06-04-2020, 02:20 PM | #1 |
Drives: 2017 Camaro Join Date: Feb 2020
wrapped hood....
Hello.
A cat has been walking and sleeping on my hood. this morning I woke up to find a scratch on my hood about half a foot long. Now when i feel it is not a keep scratch meaning there is no feel to it. it is smooth. I tried to put on some matte spray and wipe it...but its till there. what can i use to get it out? its a 3m black wrap. like in sig. thx
06-04-2020, 11:04 PM | #2 |
Drives: 2019 SS1LE Garnet Red../Silver CL30 Join Date: Mar 2019
Adams VRT would be worth a try. I use it on my 1LE hood with good results.
06-04-2020, 11:11 PM | #3 | |
Drives: 19’ Camaro SS 1LE Join Date: Nov 2016
If you run your fingernail across the wrap, can you feel the scratch? I use ‘Chemical Guys, Wrap Detailer’ and it’ll make short work on pretty much anything unless it’s actual damage.
2019 Camaro SS 1LE
06-05-2020, 12:12 AM | #4 |
Drives: SS 1LE, 89 TTA, 91 GTA, 91 Formula Join Date: Jul 2019
I recommend waking up at odd hours to check your car. Bring a bat with you. All it will take is one good hit and you will not have the issue again. Been there, done that.
06-05-2020, 02:38 AM | #5 |
Drives: 2019 ZL1 A10 Join Date: Aug 2018
06-05-2020, 06:15 AM | #6 | |
Drives: 2017 SS A8 Hyper Blue/White Stripes Join Date: Jun 2010
OP, you might check with a local company that does wraps and see if they think it can be corrected or will need replacement. Maybe someone here knows of a correction product? The issue I see is anything that would remove the scratches will also create a shiny spot in the flat finish.
2017 Camaro 2SS Hyper Blue
2011 Camaro 2SS 2004 Corvette CE SOLD Last edited by Memphis SS; 06-05-2020 at 07:23 AM. |
06-05-2020, 06:28 AM | #7 |
Drives: Former 2016 Camaro 1LT Join Date: Jan 2017
On the subject of wraps ho much does it cost to get a hood wrapped?
My 97 TJ Wrangler (show Jeep) hood suffered damage with scratches down to the primer from an intense storm at work 2 weeks ago. Needs complete sanding and re-paint and clear coat. The cost is a whopping $750.00. And if it does get damaged like in this case is it repairable or do you need to get it re-wrapped?
2006 C6 Corvette Manual, 2019 Silverado, 1997 Jeep Wrangler
06-05-2020, 07:14 AM | #8 |
06-05-2020, 09:59 AM | #9 | |
Drives: 2002 z28, 2018 2ss 1LE Join Date: Sep 2012
Put a cover on your car If you’re that worried about it, I did. |
06-05-2020, 12:48 PM | #10 |
No I do not feel the scratch. Good thing.
I would not hurt the cat either. The wrap cost me $250 at a local graphics place. I'm gonna try that spray. 3m vids state to try a detailer. Then try a heat gun.
06-05-2020, 12:59 PM | #11 |
Drives: 08 Tiburon GS, 2018 Camaro 2.0T Join Date: Sep 2017
Do not heat the wrap too much. The satin finish might be impacted and will look more glossy.
2018 Camaro LS | 6 spd | 2.0L turbo | Nightfall Grey | RS package | Technology Package.
--------------------- Order WDGHKX 1100 - 5/08/2018 | 3800 - 6/18/2018 2000 - 5/09/2018 | 4200 - 6/21/2018 3000 - 5/28/2018 | 5000 - 6/27/2018 6000 - 6/29/2018 |
06-05-2020, 01:46 PM | #12 |
thx qc.
06-05-2020, 03:04 PM | #13 |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
06-07-2020, 06:22 AM | #14 |
If you can feel an edge on it with your fingernail you'll have to peel it and redo it.
