01-18-2018, 07:19 PM | #29 |
Drives: 2016 Camaro 2SS/RS Join Date: Oct 2008
My 2005 Silverado with manual controls does this. If the system is off it blows air through the vents. I read the owner's manual when I got the truck and it said this is normal. It only bothers me during winter when it sends cold air from outside. So I change the setting to blow the air to the floor and raise the temp to warm my feet without turning the system on.
2016 2SS: Silver Ice, A8 Auto, Adrenaline Red, Black Rally Stripes, and Black bowties.
My Journey..... 1100 Status - 08/17/2015 : 2000 Status - 09/28/2015 2500 Status - 09/29/2015 : 3000 Status - 09/29/2015 3000 Status - 10/19/2015 TPW 11/9 3800 Status - 11/04/2015 Seq: 122808 4300 Status - 12/17/2015 (Charlotte, MI) 4200 Status - 01/08/2016 4800 Status - 01/14/2016 5000 Status - 01/19/2016 6000 Status - 01/20/2016 |
01-18-2018, 11:16 PM | #30 |
Drives: X-15 Velocipede Join Date: Mar 2008
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer STANDARD DISCLAIMER camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever, whether express, implied, or statutory, including, but not limited to, any warranty of merchantability or fitness for a particular purpose or any warranty that the contents of the information will be error-free. |
01-19-2018, 01:02 AM | #31 |
Drives: 2SS 1LE Join Date: Oct 2011
I really did not like the one in my BMW 4-series, on auto it would run the A/C continuously, no matter what the conditions (so the dead of winter), which made it take longer to get heat going, and if you didn't have the vents set right it would constantly blow cold air, in addition to the climate control there was some sort of temp gauge on the vent itself, which I didn't figure out for a while, but if you have it set to auto it does whatever it was doing last when you start up the car, no matter what the temp is, so it'll blow cold air full blast rather than wait till it's heated up and then do hot air. I'd rather have no air and let it warm up than be blasted by cold. Due to how frustrating the "auto" was, I simply never ran it on auto, it was kind of ok in the summer at times, but absolutely not in the winter. Camaro system seems better so far.
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
03-08-2018, 01:56 PM | #32 |
Drives: 2016 1LT RS Join Date: Sep 2015
I noticed with mine, that on full auto and I want the a/c off and have outside air to help regulate the temp. I close the driver vent...weirdest setup ever.
02-04-2019, 08:27 PM | #33 |
Drives: Chevy Camaro 2017 SS Join Date: Feb 2019
Always on climate controls
Just bought a 2017 camaro ss. I called a dealer and asked the same question. It's normal to have the temp display on and fan speed off. There will always be a little air flow. I believe the service rep said it keeps the blower motor lasting longer if the system is constantly running. There are climate settings that do allow you to choose low, meduim, or high auto climate flow which helps a little i think.
02-05-2019, 12:15 PM | #34 |
Howdy! Pete here...
Drives: 2017 50th Anniv 2SS, A8, NPP, MRC Join Date: Jul 2009
Interesting thread. Maybe I should try changing some of these settings.
I'm over 36K miles and have NEVER turned the A/C off--even in 20 degree weather (except at the track). I just turn the temp up or down to get the comfort level I want. With the A/C always on, the compressor removes excess humidity in the cabin. Also...I leave it in recirculate mode 100% of the time.
PnCRedJwl2SS
2017 50th Anniversary Edition, A8, NPP, MRC, w/Sunroof and Glow-tie! ___________________________________________ ___________________________________________ Ordered from GM Delivered to dealership and home 9-16-16 This car is a beast! |
