10-01-2020, 10:42 AM | #1 |
Trading 765 RWHP '13 ZL1 for '19 ZL1 1LE today! Looking for the truth!
So, after years of contemplation and a week of a pissed off wife... I am getting my 1LE today. I am torn on how excited I should be haha. I have been getting this car ready to roll for 5 years now and I finished everything last year. But, I couldn't get the 1LE off of my mind and just had to pull the trigger. It was that or a c8... and I think at 6'4" 300 lbs that I might be a smidge too big for a c8 haha.
Anywho, I am reading a lot of conflicting "Facts" on here and I want to see what direction I am going to go when I mod this lil guy. Do it once, do it right. I want to be close to what I had before but in a 1LE haha. So, can I get clarification on the following things from you guys? -Heard injectors are good to 900+rwhp, heard they aren't. I know I am going to need a pump at 700+. I had the DSX kit in my '13 and I dug it. Will do again. When do I need to worry about redoing the injectors? I have a 6.2 DI in my '18 half ton and know how important the catch cans are so it will more than likely be on the first round of mods. -Was the oil issue on the A10 fixed in '19? Still see guys recommending a pump on 19's and I see guys saying that it was fixed. -Heard the motor and block need to be pulled to put in a cam/oil pump. I am just seeing how in depth this is going to get haha. -This SC is smaller than the '13 zl1. But, has less heat soak, even when pullied. I know cooling was huge in the '13. I will still be doing cooling but how much is really needed? I don't want to go to the 2650. I will be porting this guy. -The LT4 is stronger than a LSA? I have seen a lot of people having oil issues on the their LT4 and I really have not seen a lot of issues on a LSA. I fear about buyers remorse haha. I love my current car but I do know that I am getting a better car. I just want to make sure that I am not trading in to get something really finicky and PIA to get right haha.
764RWHP on e85 683RWHP on 91. M6 Black on Black on Black. 1300ID's, DSX Aux Pump and Flex Fuel Sensor, Lingenfelter 2.5 upper 9.5 lower, 100MM idler, AFCO HX w/ FANS. 1 7/8"ARH exhaust to axle incl LTH, MF's, Fuel Lab FF, Lingenfelter ported snout and TB, Lingenfelter CAI, RotoFab coolant tank, NGK 2 steps colder spark plugs, Moroso catch can, BTR Stage III cam, crank case breather. Tuned by Power Labs in Idaho Falls, ID.
10-01-2020, 10:49 AM | #2 |
Used to own a ZL1
Drives: '16 Z06 Join Date: Apr 2020
The 6th gen ZL1 is a serious package, the 1LE even more so. I don't think you can possibly be disappointed with it no matter what you drove before. If you're going for 765, you can get there safely with a couple fuel mods. A cam and aux pump should be plenty.
I will let someone with more experience answer though. Grats on the new ride! |
10-01-2020, 10:55 AM | #3 | |
Drives: 2020 Camaro ZL-1 1LE Join Date: Jul 2018
1LE Upgrades
Home Track: NCM Motorsports Park
10-01-2020, 11:03 AM | #4 |
No component on the factory fuel system is capable of 900+ whp DI only. On MS109 race gas you could probably stretch it out to 850whp but not on pump 93 and not even remotely close on E85. Meth and a mix of E might get there. So the conflicting info you are hearing is likely based on different fuels and using meth or not.
2016 NFG 1SS A8
10-01-2020, 11:08 AM | #5 | |
If I go 800RWHP with e98... am I good on stock DI?
10-01-2020, 11:39 AM | #6 | ||
850 ON E60 WITH CAM 32% LOBE AND FUEL PUMP VOLTAGE BOOSTER. Quote:
I had a 13 ZL1 and now have an 18 ZL1 1LE and can speak from experience. 2 very different cars all positive. Feel free to call me 203-753-7223 Ted.
www.jannettyracing.com
10-01-2020, 02:13 PM | #7 | |
10-01-2020, 02:46 PM | #8 | |
AXLERODZL1
Drives: 2019 Riverside blue ZL1 Camaro Join Date: Dec 2018
No issues have been made public on any 19's so far. That looks to be a 17-18 issue. My 19 was purchased in Nov 18 and has done excellent.
'19 ZL1 A10 Riverside Blue PDR/Nav/Sunroof
Kong ported blower/snout Roto-Fab Big gulp 103 TB Lingenfelter Lower Pulley(9.17) 1 7/8 ARH headers and Exhaust Meth injection(single nozzle) 733whp/788tq |
10-01-2020, 04:51 PM | #9 | |
2016 NFG 1SS A8
10-01-2020, 10:50 PM | #10 |
Drives: 2018 ZL1 1LE Join Date: May 2020
Just a heads up - Doing research on catch cans I found numerous posts about people having their warranties voided for having them, or being threatened that it would be if they do install them. I bought an Elite Engineering catch can that I have yet to install on my car for this very reason. I keep going back and forth. It's not just a quick uninstall if the car has to go to the dealer. The supercharger has to come off and you have to buy all new supercharger bolts, and lid bolts as they are one time use.
10-01-2020, 10:57 PM | #11 | |
10-02-2020, 07:13 AM | #12 |
How did this turn in to a warranty discussion?
10-02-2020, 07:14 AM | #13 |
Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
With the stock SC ported and cam I’m sure you can make 730-740whp. Heat soak is an issue if you are doing back to back runs. To limit that you can do meth. That will also help to make more power. For reference I have fill bolt ons, cam, ported SC, and meth. Car makes 780whp but I won’t be doing back to back pulls even with the meth. Normally let the car cool about 30min between 1/4 mile runs. If I was tracking the car I would not have so much pulley to increase boost. Maybe just a 2.3 and that’s it.
Now if you want to make 800+ the Mag 2650 seems to be the favorite way to go. I think regardless of what you decided with cam and full bolt ons with 2650 you are maxed on fuel to about 850whp without doing very expensive fuel upgrades. At any rate this car is light years better than the 13 ZL1. It’s also about 200lbs lighter. |
10-02-2020, 07:21 AM | #14 |
Drives: ZL1 1LE M6, Pontiac TransAm 400-T10 Join Date: Aug 2019
