02-06-2017, 12:20 AM | #1 |
Th400 streetable?
OK so I bought a used th400 in good working order for $100. Obviously it's a 3 speed. Would that trans if built be a good option for the Camaro? It's street driven alot.
345 gears 30" tire
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/ |
02-06-2017, 12:42 AM | #2 |
Drives: 2023 SS 1LE 10SPD/2015 SS 427 Man Join Date: Aug 2015
Is this a trick question? Not trying to be smart A**. If you enjoy driving it on the street the TH400 sucks. Your overall gear first gear ratio will be reduced because of the 2.10 Th400 first gear. You will need like 4.11 (or more with a tall tire)rear gear to get you back to where you were. If your primary goal is to get your weight and quarter mile e.t. down then It's a great choice.
02-06-2017, 05:04 AM | #3 |
Drives: IOM 2SS/RS Join Date: Dec 2011
I have a th400 with the stock auto rear gear, 3600 stall and 28" tire. Drive it everyday no issues at all. It's a blast with the turbos
02-06-2017, 08:21 AM | #4 |
Drives: 2010 2SS LS3, 2013 duramax Join Date: Nov 2012
4L80
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
02-06-2017, 08:37 AM | #5 |
Drives: 2010 Camaro SS Join Date: Aug 2013
There was a time when millions of cars on the road had three speeds...and they drove just fine. With 3.45 gears, it wont be the fastest off the line, but it wont be bad at highway speed.
02-06-2017, 08:39 AM | #6 |
Drives: 2015 camaro 2lt Join Date: Dec 2016
how much power you making?
Cosmetic mods: SS hood with painted vent, SS bumper, acs 1le front lip black, big worm gfx tinted all lights, solar wing v2, Camaro seat belt pads and oracle color shift halos and fog light halos and rear colorshift bow tie, carbon creations carbon fiber stingray z spoiler
Wheels: lexani r-3 bg finish 19x8.5 Performance: cold air inductions intake, mrt v1, jacfab ported intake manifold, intake manifold spacer, overkill tuned on E85. |
02-06-2017, 10:38 AM | #7 |
Drives: 2010 camaro ss Join Date: Jun 2010
I don't drive mine much but when I do it's fine on the street. It actually makes me do the speed limit now lol. At 70mph I'm at 3k rpm. Mine doesn't feel like a turd off the line with the 3.45 gears. I'm at 600whp through the th400 and on a loaded mustang dyno
02-06-2017, 11:02 AM | #8 |
Well when I'm all said and done I'll be over 1000whp with a manual. I've been throwing the auto idea around for sometime. But I built my car for a fun street car not a drag car. But I still want to gap people on the track too lol it's hard pick
02-06-2017, 11:30 AM | #9 |
Drives: Black '13 2SS/RS/1LE w/NPP/NAV Join Date: Oct 2012
TH400 was for many years (20-30) considered the go to transmission in the GM world if you made a lot of power. That said it was always known for "weird" gearing and that "damned electric kickdown switch". For a DD with durability concerns I would probably lean towards the 4L80e. It's big and heavy the gearing is supposedly better and by now they know how to build them strong. In the early days people would make them worse because they didn't know WTF they were doing with them when they tried to make them better.
You're going to enjoy that OD 4th gear for daily commutes. No matter what you need to make sure you have the right rear end gears and converter for your setup. Sent from my SM-G935V using Tapatalk
My Build Thread... http://www.camaro5.com/forums/showthread.php?t=285054
02-07-2017, 12:17 AM | #10 |
This is how I know I'm getting old. I went thru all the years in muscle cars buzzing around at 3-3500 RPM on the expressway/freeway and just got sick of it. The noise, the wear and tear on the motor, the fuel consumption. Its just been in the last few years I've gotten into higher horsepower late model cars and really enjoy the comforts of overdrive and NPP exhaust.
02-07-2017, 04:31 AM | #11 | |
02-07-2017, 09:25 AM | #12 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
I love the sound of a big pushrod V8 humming down the interstate. That's why I put 4.10s in mine after I swapped to th400. Love it. And I'm in my 40s and 9 out of the 12 camaros I've owned weren't overdrives. Out of all of the mods I've done to mine the gears hurt the mileage the worst. But who cares about that? Lol
I've put 1900 miles on mine in the last month.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
02-07-2017, 09:42 AM | #13 |
Also th400 was good enough for companies like Rolls Royce, Ferrari and Aston Martin to use them. The early ones with the big sprags could take almost 800 hp stock.
02-07-2017, 09:46 AM | #14 |
Drives: 2010 aqua blue SS/RS M6 Join Date: Feb 2010
I daily my th400 car all the time.
I have 4500 stall and 3.91s 70 mph cruise is no problem. I wouldn't have my car any other way. Plus my car had gone 10.8 in the 1/4 so far and put me at the best of #9 on the fastest sbe cars
10.91 at 122 H/C stock block N/A
