Old 11-25-2020, 06:26 PM   #1
fxdxron1
Drives: 2016 Camaro 1SS
Over flow tank cap
Tried to remove my radiator over flow tank cap while the engine was cold. It turned a little but then got very tight. What am I doing wrong?
fxdxron1 is offline   Reply With Quote
Old 11-25-2020, 06:37 PM   #2
s346k
s346k's Avatar
Drives: like an old lady
if i recall correctly, the overflow tank does not have a twist cap.
Old 11-25-2020, 06:56 PM   #3
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Yeah it does...
Old 11-25-2020, 08:09 PM   #4
Wierd Harold
Drives: 2017 2lt rs
Try turning it clockwise my Silverado is that way.
Wierd Harold is offline   Reply With Quote
Old 11-25-2020, 09:08 PM   #5
You're doing nothing wrong. It will do that but just keep going.
Old 11-25-2020, 10:18 PM   #6
fxdxron1
You cannot turn in clockwise as it has locking tabs. When I turn it counter clockwise it gets so tight I think it will brake.
Old 11-26-2020, 12:23 AM   #7
s346k
s346k's Avatar
if you're referring to the top tank, it is not an overflow tank and should be full all of the time. the lower tank is the overflow and has a full cold mark and is filled via a cap that pops open.
i'm saying this because you can pour coolant in the top part all day and none of it will get to the reservoir aka overflow.
edit: yes that twist cap can be stubborn.
Old 11-26-2020, 12:34 PM   #8
fxdxron1
Yes, you are correct. The tank on the top is full and bottom tank is not when cold. Tank on top has a cap and will not come off.
Old 11-26-2020, 12:52 PM   #9
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
You just turn it counterclockwise and then lift the cap up. Works pretty much just like any other coolant tank cap.
The bottom tank should be half full when cold. There is a line on the tank you can use as a reference.
Lastly...
Sent from toaster or something
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
GM Performance Intake and that's it, because driver mods before car mods
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
UnknownJinX is offline   Reply With Quote
Old 11-26-2020, 05:10 PM   #10
Camaro_QC
Camaro_QC's Avatar
Drives: 08 Tiburon GS, 2018 Camaro 2.0T
2018 Camaro LS | 6 spd | 2.0L turbo | Nightfall Grey | RS package | Technology Package.
Order WDGHKX
1100 - 5/08/2018 | 3800 - 6/18/2018
2000 - 5/09/2018 | 4200 - 6/21/2018
3000 - 5/28/2018 | 5000 - 6/27/2018
6000 - 6/29/2018
Camaro_QC is offline   Reply With Quote
Old 11-27-2020, 05:15 PM   #11
fxdxron1
Thank you everybody for your help with this cap it's not coming off unless I breaks the tank when I do it.
Old 11-29-2020, 11:30 AM   #12
Jeb114
Jeb114's Avatar
Drives: 2021 300
Counter Clockwise is loosen, Clockwise is Tighten....
Jeb114 is offline   Reply With Quote
Old 11-29-2020, 12:00 PM   #13
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Righty tighty, lefty loosey!!
