Old 07-22-2018, 09:40 PM   #1
masoch
Drives: 2017 Camaro 1SS M6
Plasti-dip - How do I keep messing this up?
Trying to plasti-dip the bow ties on my SS. I've watched 50 videos on this, the process is easy enough but I keep on screwing up when I'm removing the tape from the chrome section of the bow tie. The coating is getting between the gold emblem and the chrome so when I go to remove the tape, I'm also peeling a piece of the coating off the gold.
How do I avoid this? I have been rolling the tape over the chrome lip of the bow tie, could this perhaps be the issue? Maybe I need to go over that area with an exact-o knife to prevent it from peeling when I remove the tape? I feel stupid having to ask this question but I can't be the only one who has had this issue before!
masoch is offline   Reply With Quote
Old 07-22-2018, 10:15 PM   #2
DougCBJ
Drives: 2016 Blue 2SS
stop taping the chrome just tape a square around the emblem and then tape up some newspaper surrounding the area to avoid overspray. 1st coat light, next coat heaver due 4 or 5 coats over the entire area not taped off this will make it easier to remove. Then just make a small nick on the chrome area and pull, it should pull around the center no problem.
DougCBJ is offline   Reply With Quote
Old 07-22-2018, 10:24 PM   #3
chris227
chris227's Avatar
Drives: 2020 Camaro 2SS
Peel the tape while the plasti dip is still wet.
Old 07-22-2018, 11:52 PM   #4
Camaro_QC
Camaro_QC's Avatar
Drives: 08 Tiburon GS, 2018 Camaro 2.0T
Exactly what both says. But the most important, peel while wet.
2018 Camaro LS | 6 spd | 2.0L turbo | Nightfall Grey | RS package | Technology Package.
Order WDGHKX
1100 - 5/08/2018 | 3800 - 6/18/2018
2000 - 5/09/2018 | 4200 - 6/21/2018
3000 - 5/28/2018 | 5000 - 6/27/2018
6000 - 6/29/2018
Camaro_QC is offline   Reply With Quote
Old 07-23-2018, 12:26 AM   #5
masoch
Thanks everyone, both of these tips I will be putting into action next weekend.
If anyone else has other ideas, don't hesitate!
Old 07-23-2018, 03:27 AM   #6
SR 33
SR 33's Avatar
Drives: 2016 1LT - SIM
I did this exactly, worked perfectly
SR 33 is offline   Reply With Quote
Old 11-09-2018, 01:09 PM   #7
BA RS
Big B
BA RS's Avatar
Drives: 2016 2SS Summit White
or you can get a heat gun and seperate the center bowtie from the chrome piece. Then scuff the center piece a little . Spray some primer on it and let is dry then spray what ever color you want for the center of the bowtie and then let it dry. Then clear coat and once its all dry get some 3m tape and tape it back to the chrome piece. Then you wont have to keep messing with the plastic dip and it will last longer.
2016 2SS,NPP exhauset, A8, Black and White interior, black rims, black center stripe.
BA RS is offline   Reply With Quote
Old 11-09-2018, 08:17 PM   #8
Muthstryker
Drives: Black SS
Plasti dip done correctly is perfectly fine. Peel tape while wet, before spraying keep the cans of dip in hot water to warm them up.
Muthstryker is offline   Reply With Quote
Old 11-09-2018, 11:37 PM   #9
Camaro_QC
Camaro_QC's Avatar
I agree with yarbie though... I hate plasti dip... Used it once, liked it for a day and regretted it for 3 years almost...
Never gonna use that product again.
Order WDGHKX
6000 - 6/29/2018
Old 11-10-2018, 11:58 AM   #10
KirkH
I like peel coat spray paints for bowties. Use many light coats. Peel tape while wet. Use the glossifier to finish.
I like to be able to change up the color of my bowties to match the different color stripes I apply. Here's a fun one I did for my previous nightfall grey metallic RS:
Black peel coat, krylon glitter blast, glossifier
Old 02-10-2019, 08:20 PM   #11
CruzinQueen
CruzinQueen's Avatar
Drives: 2017 1LT RS Convertible V6 A8
Did the same thing on my old 2016 Colorado. It worked perfect and lasted through two winters, probably 60 car washes, summer bugs, etc with ZERO problems. It's awesome and if you like to change it up it's a simple process to paint, peel, and repeat as many times as you like. I love plastidip for emblems and can't wait to get after my 2019 Terrain this spring.
2017 Camaro 1LT RS V6 A8 Convertible - Silver Ice/Black Cloth, K&N CAI, MRT v. 2 Axle Back, Redline-style Badges and Wheel Hashes, American Authority Grille & a Whole Lot of Attitude
2019 GMC Terrain SLE 1.5T - Blue Steel Metallic/Black Cloth "Soccer Mom Spec"
CruzinQueen is offline   Reply With Quote
Old 02-11-2019, 08:21 PM   #12
Tha_Infamous_E
Drives: 2017 Camaro SS
In all honesty, I've learned the hard way that Plasti-Dip is just the cheap ass way of going about things - the amount of time and effort you have to spend in getting it right will out-cost the fact of just buying them painted from a professional company like RiverCityCreations or something - it's only $70 for each emblem and it comes out perfectly glossy. This goes with rims and everything else, just get them painted - don't bother plasti-dipping that shit, even if you get it on properly, good luck removing it without tearing your hair apart. Also, the matte look of plasti-dip just doesn't look pleasing either, makes it incredibly easy to spot and very cheap look to it as well.
Tha_Infamous_E is offline   Reply With Quote
Old 02-11-2019, 09:02 PM   #13
oOKhanhOo
Drives: 2018 SS 1LE
I wrapped mine with leftover vinyl. Just need the vinyl, razor blade, and blow dryer.
oOKhanhOo is offline   Reply With Quote
