11-26-2020, 08:47 PM | #1 |
Drives: 2020 Rally Green ZL1-1LE Join Date: May 2020
Low lift Cammotion Cam lobes
Has anyone had long term experience with using softer lobes (sub .600) in a daily driver? I'm wondering how much longer will a set of springs last if I get a Cammotion custom grind with somewhere between .570 to .590 lift.
Also thinking about installing PRC heads with bigger valves. Will the larger valves make up a bit for the lower lift? Thoughts? |
11-28-2020, 10:52 PM | #2 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
Sub .600 lift is the way to go for valvetrain longevity.
The GM hotcam is a .577 with a 1.7 rocker.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
11-29-2020, 12:23 AM | #3 |
^Agreed.
2016 NFG 1SS A8
11-29-2020, 02:13 PM | #4 |
Thanks for the confirmation!
11-29-2020, 05:58 PM | #5 | |
Sarcasm loading --------
Cam swaps are expensive - you would be looking at about 4k out the door, and swapping the cam for a small to medium HP gain would not be worth the cost. I would go with a maggie before doing a cam swap.
2018 MBM ZL1 1LE - Stock 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
11-29-2020, 06:35 PM | #6 |
One of the biggest reason for a cam is to get a larger fuel lobe to over drive the high side pump and increase fuel system headroom. So yes while it is expensive there is a point where it becomes necessary to make more power if trying to fuel the engine DI only.
2016 NFG 1SS A8
11-29-2020, 10:27 PM | #7 |
Eventually, its getting a 2650 too. For starters, I'm doing PRC heads, a cam, head studs, lifters, and fuel system upgrades for E85.
11-30-2020, 07:12 AM | #8 |
Green you'll make some serious power with the 2650 Heartbreaker. Go get it.
