02-12-2019, 10:55 AM | #1 |
Drives: 2015 ZL1 Lingenfelter 700 Join Date: Mar 2017
Max power for NA build?
I am looking for some input in regards to max power for a NA built motor. I have had a couple of z/28's and the last one was fully built by 21st Century Muscle Cars here in Dallas and it was a monster, but that was an LS7 motor. I am trying to decide between a 1SS 1LE or the ZL1 1LE for my next car. I wont daily drive it but it wont just be a track car, so like many guys, I am trying to determine if I can live with the very track focused suspension on the ZLE. With that in mind, I am wondering if I can juice up the LT1 enough to make a 1SS 1LE work for me.
FYI- I had a 2016 1LE and also had a 2017 ZL1 but it had the auto. The 1LE was a fun car but I felt it needed more power. The ZL1 was strong but not as engaging- it was easy to go fast but it didn't FEEL fast (probably because of the auto)...should have gotten a manual Looking for feedback from guys that have built their LT1 motors, how much HP and torque they are producing and if they are happy with the results. Thanks in advance and sorry for the long post! |
02-12-2019, 11:39 AM | #2 |
Drives: 2018 SS 1LE Join Date: May 2018
Local guy with H/C/I put down 555whp on his 18’ 1LE & Cordes Performance
🌽 Sauced, 2018 SS 1LE - 123mph @ 5,000 DA
ARH 2”x3” FULL System, Pray Ported MSD Intake Manifold, Pray Ported GM 95mm TB, RotoFab CAI, DsX e85 Kit, MightyMouse Catch Can, NicD Tune https://instagram.com/corn_sauced?ut...d=o0ako89uurwl |
02-12-2019, 11:45 AM | #3 |
Drives: 2016 Camaro 2SS Join Date: Apr 2018
I'm having a full NA build being done right now at HHP. I should be at 560 through an auto when its said and done.
02-12-2019, 12:54 PM | #4 |
Drives: SS 6 speed of course Join Date: Jan 2016
Max what street or race? A stage 3 street build with aftermarket heads ported, 420 plus CID, e85 or even better wot meth injected (dual inject) sleeved block, custom 2" headers, sheet metal intake, over 600 WHP, maybe way over. There are less crazy builds at over 700 engine HP already.
02-12-2019, 01:01 PM | #5 | |
I am looking to track it occasionally on road courses, it wont be doing any drag racing. |
02-12-2019, 01:02 PM | #6 |
02-12-2019, 01:07 PM | #7 | |
https://www.lmperformance.com/104190...der-heads.html Here is a close to max build (minus the Jr heads and a MSD instead of a sheetmetal, no E85) http://www.superchevy.com/how-to/eng...d-performance/ sumting like 22K for that engine. Road course, you are going to need cooling and a whole lot of midrange I'd do: Pray ported heads, Pray ported intake with ported 95mm TB drop in forged piston and rods stock weight 2" headers off road pipe Rotor Fab Stg II cam with bigger fuel lobe, 112 LSA 23x by 24x Mishimoto cooling on everything E85 good tuner DSSV shocks... ummm $12k no labor estimate on either price
02-12-2019, 01:45 PM | #8 |
My build has the following Butler
1.Pray ported MSD manifold 2.Pray ported 95mm throttle body 3.TSP ported heads 4.TSP VVT-2 cam 5.E85 6.Rotofab CAI 7.GPI drop in rods and pistons 8.TSP 2in headers Total price your looking around 12k to 14k depending on how much labor cost is at whatever shop you choose. |
02-12-2019, 01:52 PM | #9 | |
sounds pretty strong- when do you get the car back? |
02-12-2019, 01:56 PM | #10 | |
02-12-2019, 02:29 PM | #11 |
I'm hoping sometime next week they sent the motor to LME to do all the cleanup and machining so pretty much LME is doing the whole motor build instead of HHP.
02-12-2019, 02:36 PM | #12 |
TxSpeed uses the VVT with a 20 degree restrictor, so I can see their cam building a little more midrange, for locked cams, a 114 or 112 LSA will build a lot more torque in the mid-range.
02-12-2019, 03:35 PM | #13 |
They actually recommend the 0 degree lockout now for their Lt1 cams and the 4 degree for the Lt4
02-12-2019, 04:30 PM | #14 |
Interesting because their "thing" was keeping the VVT "The gen 5 LT1 engine utilizes Variable Valve Timing (VVT) controlled via a cam phaser. A cam phaser is a computer-controlled cam gear that automatically optimizes camshaft timing based on the current engine RPM. While this technology provides tremendous efficiency benefits, it presents a challenge when designing performance cams due to the wide range of valve timing movement and constantly changing piston-to-valve clearance. With the help of Texas Speed's Superflow 902 engine dyno, we are able to custom-design camshafts and phaser tuning tables to allow our gen 5 LT1 customers the ability to purchase the ultimate in LT1 performance camshafts! Thanks to the Superflow 902 dyno, Texas Speed is the only company that currently offers a VVT camshaft with a phaser table included to properly tune the camshaft phaser once it's installed in your 2014+ Corvette!
The Texas Speed & Performance LT1 VVT-2 camshaft is a great choice for the enthusiast looking for an additional jump in horsepower.y. It will have a nice lope at idle and will require a higher stall speed torque converter for automatics. It does remove the factory AFM/DOD system that deactivates cylinders, but it retains the variable valve timing (VVT) system that allows the engine to advance and retard the cam while the engine is running. This provides a much better power curve since the engine can advance the cam in the lower RPM's for better torque and retard the cam in the upper RPM's for better horsepower. We do recommend using our TSP .660" dual spring kit with PAC springs & titanium retainers and TSP hardened chromoly pushrods with this camshaft. Each gen 5 LT1 camshaft Texas Speed offers will require the use of a Comp Cams Phaser limiter kit. The phaser limiter restricts the range of cam timing movement to 20°. This modification provides the necessary valve clearance for serious performance camshafts with tighter lobe separations while still utilizing the benefits of the VVT technology."
