10-07-2020, 02:11 PM | #1 |
Michelin Pilot Sport A/S 4
I have researched quite a bit for tires that I could use on non track set. I have seen people talk about the Bridgestones, but has anyone used the Michelin Pilot Sport A/S 4 with 285/30/20 and 295/30/20? Wondering if this setup would work for non track tires.
10-07-2020, 02:15 PM | #2 |
why not ps4s?
10-07-2020, 02:46 PM | #3 |
I want to be able to drive when temps are under 40 degrees.
10-08-2020, 07:59 AM | #4 |
Drives: 2017 Camaro 2.0T, 91 Miata Join Date: Jan 2020
They're quite new still, so it's likely no one would have much, if any, experience on them. I have the a/s 3+ as my daily wheels and am very happy. The a/s 4 came on the C8, so I can only imagine they perform quite a bit better. Not sure about their snow capabilities, but if that's not something the car will see, then it doesn't matter anyway.
10-08-2020, 09:44 AM | #5 |
If you commute and have a 2nd car to drive during winter, just buy the 4S which I have driven in Denver for 5 years when temps are above 30F, no ice or snow
'20 ZL1 1LE A10,
10-08-2020, 08:33 PM | #6 | |
Drives: '18 1SS 1LE Join Date: Sep 2017
I'd rather upsize the fronts to 295 than downsize the rears to 295's, sidewalls are thin enough no need to get smaller. Two weeks after I order the Bridgestones in 295/305 Michelin will come out with an amazing all season set in 285/305, so get ready.
'18 1SS 1LE Black, PDR
11-25-2020, 10:23 AM | #7 | |
Drives: BMW 335 Join Date: Nov 2020
I don't even own a Camaro, but I am strongly considering it. Just researching tire options as I can't get a way with the GY3 in the Northeast. |
11-25-2020, 11:38 AM | #8 |
Drives: 2018 ZL1 coupe Join Date: Nov 2018
Michelin lists PS4 A/S non-runflats on their site in 285, 295 and 305 /30-20. Whether any of those sizes are actually available is another question.
I have been looking forward to this tire as a replacement for the 'Stone RE980 A/S on our ZL1, but haven't seen much real-world feedback as of yet. |
11-25-2020, 12:09 PM | #9 |
When I was first looking, I did not see a 305 tire in the PS4 A/S, its great they have it now, but finding it is a bit harder, I can easily find it in 285 and 295. Guess I will have to see if someone can order it.
11-25-2020, 02:36 PM | #10 | |
This is the only Michelin part number I can find. 305/30ZR20 (99Y) - 90383 Also worth noting that Michelin tech service is not very helpful |
11-25-2020, 03:33 PM | #11 |
Drives: 2018 2SS 1LE Black Join Date: Aug 2018
It is a French company so theres that. I can't find them either, not so sure they exist in a non run flat. I would buy those in a NY minute to get away from the aptly named "Stones".
11-25-2020, 03:40 PM | #12 |
Tire Rack has the non-runflats in 285/30/20 and 295/30/20, but the at 305 width they only list the 305/35/20. I don't think dropping one notch down to 295 would hurt very much in terms of traction or even looks.
11-25-2020, 04:40 PM | #13 |
You would think but I have the Bridgestone's in 295/30-20 and 305/30-20 as they don't make a 285 and you won't be confused looking at them, the rear is visually wider. Michelin has an excellent molded in rim protector that I've personally tested on a granite curb on the PS4S, stretching a 295 on a 11" rim may nullify it. That said I have considered it as the Bridgestone's annoy the hell out of me, you could run over a nickel and feel and hear it and they look like vacuum cleaner belts.
11-25-2020, 05:00 PM | #14 | |
Michelin's site doesn't say anything to identify that part number as ZP (run flat) that I can find... Like you said, their site isn't very helpful. |
