05-24-2020, 06:44 PM | #1 |
Drives: 2016 SS Join Date: Jun 2019
Whipple IAT's
So I know these engines like to run hot but what is to hot when it comes to IAT's. Newly installed Whipple at a safe 6lbs is making 633RWHP and 622 Torque. With ambient temperatures today around 88 just driving local the IAT's were 125-128 hitting 135 a couple times. Should this be addressed before taking the car to a road track? Figure I will be losing HP after 135
05-24-2020, 06:46 PM | #2 | |
Drives: 2019 2ss 1LE Join Date: Mar 2019
Stock internals? |
05-24-2020, 07:04 PM | #3 |
Drop in Diamond Pistons, BTR cam
05-24-2020, 09:31 PM | #4 | |
05-25-2020, 10:10 AM | #5 |
That is right in-line where it should be for the ambient temp. Mine hit 131 yesterday in 88 degree weather after I ran 5th gear out to 6500rpm. 3.375 pulley hitting about 9.9psi of boost. My tune doesn't pull timing until 154 and I have yet to see a temp that high with it.
2016 NFG 1SS A8
