01-01-2016, 09:30 PM | #29 |
Consistently inconsistent
Drives: 2015 2LT Summit White Join Date: May 2015
That chart can mislead, as ANY customer complaint is included even if not duplicated/confirmed.
Thanks to MRR, I have some SWEET wheels! Thank you!
2015 2LT Ported TB, Ported intake, JACFAB intake spacer, Borla exhaust, IPF 91 tune, Complete 1/LE suspension, Brembo brakes, Goodridge lines, Elite catch can, CAI with Thermo-wrap, 275/40-20 x 10's all around, Z/28 spoiler, GM splitter, Alpine/Polk stereo with AudiControl interface. |
01-02-2016, 12:19 PM | #30 |
Drives: 2016 GT350 Join Date: May 2015
Older 3.6's due have an issue with timing chains, between 60-100k, most will wear the guides or chain enough to set a code. Oil changes and oil levels are critical on these motors. Price in our shop runs $1400-2200 depending on model.
"Life is hard, it's harder if you're stupid" John Wayne
06-12-2017, 08:27 PM | #31 |
Drives: 2011 CAMARO 1LS SGM Join Date: Jun 2017
2011 3.6L LS
JUST READ THE THREAT, I REPORTED MY TIMING CHAIN FAILURE TO THE U.S. DOT NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION, JUST WONDERING IF ANYONE ELSE HAS SO WE CAN ACTUALLY GET A RECALL GOING SINCE IT HAPPENS TO A LOT MORE 3.6L'S THAN I THOUGHT. ONLY HAD 78,000 MILES ON IT AND I NEED MY ENTIRE ENGINE REPLACED. NO CHECK ENGINE LIGHT, OR WARNING SIGNS CAUSED IT TO HAPPEN, OIL CHANGED REGULARLY, AND REGULAR MAINTENANCE DONE.
06-12-2017, 08:32 PM | #32 | |
78,000 miles on a modern car is inexcusable.
09-06-2022, 08:11 PM | #33 |
Drives: 2012 3.6l v6 camaro Join Date: Aug 2022
2012 3.6l camaro engine locked up
I have an engine that you can turn the crank shaft like 1/4th of a turn then stops and won't go any further. I removed valve covers, and oil pan and nothing seems to be broken or messed up then I pulled timing cover off and still unsure why crank doesn't move. If you have any idea on how to help me please do. (Motor has 101,000 miles on it?
09-07-2022, 07:14 AM | #34 |
09-07-2022, 11:02 AM | #35 | |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
09-07-2022, 12:49 PM | #36 |
Drives: 2012 Victory Red LFX Join Date: Dec 2012
Sounding a lot like a seized piston.
2018 SS wheels, red Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, front grille Bowtie delete, painted red rotors and calipers, 1/4 window American Flags, splash guards, AEM dry panel air filter.
09-07-2022, 08:07 PM | #37 |
Drives: 15SS Camaro Join Date: Dec 2020
This could be a little tough to figure out but it can be done. 1st thing I would do either remove the heads OR disassemble the cam-train to close all the valves. Then simply check if the crank turns ok. If it does you know the valve timing was off and a piston was hitting a valve. With the heads off all this will be much easier to check out. Most likely some of the valves will be bent and need repair or buy used heads off of fleabay. Then replace and time the timing chains and you'll be cruizin again.
09-07-2022, 09:38 PM | #38 |
Drives: 2010 RS Inferno Orange Metallic Join Date: Mar 2010
yep if you really want to buy a Piece of Trash
Get you a V6 Camaro 80k head gasket, new engine 90K bad cats oh btw Air conditioner duct breaks at 95K 100K rear end goes out
PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
09-07-2022, 09:59 PM | #39 |
I've had a 1981 Fiat Spyder that was More dependable than the V6 Camaro
The only reason I don't have it was some one totaled the car Right now the Camaro is in the front yard as an ornament. Do yourself a Favor Do not buy this piece of Trash, Buy you a Ford At least they will look good sitting in the Yard
09-08-2022, 05:59 AM | #40 |
but it does look awesome sitting in your yard though...shiny too.you must have plans for it.
09-08-2022, 07:33 AM | #41 |
I would guess he's gonna continue to keep driving it like he stole it and replace whatever falls off.
Mmm, nice shiny red in just the right light. Yep, I can relate.
09-09-2022, 08:51 PM | #42 |
My wifes v6 Camaro has over 130k and runs like new never touched a thing except spark plugs. It is well maintained and thats the secret to keeping any car. Neighbor has a v6 with over 100k and he beats the crap out of it the only trouble hes has was the AC compressor. I see used ones all the time with 150k plus miles on them for sale. I think the early v6 Camaros with the LLT engine were more prone the troubles but I wouldn't call them trash. I've read plenty of hard luck stories with v8 too, I often wonder when I read it just blew up what really happened.
