View Poll Results: Who has experienced an oil pump failure? | |||
2016 or earlier | 20 | 13.79% | |
2017 | 53 | 36.55% | |
2018 | 67 | 46.21% | |
2019 | 2 | 1.38% | |
2020 | 2 | 1.38% | |
2021 | 1 | 0.69% | |
Voters: 145. You may not vote on this poll |
Thread Tools |
06-05-2020, 02:20 PM | #407 |
Drives: '21 ZL1 A10 '08 SRT10 Join Date: Apr 2019
Since it was new the car was always 42 ish psi at most when driving. I always thought it was weird. Dealer said normal. It would drop down to 25 ish or so at hot idle. Always went up to 40-42 if you even touch the gas at all.
06-05-2020, 07:29 PM | #408 |
Drives: 2019 ZL1 Riverside Join Date: Apr 2020
06-07-2020, 03:10 PM | #409 |
06-07-2020, 03:17 PM | #410 |
Low 40s is about right - sky high oil pressures are probably a contributing cause to pumps failing prematurely
06-08-2020, 01:10 AM | #411 |
Drives: 2017 ZL1 HBM, M6 Join Date: Oct 2016
11/2016 build date.
2500 miles no issues yet I have 2 recalls I need to get done, wiring harness and something else I cant remember |
06-08-2020, 06:51 AM | #412 |
Drives: 2018 ZL1 Camaro 6M Red Hot Join Date: Aug 2013
I don't recall 2016 build dates as having the issue. I thought it was only late 2017/early 2018 builds that were affected.
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
06-08-2020, 07:26 AM | #413 |
Drives: 18 ZL1-1LE, 10 JKU Join Date: Jul 2018
Went to blip my throttle while driving last week and on 3 straight just NOTHING from the car...decided I’m finally ready to tune that BS out...but my car shares a birthday with yours...9k miles...i really don’t want to foot the bill for this motor
06-08-2020, 08:49 PM | #414 |
Did I miss something? I could have sworn a day or two ago the polling showed zero 2019 pump failures. I look today and I see a failure.... does anyone know if this is a true failure, or is it a mistake on the pollers part?
06-11-2020, 02:30 PM | #415 |
Drives: 2018 ZL1 1LE Join Date: May 2019
Reading thru this, I noticed people reporting oil pumps failing from highly modified motors so could be that as well.
Subscribe to my Youtube channel!
https://www.youtube.com/c/Junkyardspecial Will buy your GoodYear Supercar 3R Take offs! |
06-11-2020, 04:09 PM | #416 |
Well. I got the call. Car is supposed to be ready. Hopeful that it’s ready. Hopeful that it’s done right. Thankful for 2 more years of factory warranty.
06-11-2020, 05:59 PM | #417 |
Drives: 2018 Camaro ZL1 Join Date: Feb 2020
06-13-2020, 10:58 AM | #418 | |
Drives: gas powered Join Date: Jan 2019
Im reading there all box stock?
06-13-2020, 09:15 PM | #419 | |
The car is driving nicely. I did get the PID programmed in torque pro to show oil pressure. It was a surprise to get that to work. I had to program the PID manually. I’d love to know what other PID codes are hidden in this computer. Anyway... cars running well. Oil pressure never goes over 43 on the gauge again. According to the torque app. The pressure does go over 43 when driving but the gauge never shows it. It’s weird. The water temp never matches either till the engine is warmed up. My Viper is accurate with the app. Anyway. Off topic a bit. The car runs and drives. I did get to see the oil pump they removed. It was cracked in half. Similar to the photos shown earlier in the thread. |
06-14-2020, 01:10 PM | #420 |
Drives: 2018 ZL1 Garnet Red Tintcoat A10 Join Date: Jan 2019
Oil pressure doesn't even go up at WOT?? That doesn't sound right??
