but if you start to increase the blower speed that southern heat makes a huge difference and they get really hot if they can't get a rest..... like what happens on a road course.
Nothing against drag racing but 11 seconds of wide open throttle isn't much when you get several minutes of rest on the return road, try to run the return road wide open and hit the 1/4 wide open for 30 straight minutes and see what happens to your temps...and 1/4 mile times. That is what happens when you road race.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 06-20-2017, 03:07 PM   #14
Joe's_cool_1le
Drives: Black 2017 Camaro SS 1LE
I do personally like air to water systems. ProCharger now has one as well.
ProChargers systems
HO air-to-air - Standard on the HO system (upgradeable at time of purchase to Stage 2)
Stage 2 air-to-air - Standard on STG2 system (upgradeable to "Race" unit at time of purchase)
Race air to air - Largest available air-to-air unit for maximum cooling of charge temps
Competition Race air to water - For competition use and power levels exceeding 1,000+ hp
More info here.
http://www.camaro6.com/forums/showthread.php?t=493866
2017 1LE SS Black - Mods - Forged - lowered compression - BTR custom Cam - Whipple, 3.500 upper and 8.0 lower pulley, Roto-Fab, 1 7/8 Kooks headers, off road pipes, & 3" Kooks full exhaust. LT4 fuel system, with Alky single nozzle running 100% meth. (not installed yet) DSX Tuning flex fuel and DSX tuning Aux pump
Joe's_cool_1le is offline   Reply With Quote
