Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 10-26-2016, 04:46 AM   #1
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
th400 brotherhood
Post up if your family.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Bo White is offline   Reply With Quote
Old 10-26-2016, 10:19 AM   #2
Bad70supreme
Bad70supreme's Avatar
Drives: 2010 aqua blue SS/RS M6
What's up my brother!
10.91 at 122 H/C stock block N/A
Bad70supreme is offline   Reply With Quote
Old 10-26-2016, 10:51 AM   #3
camarosspower
camarosspower's Avatar
Drives: 2010 camaro ss
Right here hermanos
camarosspower is offline   Reply With Quote
Old 10-26-2016, 03:39 PM   #4
MoeIv
MoeIv's Avatar
Drives: IOM 2SS/RS
Checking in
MoeIv is offline   Reply With Quote
Old 10-27-2016, 12:31 AM   #5
rdlawrence912
Drives: 2011 2SS/RS
Questions re: swapping
So, bottom line...how much are you guys averaging $$$ wise to do the swap, and what constitutes a good th-400 for transplant? I.e.: any specific model years, what modifications to make it worthwhile/make sense to convert from manual? Theoretically car would be used for track duty and street shenanigans on occasion.
rdlawrence912 is offline   Reply With Quote
Old 10-27-2016, 02:03 AM   #6
Bo White
Bo White's Avatar
1963-1995 is the official production years of the th400 although Chevy didn't start using it until 1965. Caddy and Buick used it before then. The early ones had a better drum but other than that they are all basicly the same. Its been used from the factory in anything from Hummer H1s to a few Jaguars and Mercedes and Bentleys even.
I've got about $3k in my swap. I used a lot of good parts too.
Totalled:
Old 11-27-2016, 10:27 PM   #7
Blakester
Drives: 2010 1ss
I am trying to decide if i wanna do th400 or 4l80e. Has anyone been able to get good worth while gains/results in e/ts by going m6 to a3 or a4 with a bolt on and or cam only car? Or not worth it?
my stock ls2 a4 gto was quicker than my camaro at the track, while my camaro traps 4 mph better. I just cant drive. Lol
Blakester is offline   Reply With Quote
Old 11-27-2016, 10:37 PM   #8
Bo White
Bo White's Avatar
My car on street tires M6 best was 8.02 in the 1/8
My car on street tires th400 best was 7.50 in the 1/8
Totalled:
Old 11-27-2016, 10:39 PM   #9
Bo White
Bo White's Avatar
Thread to read. www.camaro5.com/forums/showthread.php?t=327289
Totalled:
Old 01-15-2017, 11:03 PM   #10
Bo White
Bo White's Avatar
How many miles you guys put on your rides after the swap? I will do about 30k miles this year.
Totalled:
Old 01-17-2017, 01:18 PM   #11
tpower
DBLCHBY III
tpower's Avatar
Drives: 15 1LE
What gear and what type of rpms are you running at 60mph ?
tpower is offline   Reply With Quote
Old 01-18-2017, 01:00 PM   #12
xc_SS/RS
Drives: 2010 Camaro SS/RS
What all is involved with making a TH400 fully manual? Just the manual valve body?
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 01-18-2017, 01:13 PM   #13
Bo White
Bo White's Avatar
I'm at 3000 at 60 with 4.10s
Manual VB is all you need.
Totalled:
Old 01-18-2017, 02:57 PM   #14
tpower
DBLCHBY III
tpower's Avatar
Drives: 15 1LE
Thanks Bo White
